Number of posts : 222 Age : 70 Location : uk saddleworth Points : 4030 Registration date : 2014-08-24
| Subject: Heads up on an electrical issue Thu Jan 30, 2020 11:33 am | |
| Hi guys this is a possible issue on older scoots that i came across recently i bought a 2001 none running scoot to break it when i hooked it up to a good battery it did run but there was no dash lights or anything light wise working on dismantling the scoot the problem was solved, in the feed from the battery there is a second wire that has a inline connector all looked ok till i pulled it apart it was fully corroded up and fell in bits so if you have a similar issue ie: dead dash and no lights might be worth a look at this terminal |
| Subject: Re: Heads up on an electrical issue Thu Jan 30, 2020 3:23 pm | |
| Usefull info Siataukreg, thanks. Mine is a 2001!
BTW, did you get my PM? |
| Subject: Re: Heads up on an electrical issue Fri Jan 31, 2020 6:04 am | |
bikehiker Silver Wing Rider
Number of posts : 433 Location : New Cumberland PA Points : 3177 Registration date : 2017-09-07
| Subject: Re: Heads up on an electrical issue Fri Jan 31, 2020 6:03 pm | |
| Thanks, Siataukreg, great heads up. Helps to solve an important one of those many wiring mysteries. |
| Subject: Re: Heads up on an electrical issue Sun Feb 02, 2020 7:19 am | |
| Thanks for the info! It is tidbits like this one that help us all. |
Michel Vachon Maxi-Scooter Rider
Number of posts : 142 Age : 67 Location : Granby, Québec, Canada Points : 2214 Registration date : 2019-03-26
| Subject: Re: Heads up on an electrical issue Tue Feb 04, 2020 8:01 pm | |
| Thanks, Siataukreg,
We always need that type of info for futur problem that could happen anytime....
Michel |
