Subject: Tupperware repair Tue May 03, 2022 9:29 am
Dude, you can build new tabs and connectors using the Plast-Aid kit. It comes with a piece of flexible silicone that you use to take/make an impression of a "good tab", then you use it as a mould to create new tabs etc.
I've tried their approach and it works. The tough part is positioning/fitting the newly constructed tab back into the same place with the right angles where the old tab broke off. Check Windy Urtnowski's YouTube channel. I think he demonstrates how to do this in one of his many videos. Sorry I don't remember which one.
Subject: Re: Tupperware repair Mon May 02, 2022 7:30 pm
The Dude wrote:
I have been using Super Glue but it's messy. So plastic model glue will work better I gather. Makes sense.
I use the ABS plastic cement glue to reinforce weak points. I try to use old broken Swing plastic pieces and cement it to the underside. That is the same cement used for ABS pipes. Careful in not using too much cement. It forms a chemical bond, which means that it melts the two plastic pieces together. You could also use drywall mesh tape and coat it with ABS cement. The webbing makes a very strong patch.
The Dude Maxi-Scooter Rider
Number of posts : 193 Location : Lake Stevens, WA Points : 1227 Registration date : 2022-02-20
Subject: Re: Tupperware repair Mon May 02, 2022 4:55 pm
Number of posts : 193 Location : Ireland Points : 1772 Registration date : 2020-08-11
Subject: Re: Tupperware repair Mon May 02, 2022 3:17 pm
Quote :
Is that to say that PET bottle plastic cant be used for our purpose as you’ve described above?
Absolutely: PET bottle plastic can't be used for our purpose stated above.
Ye olde 'Lexan' would do the trick; it's tough and sticks with this family of solvents. The bit of Vivak I have is a lot like it and does contain a lot of polycarobnate. It's more stable in UV and heat forms better than Lexan.
As for "a common source for dichloroethane" - any cement you would use on a plastic construction kit will do. In a previous life I worked as a model maker in an industrial design studio. I have experience of it and just prefer to use neat dichloroethane but some may like a blend like you get in a model shop. A few years ago a design job went south on me leaving me with just a 3d printer, a high end cad system and a couple of litres of the stuff.
Subject: Re: Tupperware repair Mon May 02, 2022 2:35 pm
smellybeard wrote:
I've checked: dichloroethane makes absolutely no impression on a PET bottle.
Subject: Re: Tupperware repair Mon May 02, 2022 12:14 pm
Subject: Re: Tupperware repair Sun May 01, 2022 8:48 pm
I'm not sure if PET dissolves in dichloroethane or chloroform or similar solvents. I have some and I'll check. My bit of vivak might be an older formula - it is knocking about in the shed for 20+ years. I'm pretty sure it's a polycarbonate alloy.
Subject: Re: Tupperware repair Sun May 01, 2022 8:36 pm
So I did a little research and found that Vivak is a PET. And PET is commonly used in beverage bottles. I wonder if the sturdier plastic PET ice tea bottles can be repurposed to reinforce our ABS tupperware?
Now to find a common source for dichloroethane.
Subject: Re: Tupperware repair Sun May 01, 2022 8:02 pm
Vivak forms quite easily with heat - it's intended for vacuforming. It doesn't absorb moisture, so you don't get the little blisters of steam forming in it when you heat it rapidly. You can hit it with a hammer and you'll just leave dents in it.
Subject: Re: Tupperware repair Sun May 01, 2022 6:11 pm
Easyrider wrote:
Be careful with the left side under cover that supports your left foot when riding. It does have a tendency to crack at the corner where the foot rest starts upwards. I have had two Swings that cracked at that location. Had to add ABS pieces on the underside to strengthen the foot rest.
Thank you sir! Yes, it cracked/broke right at the mount point where my foot rests, or when i climb on. I put some pressure on it with my foot and did indeed find a lot more "flex" than I anticipated.
So, I check the parts diagrams to see if I missed something, but do not see anything obvious. I will use your advice and reinforce that area before I re-install.
