zrx212 Silver Wing Expert
| Subject: Re: Stator (Alternator) oil seal leak Mon Dec 20, 2021 7:51 pm | |
| " Also, the lower half of the engine gets oily, so the oil seal on the alternator side must be the cause? Is there another place from where the engine sweats oil? "
There's several areas that can leak oil historically on Silverwing, oil filter, oil drain plug, oil press. sensor, water pump O rings, but the alternator stator wires rubber seal block at front area of right crankcase cover is fairly common, sometimes you can clean exterior of this seal with plastic safe solvent or alcohol, etc, and coat area with god quality RTV sealant like Permatex ultra black, etc, let dry 24 hours. Otherwise there's a more involved/permanent fix, search for it. |
efinglada Scooter Rider
Number of posts : 29 Location : Madrid, Spain Points : 1771 Registration date : 2020-02-12
| Subject: Re: Stator (Alternator) oil seal leak Tue Dec 21, 2021 7:51 am | |
| Hi ZRX, It must be the alternaror cables rubber seal, everyting else seems clean Thanks a lot
| Subject: Re: Stator (Alternator) oil seal leak Tue Dec 21, 2021 1:05 pm | |
| I have the same problem. I top up a small amount of oil from time to time and clean the underside.
I might get around to fixing it someday! |
Terry Smith Silver Wing Rider
| Subject: Re: Stator (Alternator) oil seal leak Tue Dec 21, 2021 6:20 pm | |
| Subject: Re: Stator (Alternator) oil seal leak Wed Dec 22, 2021 1:27 pm | |
| Thanks Terry, and Mech1, very good information!. It is nice to know in advance where to look
I am quite sure that the oil leak on the right side comes from the alternator and spreads down to the oil pan
Fixing the oil leaks will be my New Year's resolution!
Happy Christmas!
Eduardo |
| Subject: Stator (Alternator) oil seal leak Wed Dec 22, 2021 1:40 pm | |
| It's always great to have pictures of the 'real thing' here on the forum. I like to know what I'm going to find when I go rummaging. Time to get mine fixed..me thinks! |
