Unknown part number I_icon_minitimeby sonuvabug Yesterday at 4:19 pm
Unknown part number I_icon_minitimeby sonuvabug Yesterday at 4:17 pm
Unknown part number I_icon_minitimeby sonuvabug Yesterday at 4:06 pm
Unknown part number I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Unknown part number I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Unknown part number I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Unknown part number I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Unknown part number I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Unknown part number I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Unknown part number I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
 Unknown part number
4 posters
John F.
Number of posts : 32
Registration date : 2020-04-19
Unknown part number Empty
PostSubject: Unknown part number   Unknown part number I_icon_minitimeTue Jun 30, 2020 11:45 pm
Hey all, I'm having trouble finding the part number for a spacer found in the left side belt cover. They are found in the holes for the 4 or so bolts. I've checked the schematics and change see them listed.
Thanks!
John
Unknown part number Img_2022
John F.
PostSubject: Re: Unknown part number   Unknown part number I_icon_minitimeTue Jun 30, 2020 11:52 pm
Unknown part number Img_2029Unknown part number Img_2029
Number of posts : 403
PostSubject: Re: Unknown part number   Unknown part number I_icon_minitimeWed Jul 01, 2020 12:55 am
Should be this one if you are talking about the rear-most plastic cover on the final drive.
80108-061-010
https://www.partzilla.com/product/honda/80108-061-010?ref=3c4aba2ff660043f47b71ce65446e68971c85ad4
John F.
PostSubject: Re: Unknown part number   Unknown part number I_icon_minitimeWed Jul 01, 2020 2:47 am
Unfortunately, that isn't the one, Terry. It's similar but the collar I'm looking for goes to the other cover and is a different size, unfortunately.
PostSubject: Re: Unknown part number   Unknown part number I_icon_minitimeWed Jul 01, 2020 4:34 pm
It doesn't look like the inserts that go in the front cover are available separately. I'd suggest you measure one that you have and go to a hardware store and buy some aluminium/aluminum tubing of the right diameter, then cut that to length to suit and glue it in place. The collar's ony function is to stop you from crushing/splitting the plastic cover so there's not much force on it.
Donie
Number of posts : 80
Registration date : 2013-04-07
PostSubject: Re: Unknown part number   Unknown part number I_icon_minitimeWed Jul 01, 2020 4:58 pm
It looks as if the might be held in place by a rubber grommet, and as Terry says their purpose is anti crush to prevent over-tightening the fixing bolt, and breaking the lug on the panel.
Number of posts : 1935
PostSubject: Re: Unknown part number   Unknown part number I_icon_minitimeWed Jul 01, 2020 5:24 pm
Terry Smith wrote:
It doesn't look like the inserts that go in the front cover are available separately. I'd suggest you measure one that you have and go to a hardware store and buy some aluminium/aluminum tubing of the right diameter, then cut that to length to suit and glue it in place. The collars's ony function is to stop you from crushing/splitting the plastic cover so there's not much force on it.
Good thought, too you might visit a good hardware store and check to see if the have bushings close enough in size a little modification would have them fitting the job.
John F.
PostSubject: Re: Unknown part number   Unknown part number I_icon_minitimeThu Jul 02, 2020 5:13 pm
Thanks, fellas. Gonna head to the hardware store with my fingers crossed.
Unknown part number
» Part Number. Final Drive. Drain Bolt Washer
» Hyper springs part number
» Speedbleeder part number SB8125L
» 2009 Swing Oil Filter part Number?
» Part number for rear brake lever switch