Subject: Re: Tupperware repair Sun May 01, 2022 11:31 am
Usually 1mm thick. That's flexible enough to follow the sorts of curves we usually find and cuts with a decent scissors. Being transparent, you can see through it to make sure your cement and plastics are making proper contact and that there are no bubbles. If you can't follow the curve in both directions cut the reinforcement into narrower strips.
Subject: Re: Tupperware repair Sun May 01, 2022 11:02 am
smellybeard wrote:
SW plastics are for the most part ABS and repair readily with solvent-type liquid adhesives. I use dichloroethane which runs well into the root of cracks and evaporates quickly. For reinforcement I use strips of Vivak which is extremely tough and also sticks with dichloroethane. I believe it's a PET/Polycarbonate alloy. Whatever it is, it's incredibly tough.
Excellent information Sir Smellybeard. I may have to move this to a “How to Repair Tupperware” topic.
How thick are the Vivak strips you’ve been using?
Subject: Re: Tupperware repair Sun May 01, 2022 9:16 am
GaryC Scooter Rider
Number of posts : 16 Location : Manitowaning, Ontario, Canada Points : 1561 Registration date : 2020-08-26
Subject: Action Taken Wed Sep 30, 2020 10:18 am
Thanks for all the contributions made regarding repairing the ABS and PolyPropylene body parts on the Silverwing; I really appreciate that.
Just to close the loop, I'll explain what I've done: I tried "welding" the PP parts first with a large propane torch, then with a micro butane one and finally with an electric soldering pencil. l tried using black nylon cable ties as "filler' but that just didn't work for me... my conclusion is that nylon isn't compatible with PP but I don't know that for sure. The large propane torch is great for soldering copper pipes but much too unwieldy for the delicate heating of PP, the smaller butane torch was much better but still too hard to heat areas precisely; the soldering pencil was definitely the best and a cordless one would be best.
I managed to make a good weld on the Lower Speedometer Cover broken bracket... material is >PP-T< whatever that means.
Weld on the Meter Panel >PP< was a different story. I ruined the broken standoffs by heating wrong spots with the microtorch but achieved an apparently acceptable fix by using a Cdn$9 steel reinforced epoxy putty called Tech Steel (nlsproducts.ca). I was able to reattach the lower left side tab with the soldering pencil... not a great repair compared to the undamaged right tab but hopefully it will hold up enough to get the bike back together soon.
After considering all of the options presented by the contributors, I had selected black ABS cement as the most practical option for re-attaching the ABS tab on the front Cover but just couldn't find it without importing to Canada at outrageous cost; only yellow ABS cement is readily available in Canada, as far as I could determine without making a career of this task. So I tried Cdn$7 yellow ABS cement obtained from our local building supply store. The tab does stay attached but again it appears to be an inferior fix compared to the undamaged right side tab on the Front Cover.
So, I consider all of these repairs, except for the Lower Speedometer Cover bracket, as temporary and have ordered a new Honda 64361-MCT-000 Meter Panel for Cdn $75 and a Plastex repair kit for reinforcing the ABS tab on the left side of the Front Cover from Amazon for Cdn$60, including shipping & taxes. I intend to re-address these temporary fixes next Spring.
Thanks again for all the help!
Gary
GaryC Scooter Rider
Subject: Re: Tupperware repair Sat Sep 26, 2020 10:36 pm
exavid wrote:
Gary C., you might want to check with a plumbing shop if you don't have something like Home Depot or Lowe's. The stuff is cheap and yields a 'chemical weld' when used on ABS plastic, much stronger than a glue bond with just attaches to the surface of the medium.
exavid: my woes continue... for some reason black ABS cement is not readily or reasonably available in Canada but yellow is everywhere! I wonder if the black is just more popular in the USA while yellow is more favoured in Canada? I've used the yellow stuff for several decades but just on black ABS drain pipe and fittings. It is a staple plumbing product here. For sure the yellow also chemically reacts with the pipe because once glued the pipe will break before the bond and it takes heavy hammer blows to break black ABS drain pipe. I'm wondering if the black and yellow aren't chemically identical. In fact, I just read one opinion that the yellow colour simply makes it easier to verify that proper joints have been made, presumably for inspections. Have you actually worked with yellow ABS solvent cement and know it to be inferior to the black? The yellow will cost me under $7 at my local Home Hardware store for a 4 oz can while the black will cost $42 from Amazon for the same size. (Plastifix will cost $45 plus another $50 for shipping!) Then there are different grades of black too but all in the US market. I will follow-up on your suggestion to talk to an experienced person at a long established plumbing shop because I'd follow your lead in a heart beat if I could do so to quickly to finish my FSC600A work before the weather turns ugly.
