Fork spring direction I_icon_minitimeby sonuvabug Today at 5:19 pm
Fork spring direction I_icon_minitimeby sonuvabug Today at 5:17 pm
Fork spring direction I_icon_minitimeby sonuvabug Today at 5:06 pm
Fork spring direction I_icon_minitimeby JohnyC Yesterday at 11:04 am
Fork spring direction I_icon_minitimeby john grinsel Mon Nov 18, 2024 8:50 am
Fork spring direction I_icon_minitimeby Meldrew Sat Nov 16, 2024 5:37 pm
Fork spring direction I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 7:05 pm
Fork spring direction I_icon_minitimeby terryweasely Wed Nov 13, 2024 11:48 pm
Fork spring direction I_icon_minitimeby AldusFran Mon Nov 11, 2024 10:21 am
Fork spring direction I_icon_minitimeby landisr Sat Nov 09, 2024 1:46 pm
BroOKS2K9
8 posters
BroOKS2K9
Number of posts : 25
Registration date : 2020-06-13
Fork spring direction Empty
PostSubject: Fork spring direction   Fork spring direction I_icon_minitimeMon Apr 19, 2021 3:49 pm
If the following is detailed in another topic/post, please direct me to it. Thanks in advance.
Having just hit 16K --and not sure what the previous owner may have done maintenance wise-- I did the service: replaced belt and spark plugs, engine oil/filter, air filter, fork oil, new dust seals/covers and had front wheel balanced (as there were no weights on it at all). ...even cleaned all the brown "snot" from the breather tube. Yuck!!! But man is she wicked fast now! 0-50 in mere seconds.
Can someone explain why I suddenly have a front wheel wobble? If I let go of the handlebars, anything below 40mph produces serious wobbles. Any ideas?
On page 14-16 of the 2002-2013 service manual, it show a picture of the fork spring with the caption "facing up" pointing to the right near the smaller/closer coils. From what I've gathered via manual (and YT videos), the smaller/closer coils are to be at the base/bottom of the fork. Correct? What would likely be the result if springs were inverted?
Desperate for an answer as I'm desperate to ride. And so is my 11 yo daughter. Smile
PostSubject: Re: Fork spring direction   Fork spring direction I_icon_minitimeTue Apr 20, 2021 8:51 am
BroOKS2K9 wrote:
(Snip)
(Snip)
I’ve split the “front wheel wobble” discussion to its own topic.
Number of posts : 1607
PostSubject: Re: Fork spring direction   Fork spring direction I_icon_minitimeWed Jun 01, 2022 4:35 pm
This has nothing to do with 'wobble'. I'm just about to rebuild my front forks and I too am confused about which way up the springs should go.
As BroOK2K9 mentions above, the YT videos suggest having the closer wound coil end at the bottom. This is supposed to absorb the hard impacts and allow the rest of the spring to soften things out as the shock travels upwards. My springs are within the manual tolerance and look to be in good order.
Could the manual be wrong?
Number of posts : 1013
PostSubject: Re: Fork spring direction   Fork spring direction I_icon_minitimeThu Jun 02, 2022 4:28 am
BroOKS2K9 wrote:
(Snip)
(Snip)
Where is the split post? I do not see it on the left side?
Number of posts : 3837
PostSubject: Re: Fork spring direction   Fork spring direction I_icon_minitimeThu Jun 02, 2022 4:48 am
PostSubject: Re: Fork spring direction   Fork spring direction I_icon_minitimeThu Jun 02, 2022 5:01 am
Well, I've been reading about springs and orientation from all kinds of sources and it seems that there is no answer. Different bikes seem to have progressive springs fitted in different ways. Some people have also claimed that their manual is wrong. Others, who have a more scientific understanding of how springs work, suggest the tighter coil should be at the bottom.
From my own simplistic view, I reckon that, as the SW has the small rebound spring at the bottom of the piston, I'm going with the manual and put the tighter wound end at the top. I can't wait to try it out; if I ever get the free time to put the front end back together. This job is turning out to be quite an adventure...and not a pleasant one Mad
Number of posts : 403
PostSubject: Re: Fork spring direction   Fork spring direction I_icon_minitimeFri Jun 03, 2022 1:05 am
Something not always considered in the fork spring debate is where the spring bears on the other fork parts; take a look at the top of the damper rod and the washer/spacer on top of the spring, and you may find the orientation becomes more logical.
If in doubt, follow the manual. It says tightly wound end up. From a spring perspective it doesn't matter; its being compressed and will provide the same resistance irrespective of which way up you install it.
Marvincon
Marvincon
Number of posts : 50
Registration date : 2019-05-06
PostSubject: Re: Fork spring direction   Fork spring direction I_icon_minitimeSat Jun 04, 2022 12:26 pm
https://youtu.be/9-2xt7PV_hA
This fella did an experiment on fork spring direction. From 7 minutes in.
terrier
terrier
Number of posts : 302
PostSubject: Re: Fork spring direction   Fork spring direction I_icon_minitimeSun Jun 05, 2022 6:34 am
Here's another interesting one https://www.youtube.com/watch?v=62wnr6Q_qaM
PostSubject: Re: Fork spring direction   Fork spring direction I_icon_minitimeSun Jun 05, 2022 3:59 pm
I suppose Honda had to tell us to put the springs in one way or the other, so by saying 'tight coil upwards', it means we'll at least install them the same each side.
It was Del-Boy who ******* convinced me jawdrop
» Front Fork Spring
» hyperpro fork spring oil level
» Hyperpro fork spring kit - is it worth it
» Fork Rebuild and Hyperpro Spring Installation
» Fork spring spacer and head race service/replacement
