Performance changes I_icon_minitimeby zrx212 Yesterday at 4:40 pm
Performance changes I_icon_minitimeby Meldrew Yesterday at 4:37 pm
Performance changes I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Performance changes I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Performance changes I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Performance changes I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Performance changes I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Performance changes I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Performance changes I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Performance changes I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
 Performance changes
ARC582
Number of posts : 8
Performance changes Empty
PostSubject: Performance changes   Performance changes I_icon_minitimeThu Sep 10, 2020 9:30 pm
Very pleased with the Swing’s mods. No data needed. It is much quicker without any sacrifice at cruising speeds, RPM’s, etc. and will still easily blip past 100mph. And if anyone tells you not to change your clutch springs.... I beg to differ. 🚦🛵
On the DynoTune PC I simply used the US map from 0-3750 RPM (it’s richer) then the Euro race exhaust map from 4000-8200RPM(it’s also richer). Had a little cold start 3 tries issue so I went in map at zero throttle position and installed 1’s at 800, 900, 1000 RPM’s. Fires first bump of the starter when cold or hot. Run’s great.
Mod’s so far-
65lbs weight savings from removing trunk, rack, foot pegs, stock muff, stock air box, side cover plastics, handlebar cover, parking brake caliper, shortened rear fender, cut windshield shorter, and installed lightweight 420cca lithium battery.
DynoTune PC
Malossi variator w/ 24g rollers
Delkevic slip-on muff (No cat)
Uni-Pod filter
White torque spring
Yellow clutch springs (3000 RPM engage vs. 2k)
Lithium battery
Performance changes
