driven face boss inner surface I_icon_minitimeby zrx212 Yesterday at 4:40 pm
driven face boss inner surface I_icon_minitimeby Meldrew Yesterday at 4:37 pm
driven face boss inner surface I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
driven face boss inner surface I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
driven face boss inner surface I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
driven face boss inner surface I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
driven face boss inner surface I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
driven face boss inner surface I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
driven face boss inner surface I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
driven face boss inner surface I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
Lenny
winged warrior
winged warrior
winged warrior
Number of posts : 51
driven face boss inner surface Empty
PostSubject: driven face boss inner surface   driven face boss inner surface I_icon_minitimeSun Dec 20, 2020 1:50 pm
Hey guys,
I am changing my belt, and am intending to put new oem rollers in as I am over 100 000 km and have never looked in there.
The manual (page 1-18 near the bottom) says that the driven face boss inner surface needs lithium based grease - I am about to not do anything beyond the belt as I am not sure if I do have to grease anything - or where to apply - I get the impression that everything gets put back together, don't put grease on it (from videos and tutorials)
It also says the movable driven face cam groove needs grease - I'm not sure what that is - is it connected to the pully drive?
Finally when I am putting all the bolts back on the drive pully cover, is it ok to put some engine oil on them?
Anyway, just want to do it right the first time, the Honda Dealership is closed indefinitately near me.
All the best and thanks for any suggestions you can send my way (:
Kevin
Lenny
Number of posts : 36
Registration date : 2019-09-08
PostSubject: Re: driven face boss inner surface   driven face boss inner surface I_icon_minitimeSun Dec 20, 2020 2:15 pm
https://youtu.be/82MUIwzfCPo
PostSubject: Re: driven face boss inner surface   driven face boss inner surface I_icon_minitimeSun Dec 20, 2020 3:44 pm
Perhaps you're confusing the Drive Pulley, aka
variator (the front pulley which Is attached to the crankshaft and which holds the roller weights) with the Driven Pulley, which has the clutch attached and also has the big torque spring as shown on the above video. No grease on the variator pulley weights (but you can use a dry, Teflon based spray lube like PBlaster with Teflon). The Driven Pulley needle bearing could use a kiss of grease though.
Drive Pulley vs Driven Pulley.
winged warrior
winged warrior
PostSubject: Re: driven face boss inner surface   driven face boss inner surface I_icon_minitimeSun Dec 20, 2020 4:06 pm
Thanks Tim, got it! Lenny that is a great video, really shows the steps. I can't imagine I'll ever work on the spring pully but it's good to know.
Much appreciated.
Number of posts : 1384
PostSubject: Re: driven face boss inner surface   driven face boss inner surface I_icon_minitimeSun Dec 20, 2020 8:17 pm
Variator bolt needs a drop of oil on threads before torqueing. Outer belt cover bolts don't need any oil on threads.
Guy on video could have gotten more grease in driven pulley outer face by filling it around edges and then sliding it over and wiping whatever came out. There is some space in there that he didn't fill. That's how I did it anyway.
winged warrior
winged warrior
PostSubject: Re: driven face boss inner surface   driven face boss inner surface I_icon_minitimeTue Dec 29, 2020 3:10 pm
Thank you for your advice and help, there was a lot of stuff in the drive pully area, I cleaned it all out and replaced the rollers, they were covered in material - worn out, and wiped everything down with brake cleaner.  At first I torqued the variator only to 26 pounds per square inch (I always do something wrong) then realized my mistake and took it a part, re cleaned and torqued it to 76 pb/sp ft.
the foam filter was disgusting but intact, so I washed and thorougly dried that.
The belt drive now makes a sound that could be taken as a joyful lament from days of yore, but the engine and everything else sounds great, the ride feels good - this was the first time I've done this (aside from having belt changes every 30 000 km by Honda) - it really needed a cleanout and am grateful  for the support here.
Oldschool
Number of posts : 5
Registration date : 2021-02-09
PostSubject: Re: driven face boss inner surface   driven face boss inner surface I_icon_minitimeWed Feb 10, 2021 2:54 pm
If you are sure that the belt is running in the right direction, i believe that noise is going to disappear in the first few miles.
Happened to me.
Cheers.
JamieB
JamieB
Number of posts : 224
PostSubject: Re: driven face boss inner surface   driven face boss inner surface I_icon_minitimeThu Feb 11, 2021 3:00 pm
It took me longer to put the cover bolts back in than to do the roller swap, but I did get it slightly wrong, so many bolts!
Number of posts : 1935
PostSubject: Re: driven face boss inner surface   driven face boss inner surface I_icon_minitimeThu Feb 11, 2021 3:04 pm
I either use small plastic cup with a " where it goes " note or my newer system, a piece of stiff card board with the hole it goes in noted, remove the bolt press it thru and now when you or someone else gets back to the project there's no doubt.
JamieB
JamieB
PostSubject: Re: driven face boss inner surface   driven face boss inner surface I_icon_minitimeThu Feb 11, 2021 3:06 pm
Yes, great idea, that’s exactly what I should have done.
Spark plugs being swapped this weekend.
» Drive Face Boss
» Driven Face Scraping Noise
» Boss Audio Speaker System Install
» Repairing surface scratches
» Wheel assy.surface finish
