Number of posts : 25 Location : Oklahoma Points : 1639 Registration date : 2020-06-13
Subject: Tends to go left Fri Mar 19, 2021 5:27 pm
Question:
With the SW's front wheel raised in preparation to replace the fork oil, it swings —and fully stays— to the left. Even if turned fully back to the right, it immediately turns back to the left. Can anyone speak to this matter? Thanks.
JamieB Super Scooter Rider
Number of posts : 224 Age : 47 Location : North West UK Points : 5346 Registration date : 2011-02-01
Subject: Re: Tends to go left Fri Mar 19, 2021 5:43 pm
Has someone honestly asked this question!
Number of posts : 1384 Location : Allentown PA. Points : 4706 Registration date : 2016-01-02
Subject: Re: Tends to go left Fri Mar 19, 2021 6:01 pm
Now if you were below the equator it would be the opposite. Most likely the weigh of brake caliper or some cable, hose pulling don't worry about it. Who knows as long as everything is tight. Mine does the same thing.
Number of posts : 1604 Age : 62 Location : South East England Points : 4731 Registration date : 2016-10-01
Subject: Re: Tends to go left Fri Mar 19, 2021 6:06 pm
It's gravity at work. The left hand side of the forks is heavier than the right side.
I find it very irritating when I'm working on the front end but there it is.
BroOKS2K9 Scooter Rider
Subject: Re: Tends to go left Sat Mar 20, 2021 9:51 am
Great! Thanks to all who replied. ...won't think another moment about it.
Number of posts : 1013 Age : 74 Location : HI Points : 4328 Registration date : 2015-12-18
Subject: Re: Tends to go left Sat Mar 20, 2021 3:09 pm
How many miles are on your Swing? There is a procedure to set the head bearing pre-load. You would need a fishing like scale. You measure a set amount pounds to turn the front wheel.
My 2002 Swing's head bearing had indents on the race from the ball bearings. Indents are normally created at the straight forward steering position.
