New Battery Recommendations I_icon_minitimeby sonuvabug Today at 4:19 pm
New Battery Recommendations I_icon_minitimeby sonuvabug Today at 4:17 pm
New Battery Recommendations I_icon_minitimeby sonuvabug Today at 4:06 pm
New Battery Recommendations I_icon_minitimeby JohnyC Yesterday at 10:04 am
New Battery Recommendations I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
New Battery Recommendations I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
New Battery Recommendations I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
New Battery Recommendations I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
New Battery Recommendations I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
New Battery Recommendations I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Jamesy
Brian Goobacheck
12 posters
Brian Goobacheck
Number of posts : 9
Registration date : 2021-10-24
New Battery Recommendations Empty
PostSubject: New Battery Recommendations   New Battery Recommendations I_icon_minitimeFri Dec 17, 2021 10:08 pm
Hey gang,
I have an old Batteries Plus battery in the girl and I wanted something potentially with a high CCA, made in the USA and won't just drain to nothing after sitting for a month. Perhaps I ask too much, and if so, please tell me to move along. But any recommendations would be appreciated as it's a pain to jump the poor girl so early in the morn in the cold. We're both doing our best! Thanks!
Number of posts : 3314
PostSubject: Re: New Battery Recommendations   New Battery Recommendations I_icon_minitimeSat Dec 18, 2021 2:01 am
I would buy OEM battery---ride everyday and this = no trouble for the 2-3 year life of battery. AND no electric sucking accessories. With no kick starter/fuel injection/ ability to bump start and bike is old fresh battery pays!
Number of posts : 1037
PostSubject: Re: New Battery Recommendations   New Battery Recommendations I_icon_minitimeSat Dec 18, 2021 2:57 am
It's worth investing in one of those small battery keeping jump starters if you worry about batteries.
And good luck with finding anything like a battery made in the west these days...
Jamesy
Jamesy
Number of posts : 13
Registration date : 2021-05-23
PostSubject: Re: New Battery Recommendations   New Battery Recommendations I_icon_minitimeSat Dec 18, 2021 6:22 am
OEM Yuasa batteries are the best. However other decent batteries can be had for half the price. I just keep mine connected to an Oxford Optimiser trickle charger through the winter months as if the Swing is left standing for a week or so between rides in my cold lean to, the battery will drain it’s charge as with most motorcycle batteries.
Number of posts : 2622
PostSubject: Re: New Battery Recommendations   New Battery Recommendations I_icon_minitimeSat Dec 18, 2021 6:59 am
I am cheap... Yuasa generally cost over $100.00 USD. Nothing wrong with them but I have used and will continue to use:
https://www.batterysharks.com/Yuasa-YTZ12S-p/YTZ12S_M12-11-210-K.htm?gclid=CjwKCAjwxILdBRBqEiwAHL2R8xPha3cBRPxJ6DyOJ2fsUA-DYTbGZdipcSrpzJBGm3nQpcN-N6vsihoCnKEQAvD_BwE
Been using them for years with no problems and have new ones in both my Wing and my Forza. Living in the desert I generally replace them at 2-3 year intervals. Actually I could replace once a year and still be cheaper than OEM!
My Forza is in the frozen north atm but is on a Battery Tender and should be fine. Good luck with whatever you decide.
Number of posts : 580
PostSubject: Re: New Battery Recommendations   New Battery Recommendations I_icon_minitimeSat Dec 18, 2021 7:23 am
Historically the oem Yuasa batteries that came with bikes from Japan where the best quality, IOW JDM products, 5-10yrs life was not uncommon, nowdays not so much, US made Yuasa batteries IME are no better than top quality offerings from BBAP(Big Box Auto Parts) or batteries plus, etc. and easier to get+warranty as they are close by. IAC there's some parasitic battery drain on the SW600 from clock/odometer/etc.(as most newer vehicles) plus batteries will naturally loose charge over time, a trickle charger is the easiest solution IMO.
You can start/ridebike once a month, but running less than 10- 15minutes will do more harm than good to engine in general, BTW never jump start a scooter/bike from a running car, could damage charging system
New Battery Recommendations YH5BAEAAAAALAAAAAABAAEAAAIBRAA7
BTW lots of guys run a YTZ14(more capacity/amperage) on SW600 instead of spec YTZ12, no issues with fit, etc.
