» Rear wheel valve stem
Not quite an oils question... I_icon_minitimeby MikeO Today at 6:19 pm
Not quite an oils question... I_icon_minitimeby COMick Today at 6:13 pm
Not quite an oils question... I_icon_minitimeby xwelder Today at 12:31 pm
Not quite an oils question... I_icon_minitimeby sonuvabug Yesterday at 4:17 pm
Not quite an oils question... I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Not quite an oils question... I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Not quite an oils question... I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Not quite an oils question... I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Not quite an oils question... I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Not quite an oils question... I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
4 posters
Number of posts : 403
Not quite an oils question... Empty
PostSubject: Not quite an oils question...   Not quite an oils question... I_icon_minitimeFri Jun 12, 2020 6:38 pm
I've looked through the service manual and can't see an answer to this one. With the variator and the driven hub, the CVT parts slide sideways to vary the gearing, but is there any grease that should be applied to the boss, splines or drive/driven pulleys to lube this movement? I do know that grease/oil is verboten on the parts that contact the belt. TIA.
PostSubject: Re: Not quite an oils question...   Not quite an oils question... I_icon_minitimeFri Jun 12, 2020 6:45 pm
Not on the Drive Pulley boss.
There is grease internally in the Driven Pulley to lube the needle and roller bearings as well as a small amount of grease on the Driven Pullet moveable face helix.
PostSubject: Re: Not quite an oils question...   Not quite an oils question... I_icon_minitimeFri Jun 12, 2020 11:17 pm
Thanks for that.
Marvincon
Marvincon
Number of posts : 50
Registration date : 2019-05-06
PostSubject: Re: Not quite an oils question...   Not quite an oils question... I_icon_minitimeSat Jun 13, 2020 2:53 am
https://youtu.be/_IPTRrVtD-8
this video shows the grease being removed and replaced in the driven pulley 'torque controller'
PostSubject: Re: Not quite an oils question...   Not quite an oils question... I_icon_minitimeSat Jun 13, 2020 7:14 am
Thanks Marvincon, looks like some useful videos there.
Number of posts : 1384
PostSubject: Re: Not quite an oils question...   Not quite an oils question... I_icon_minitimeSat Jun 13, 2020 11:34 am
I used Yamaha Polyurea grease to lube the pins and sliders in rear hub. Honda stuff seams next to impossible to find. Housing then needs a 1/8 coating of a good wheel bearing grease in there.. Pins are exposed in the hub where bearings are other grease kind of seals that up. Driven Face.
» Got one...
» Rollers or sliders needed or not?
» Serious Question?
» A big question
» Question - Is it me?
