| Techron in my tank | |
+5Billy23 sonuvabug cookkees Dale N. Meldrew 9 posters |
Billy23 Scooter Rider
Number of posts : 15 Age : 83 Location : Corby, Northants UK Points : 1894 Registration date : 2019-09-12
| Subject: Techron in my tank Mon Jul 13, 2020 9:12 am | |
| Hi I haven’t bought it yet but, I thought I would ask the question, how much Techron would I put into the tank? I am guessing that it would not be the whole bottle Just noticed as I tried to order that it is concentrated, is that the one I need? Or perhaps another brand/type? Thank you for any help |
sonuvabug Silver Wing Expert
Number of posts : 930 Location : Mid-Western Ontario Canada Points : 6173 Registration date : 2010-09-15
| Subject: Re: Techron in my tank Mon Jul 13, 2020 10:35 am | |
| Don't know about Techron although it has a good reputation. I use Seafoam and it works really well.
I think it states only an ounce or so per SWing fuel tank volume but I've put in a whole bottle to give the entire fuel system a thorough "hot" cleaning ... no adverse effects. Seafoam can also be used as a fuel stabilizer which I use for winter storage of all of my gas burning machines. |
Number of posts : 4214 Location : York, North Yorkshire, England UK Points : 9419 Registration date : 2010-11-16
| Subject: Re: Techron in my tank Mon Jul 13, 2020 10:56 am | |
| Hello mate, isn't Techron just another fuel system cleaner and additive like Redex that Brits have been using for years. There used to be a lad on here called Old Limey who was a long time user and regularly added a shot of of Redex when he filled up. I bought a four pack of 90ml bottles with a view to adding half a bottle when I filled up, then Old Limey posted he'd stopped using it for some reason which is probably there somewhere in his posts. After that I decided not to use Redex in my Silver Wing, As you haven't bought this Techron yet, why not buy and try a single 90ml bottle of Redex from Halfords or elsewhere first. It may be all you need and it'll be far less to buy than Techron. The only time I used a fuel injector fuel system cleaner was in a BMW K75 RT back in my biking days, and one small bottle was enough to dose two tanks full and it worked after I'd added to the first. Of course on the other side of the Pond I bet someone recommends Seafoam, Gooner Kev imported a can using his Lottery winnings, he might now also be a convert.
Number of posts : 1998 Age : 78 Location : Princeton, MN Points : 6051 Registration date : 2014-02-13
| Subject: Re: Techron in my tank Mon Jul 13, 2020 12:27 pm | |
| I'm one on this side of the Pond who uses Seafoam. I don't use it in the SWing on any sort of regular basis but do add it to the last fill before I put it to bed for the winter. I use about 1/3 of a can, fill up the SWing to mix it up then take it for a shortish spin to circulate it. Then it goes nite nite for the winter unless we get that rare warm day with no snow on the roads.
I do however use Seafoam in my gas can for my snowblower and lawn mowers. It sometimes takes me 2 or 3 years to go through a six gallon can and the Seafoam keeps the gas good until it's used up. I've never had a problem with any of them starting right up and running good. I did have to replace my 30 year old Honda HS55 snowblower last winter. I guess the Seafoam finally killed it... LOL And I only had to change the belts on it once in those 30 years. Spark Plugs and oil on a normal basis tho. I guess that shows the quality of Honda products when taken care of. |
cookkees Scooter Rider
Number of posts : 12 Location : Pittsburgh, PA Points : 1630 Registration date : 2020-06-03
| Subject: Re: Techron in my tank Mon Jul 13, 2020 2:03 pm | |
| Introduced to Seafoam when I acquired the scooter dealership.We put it in every scooter we sold and/or repaired.I regularly use Seafoam in everything I own, cars, scoots, mowers, weed wackers, et al. WalMart has it at $6.97....cheap insurance. 1 ounce to the gallon.
| Subject: Re: Techron in my tank Mon Jul 13, 2020 2:07 pm | |
| - Meldrew wrote:
- ... snipped ... Of course on the other side of the Pond I bet someone recommends Seafoam, Gooner Kev imported a can using his Lottery winnings, he might now also be a convert.