PostSubject: Re: New Battery Recommendations   New Battery Recommendations I_icon_minitimeSat Dec 18, 2021 8:14 am
Everyday riding is the solution to no battery trouble!!
Number of posts : 1935
PostSubject: Re: New Battery Recommendations   New Battery Recommendations I_icon_minitimeSat Dec 18, 2021 9:21 am
I'm liking my Lithium Ion battery a lot, even when it has been setting around when I plug in the battery tender it shows steady green full charge in less than 15 min. All told I have 5 Lithium batteries I use and an still amazed at their life span.
Number of posts : 1013
PostSubject: Re: New Battery Recommendations   New Battery Recommendations I_icon_minitimeSat Dec 18, 2021 3:23 pm
I got a lithium battery for my Swing and It did not do well because of the constant parasitic draw, especially if you have an alarm system. My new Shorai battery would not last four days sitting idle. Will not start the bike. Clock, and trip meters will reset. Shorai tech confirmed that lithium batteries will not hold a charge for more than a few days depending on the amount of electrical requirements when the ignition is off.  He recommended their battery tender. My other gel batteries used to last two weeks without any problems. It will hold a charge for months if disconnected. After three years I ended up replacing that battery with a AGM type battery.
Number of posts : 1384
PostSubject: Re: New Battery Recommendations   New Battery Recommendations I_icon_minitimeSat Dec 18, 2021 4:33 pm
YTZ14 is for the Honda ST1300 and has 20 or so more CCA and it does fit. Buy a fresh one and you should have no issues.
Number of posts : 933
PostSubject: Re: New Battery Recommendations   New Battery Recommendations I_icon_minitimeSun Dec 19, 2021 10:39 am
I upgrade our Silver Wing and Burgman 400 batteries to the YTZ14 size when they are due.  You'll see by the chart below on Page 6, the dimensions are identical between the YTZ12 and YTZ14.  Like Mech1twa says, 20 more CCA in the YTZ14 and only slightly heavier which you'll never feel.
http://www.yuasabatteries.com/wp-content/uploads/2020/01/2020_Application_Guide_File.pdf
johnd
Number of posts : 544
PostSubject: Re: New Battery Recommendations   New Battery Recommendations I_icon_minitimeMon Dec 20, 2021 11:21 am
My last battery only lasted 2 years. (cheep) Then I bought the TPE lithium LiFePO 4 300 cca. with smart battery management, what ever that is. I was amazed at how much lighter it was compaired to all my others and even though I ride almost every day, has not given any signs of getting tired going on 1 year. If it last 3 I will be very happy.
PostSubject: Re: New Battery Recommendations   New Battery Recommendations I_icon_minitimeMon Dec 20, 2021 5:53 pm
4 Years on mine so far, once a month I put the Battery Tender on it, float occurs fast.
Number of posts : 1999
PostSubject: Re: New Battery Recommendations   New Battery Recommendations I_icon_minitimeFri Dec 24, 2021 9:29 am
New Battery Recommendations Li_bat16
New Battery Recommendations Li_bat17
The battery on the right is the first one I ordered off Ebay when I first got my SWing. The Lithium Ion on the left is what's been in my SWing after the first year when the cheapie on the right died. It only cost $25 so no big deal. The Lithium Ion has been working great for the last 5 years with no problems. During the winter I put it on the Deltran Battery Tender about once a month to keep it charged. A couple months ago I ordered a new one, not because the old one is going bad but just to be on the safe side. It's all charged up and ready to install. So now I'll be set for another 5-6 years...
I'll just bet you can't guess where the Golden Dragon battery came from. LOL
johnd
PostSubject: Re: New Battery Recommendations   New Battery Recommendations I_icon_minitimeFri Dec 24, 2021 9:32 am
Good choices of batteries. Happy holidays
PostSubject: Re: New Battery Recommendations   New Battery Recommendations I_icon_minitimeFri Dec 24, 2021 12:35 pm
" I'll just bet you can't guess where the Golden Dragon battery came from. LOL "
 The same place as the "Battery Tender" since aprox. 80% of lithium batteries come from Chi**, Taiw**, etc. and since most of their products are made in Asia, check year 1996 !!, Deltran is based in Deland, Fl over 50yrs, now partners/owned by Lowe's companies(The Home Center)
https://www.deltran-global.com/company
» Recommendations for tires battery and helmuts
» Oil filter recommendations/ Fram 6017A cut open
» Tire recommendations
» Suspension help / recommendations
» Recommendations on Maintenance
