spanishfudge Scooter Rider
Number of posts : 25 Age : 62 Location : Antas, Almeria, Spain Points : 2203 Registration date : 2018-12-21
| Subject: Dr pulley sliders Fri Jan 22, 2021 6:37 am | |
| just seen a set of dr pully rollers for a silverwing 400 the size is 28 20 24 are these ok to fit on a 600 wing would like to fit as here say this is a good roller |
| Subject: Re: Dr pulley sliders Fri Jan 22, 2021 7:59 am | |
| Variator weights from 400cc and 600 cc Silverwings are interchangeable.
28x20 is the dimension of the rollers. That would be for original Honda, as well as Malossi or Polini roller weights or for Dr Pulley sliding weights. The original rollers weigh 28gm.
So lighter 24gm weights (either in the form of roller weights or sliding weights) will be a nice improvement over the original weights. If they are Dr Pulley sliders just insure that they are installed correctly. |
| Subject: Re: Dr pulley sliders Fri Jan 22, 2021 10:29 am | |
- Variator weights from 400cc and 600 cc Silverwings are interchangeable.
So lighter 24gm weights (either in the form of roller weights or sliding weights) will be a nice improvement over the original weights. If they are Dr Pulley sliders just insure that they are installed correctly. thank you Cosmic ,will try them out cheers and happy new year to you and all |
