| centerstand and rear wheel | |
frossa Scooter Rider
Number of posts : 3 Location : Trumbull,CT Points : 1587 Registration date : 2020-07-21
| Subject: centerstand and rear wheel Fri Jul 31, 2020 1:28 am | |
| New to the Swing. When my bike is on the centerstand the rear wheel is not off the ground. Is this correct and if not what should I look for. Thanx, Fred |
| Subject: Re: centerstand and rear wheel Fri Jul 31, 2020 1:33 am | |
| Possibly aftermarket rear shocks. Hagon shocks are longer than OEM shocks. Or possibly a car tire on the rear. What size rear tire do you have? |
Number of posts : 1013 Age : 74 Location : HI Points : 4346 Registration date : 2015-12-19
| Subject: Re: centerstand and rear wheel Fri Jul 31, 2020 8:00 pm | |
| Maybe the previous owner shortened the stand to make it easier to get the bike up on the center stand. |
| Subject: Re: centerstand and rear wheel Fri Jul 31, 2020 11:23 pm | |
| Maybe stand is bent from somebody too fat sitting on parked bike? |
Terry Smith Silver Wing Rider
| Subject: Re: centerstand and rear wheel Fri Jul 31, 2020 11:56 pm | |
| I've got Hagon shocks and a new tyre and there not much clearance between the floor and the tyre on the stand, but the wheel spins freely.
To the OP, are you sure your stand is not sitting in a depression? If not, stick a piece of wood under the stand feet before you use it to lift the bike higher. |
| Subject: Re: centerstand and rear wheel Sat Aug 01, 2020 1:08 am | |
| It seems you've answered your own question in your Introduction. You stated that the center stand was bent when you got it.
Please let us know how you sort this out. We all benefit from shared information.
Last edited by Cosmic_Jumper on Sat Aug 01, 2020 12:40 pm; edited 1 time in total |
| Subject: Re: centerstand and rear wheel Sat Aug 01, 2020 1:52 am | |
| Stand lifting arm was bent. Seems the original owner just tried to put it on the stand by standing on the "lifting arm" ownly. did not pull back on the bars or lift the rear at all, or had the parking brake on. |
| Subject: Re: centerstand and rear wheel Sat Aug 01, 2020 1:56 pm | |
| Quite probably bent more than meets the eye. |
| Subject: Re: centerstand and rear wheel Sat Aug 01, 2020 9:05 pm | |
| Like other parts from the 1500 Gold Wing any chance that the centerstand would work? |
| Subject: Re: centerstand and rear wheel Sat Aug 01, 2020 9:29 pm | |
| Center stand on eBay.
https://www.ebay.com/itm/03-Honda-FSC600-FSC-600-Silverwing-Scooter-Centerstand-Center-Stand-with-Spring/312637596099?hash=item48caa721c3:g:bBIAAOSw3Ftc8o7y |
