| Oil for Silverwing | |
+6sc00ter Dale N. Mech 1 twa GHM-PM john grinsel Teresaamorris 10 posters |
Teresaamorris Scooter Rider
Number of posts : 3 Location : Sarnia Ontario Points : 1728 Registration date : 2020-03-05
| Subject: Oil for Silverwing Thu Mar 05, 2020 11:48 pm | |
| We have been using Mobil 1 synthetic. My spouse has a 2010 Can Am Spyder. There is a warning in the service manual about issues with the clutch slipping if using oil with designation api SM. Mobil 1 now has this designation. Has anyone had recent issues with the clutch slipping after an oil change? We are having problems sourcing oil for his trike, as most oils now seem to have this designation. |
Number of posts : 3314 Age : 85 Points : 9467 Registration date : 2009-08-18
| Subject: Re: Oil for Silverwing Fri Mar 06, 2020 6:34 am | |
| First, SilverWing does not have a wet clutch that can slip.
Based on over 90,000 miles with two new SilverWings and no engine trouble---WalMart house brand 10-40 works fine---priced right. |
Number of posts : 2624 Age : 72 Location : Bullhead City, AZ Points : 7515 Registration date : 2012-05-17
| Subject: Re: Oil for Silverwing Fri Mar 06, 2020 7:02 am | |
| As John says there is NO wet clutch to worry about. Use whatever good quality 10W-30 or 10W-40 oil. Mobil One is fine if you care to use it. The Silver Wing is not hard on oil like some dirt bikes so Walmart oil will work or any conventional oil. I usually use Rotella T5 synthetic blend.
The above being said my SWing did not like Rotella T4 15W-40 diesel oil. The only time my scoot used any oil between changes was using this oil. |
Number of posts : 1384 Location : Allentown PA. Points : 4730 Registration date : 2016-01-02
| Subject: Re: Oil for Silverwing Fri Mar 06, 2020 7:58 pm | |
| Mobile makes a great motorcycle oil wet clutch safe but $10 a qt. 10W40 or 20W50. I've been using Mobile one 0W40 European formula for the last few oil changes. Has a higher zink- phosphorus levels than many other car oils. Less engine wear. Viscosity is right there with a 10W at 50-70°F and more like a thin 40W when hot.
Most 10w40 oil don't have friction modifiers that could cause a wet clutch to slip.
Shell also makes some good oils Rotella T6 in 5W40 and 0w40 but I've never seen 0w40 anywhere. Diesel oils. They also make 10W30 semi synthetic.
Stay away from any oil SN rated oil. Reduced zink-phosphorus levels in new oil are to protect cat. converters from damage. It slowly destroys them more so in a engine burning much oil. |
Number of posts : 1999 Age : 78 Location : Princeton, MN Points : 6076 Registration date : 2014-02-13
| Subject: Re: Oil for Silverwing Fri Mar 06, 2020 11:47 pm | |
| This is the oil I've been using: https://www.amsoil.com/shop/by-product/motor-oil/motorcycle/20w-40-synthetic-v-twin-motorcycle-oil/?code=MVIQT-EA
I use Amsoil, but not motorcycle oil in my other vehicles, in all my engines just because I like it. No other special reason. I like it. I use it in my snowblower, lawn mowers, car, pickup and SWing.
But then that's just my choice.
I had a 99 Chevy Silverado with over 245,000 miles on it. I like it especially in the winter because it doesn't thicken like regular oil. And here in Minnesota we do get winter once in a while... |
sc00ter Super Scooter Rider
Number of posts : 232 Location : Norfolk, VA Points : 2575 Registration date : 2018-07-16
| Subject: Re: Oil for Silverwing Sat Mar 07, 2020 12:24 am | |
| My wife had a Can-Am Spyder, I think it to was a 2010. Use the RECOMMENDED oil in the Spyder. Even if you have to buy the oil change "kit" at the dealership, I actually recommend that kit myself. And do the WHOLE change EVERY TIME! Oil and filter at the same time. If you allow the Spyder to start slipping (is yours the semi-auto or normal clutch?) or find any metal "dust" in the oil, prepare for a terror repair bill to service the clutch. As for the Silverwing, I use regular automotive synthetic. |
| Subject: Re: Oil for Silverwing Sat Mar 07, 2020 9:57 am | |
| Ours is the semiautonomous. Thanks for the input. |
| Subject: Re: Oil for Silverwing Sat Mar 07, 2020 9:58 am | |
| I meant semiautomatic. Cursed spell check. |
Dzone Scooter Rider
Number of posts : 10 Location : bulgaria Points : 1628 Registration date : 2020-06-21
| Subject: Re: Oil for Silverwing Mon Jun 22, 2020 2:57 pm | |
| i use Motul 300V 10w50 very good even in hot weather and agressive driving |
steve_h80 Silver Wing Guru
Number of posts : 1037 Location : Teesdale, UK Points : 4232 Registration date : 2016-05-15
| Subject: Re: Oil for Silverwing Tue Jun 23, 2020 4:18 pm | |
| Anything that meets the spec and at periods by the manual. The SW is a simple engine, doesn't rev high & no wet clutch. Anything too expensive is waste of money I reckon. |
Number of posts : 4218 Location : York, North Yorkshire, England UK Points : 9447 Registration date : 2010-11-16
| Subject: Re: Oil for Silverwing Wed Jun 24, 2020 6:30 am | |
| No one seems to mention the oil specs Honda recommend for the Silver Wing, just the viscosity they're using which is usually 10w-40. I started off using 10w-40, then changed to 10w-30. It took quite a bit of label browsing to find a brand that had the correct API service classification of SG or higher, JASO T903 standard and all the rest of it.
To make it easier for myself I had the oil spec in the Notes in my iPhone for reference.
bikerboy Silver Wing Rider
Number of posts : 405 Age : 81 Location : Leyland England Points : 5372 Registration date : 2011-05-12
| Subject: Oil for Silverwing Thu Jun 25, 2020 6:09 am | |
| As Meldrew says the right spec. is important and I also think that frequent changes helps . It doesn't need a lot of oil and running on clean oil helps maintain engine condition . I give all my engines more frequent changes than the service schedule. |
