More Torque Settings Left Rear Cover I_icon_minitimeby zrx212 Yesterday at 4:40 pm
More Torque Settings Left Rear Cover I_icon_minitimeby Meldrew Yesterday at 4:37 pm
More Torque Settings Left Rear Cover I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
More Torque Settings Left Rear Cover I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
More Torque Settings Left Rear Cover I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
More Torque Settings Left Rear Cover I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
More Torque Settings Left Rear Cover I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
More Torque Settings Left Rear Cover I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
More Torque Settings Left Rear Cover I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
More Torque Settings Left Rear Cover I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
3 posters
Number of posts : 1606
More Torque Settings Left Rear Cover Empty
PostSubject: More Torque Settings Left Rear Cover   More Torque Settings Left Rear Cover I_icon_minitimeSat Mar 20, 2021 3:51 pm
Does anybody have the torque settings for the left rear (crankcase) cover?
There are the three large bolts around the bearing area and then the small 8mm bolts around the edge of the cover, and one in the middle.
I can't find the torque settings in the manual.
Thanks
Number of posts : 1384
PostSubject: Re: More Torque Settings Left Rear Cover   More Torque Settings Left Rear Cover I_icon_minitimeSat Mar 20, 2021 4:53 pm
Outer belt cover Right? 6MM bolts 10MM head 7-9lbf-ft . 8MM bolts 12MM head 16-20lbf-ft manual is confusing Page 1-11 at the top. Fastener types are different.
Number of posts : 580
PostSubject: Re: More Torque Settings Left Rear Cover   More Torque Settings Left Rear Cover I_icon_minitimeSat Mar 20, 2021 5:20 pm
Are you talking about final gearbox cover ?, std torque for 8mm low tension(reduced head or allen)) bolts is 22NM/16ft/lbs, high tension(built in flange/washer) 26NM/20ft/lbs, see SW shop manual 1-11. I usually do 24NM/18ft/lbs on most 8MM bolts.
PostSubject: Re: More Torque Settings Left Rear Cover   More Torque Settings Left Rear Cover I_icon_minitimeSun Mar 21, 2021 5:52 am
Very useful info above, thanks. The manual is confusing I agree. I'm talking about the aluminium 'pulleys and belt' cover. There are three larger bolts around the rear pulley shaft bearing housing and then the smaller bolts around the edge of the casing plus the one in the middle, nicely hidden! (For simple reference, I usually call the bolt size by its head size rather than the stem thickness or thread pitch).
One more thought. Do the bolts have to be secured in a particular sequence to prevent distortion?
PostSubject: Re: More Torque Settings Left Rear Cover   More Torque Settings Left Rear Cover I_icon_minitimeSun Mar 21, 2021 9:54 am
 This is mostly a PSA, As a general rule any panel or cover having multiple fasteners should be tigthened  from center out in a criss/cross pattern, but mostly applies to large contact area surfaces, this particular cover(belt cover) is a very robust part and it's aligned by dowel pins, don't believe it will migrate/slide any when torqued, honestly as this is considered a service cover and will get removed more often, I would stay in the low range of torque range to prevent thread damage in the long run, so 10nm(7ft/lbs) for 6mm and 22nm(16ft/lbs) for 8mm should be good IMO, install the bolts finger tight and then torque, Just make sure your bolt and case threads are clean/oil free for true torque reading. I like to do sharpie marker stripes(witness marks) on larger bolts JIC I don't have a torque wrench handy at some point. BTW don't use any loctite, etc. on regular service bolts.
PostSubject: Re: More Torque Settings Left Rear Cover   More Torque Settings Left Rear Cover I_icon_minitimeSun Mar 21, 2021 2:27 pm
This is the kind of stuff I need to know. Thanks. It's worth knowing a little of the science involved with this stuff. I will think of nuts and bolts in a different way from now on. The sharpie marks are a good idea too.
I suspect I've been a bit heavy-handed in the past so here's to new philosophy Cool
» Left Rear Cover Removal - Pictorial (Main Fuse Access)
» torque settings
» torque settings help
» Torque settings
» Rear shock settings