I take it Seafoam is not readily available in the UK and costs a small fortune to import it in. I didn't know this. |
| Subject: Re: Techron in my tank Mon Jul 13, 2020 2:18 pm | |
| - Meldrew wrote:
- Hello mate, isn't Techron just another fuel system cleaner and additive like Redex that Brits have been using for years.
Of course on the other side of the Pond I bet someone recommends Seafoam, Gooner Kev imported a can using his Lottery winnings, he might now also be a convert. Hi Meldrew Yes good idea, I am only thinking of using it as my fuel gauge has stopped working, I think the previous owner stood the bike up for a long while and the sender has perhaps gunged up. I read on the forum some place that a dose of cleaner might “ un stick it” so I thought I would try it. Off to Halfords tomorrow. Thanks for your advice. Bill |
Number of posts : 4415 Age : 81 Location : damn near Philadelphia, PA Points : 10722 Registration date : 2009-06-12
| Subject: Re: Techron in my tank Mon Jul 13, 2020 2:56 pm | |
| - Billy23 wrote:
I am only thinking of using it as my fuel gauge has stopped working, I think the previous owner stood the bike up for a long while and the sender has perhaps gunged up. I read on the forum some place that a dose of cleaner might “ un stick it” so I thought I would try it. You’ll probably need more than just “a dose”. Best suggestion is to use a full can with the next fill up. The longer you let the scoot rest before using that 1st treatment the better chance it will have to attack that varnish & gunk. Then 1/2 can in each of the next 4 fill ups. |
Number of posts : 1935 Location : Hocking Hills U.S.A. Points : 5336 Registration date : 2016-01-29
| Subject: Re: Techron in my tank Mon Jul 13, 2020 9:05 pm | |
| Important words on the bottle, up to. As Tim said put the entire contents in, at least the 1st time. |
| Subject: Re: Techron in my tank Tue Jul 14, 2020 2:48 am | |
| Techron recommends for motorcycles to tip the contents of the bottle in a near empty tank before filling up. When I posted earlier Bill hadn’t mentioned that his fuel gauge had stopped working. These additives are more commonly used to clean fuel systems and fuel injectors. Whether Techron, Redex, Seafoam etc, will also cure a fuel gauge fault I've no idea. However I've dug out my FSM and looked at the Fuel Unit in the Lights/Meters/Switches section to see what it says about the fuel level indicator not indicating property. It has two paragraphs, System Inspection, and Float Level Sensor Inspection. The System Inspection involves disconnecting the fuel unit connector and shorting terminals with a jumper wire to check. The Float Level Sensor Inspecton involves removing the fuel pump/unit and measuring resistance. So maybe dosing a tank of fuel with any of these wonder additives in the hope of clearing this fault isn't the way to go. Here's hoping it does. |
Lenny Scooter Rider
Number of posts : 36 Location : Uk Points : 1915 Registration date : 2019-09-08
| Subject: Re: Techron in my tank Tue Jul 14, 2020 3:56 am | |
| What might be worth a try with a low level of fuel is to vigorously move the bike from left to right which may release the float. Vigorously moving a Silverwing from left to right is another matter |
| Subject: Re: Techron in my tank Sun Jul 19, 2020 4:17 pm | |
| Thanks guys for the help on this. I agree that the “Cleaner” may not help my stuck fuel gauge but, getting the float out of the tank and changing it seems to be soooo much hassle, I thought I would give it a go.........and pray :-) Haven’t had time up to now but tomorrow is the day. Wish me luck |
Qwazert Scooter Rider
Number of posts : 6 Location : BC Canada Points : 1502 Registration date : 2020-09-29
| Subject: Re: Techron in my tank Tue Sep 29, 2020 10:46 am | |
| For those who can't buy Seafoam where they live...there are several different "recipes" available on the web. Unfortunately, because I am a NEW member...I can't post links yet. Google is your friend.
| Subject: Re: Techron in my tank Tue Sep 29, 2020 1:31 pm | |
| Here is a link to “recipes” for several of the more popular fuel tank additives. If you’ve found a DIY recipe for Techron please post. |