Gary
Subject: Re: Tupperware repair Sat Sep 26, 2020 8:22 pm
GaryC Scooter Rider
Subject: Re: Tupperware repair Sat Sep 26, 2020 8:56 am
exavid wrote:
ABS plastic as found in all the black drain pipes and fittings is best joined with the black ABS cement which has the advantage of being inexpensive as well as giving a bond that's more chemical welding by softening the ABS plastic in the joint and bonding it not like a surface bond, much stronger. You can also patch holes in ABS parts with the stuff. I repaired a damaged GL1000's front fender with ABS Cement mixed with ABS dust collected from my sander. The crack and small broken piece was replaced by an ABS "putty" mixture. I talked with a friend of mine who rides with the guy who bought that bike that I repaired in 1999, he told me that the fender still looks like new and the patch isn't visible out the surface. Can't ask for more.
exavid: that does it! I'm now looking for black ABS cement and intend to follow your advice. I don't know that it will be inexpensive unless I can find it in Canada at Home Hardware Building Centres or places like CTC but the proven effectiveness is what I want. Thanks again for this most practical of solutions!
Gary
Subject: Re: Tupperware repair Sat Sep 26, 2020 1:04 am
GaryC Scooter Rider
Gary, I've done lots of research, repair and paint work on both the PP black and ABS painted bits. Plastifix (exact same product as Plast-Aid) is available in Canada through Aircraft Spruce Canada at the Brantford Airport. See first link:
AircraftSpruce - Plastifix
Secondly, my experience is that no glue alone will do an adequate job on either the black (PP) parts or the painted parts (ABS) parts without using additional materials for reinforcement. You have cracks/splits because they are weak points and simply returning them whole will not address the inherent stress points. You need to fortify them with additional materials like fiberglass webbing, using bent staples as reinforcers (think rebar in cement) etc.
Third, the black PP parts are usually best repaired by plastic welding using a soldering iron or other similar heat source like open flame if you are able to and know how to control it. It's pretty easy to do once you get the knack of it ... about the same skill level as soldering copper plumbing sweat joints. I use plastic zip ties for my "plastic welding rods". Your meter panel repair will likely require this approach.
Third, check out Windy Urtnowski on YouTube. He has a number of informative videos on how to repair and restore the various plastic bits from MC's. He does this for a living and is very good at it. See link below:
YouTube - Windy Urtnowski - Fairing Repair
Lastly, I have collected a number of SWing parts over the years and currently have a brand new ... and ... a used meter panel that I am willing to sell.
I also have a complete, post 2006 dash panel, with the much desired black textured finish including the raised, much sturdier cubby lids etc. In fact, it already has the 12v outlet installed in the left hand cubby and a rheostat installed in front for hand/seat/clothing warming devices. You can drop me a PM and let me know if you're interested in any of the above.
Good Luck with your repairs. ~ BugJr ~
sonuvabug: I've sent two PMs to you but didn't know I need to have 5 posts before I can do that, so you haven't seen them. I'll try to beat the system by repeating my request here; hopefully that's not breaking any rules.
Following up on your reply regarding new and used meter panel parts, I'd be interested in knowing what you have and how much you'd want for each part. Also, I've found Canada Post still has the most economical shipping rates, so would like to use that method if we make a deal. I've been able to "weld" the broken bracket on the Case (Lower) Honda part number 37211-MCT-691 so, if it stands up to reassembly, I may not need that piece. My unit is stamped "Honda >PP-T<" but the part number is not included. The part I'm most interested in is called "Cover, Meter Honda part number 64371-MCT-770". This part number and the earlier one was obtained from an online supplier in the USA. My unit has the following stamping: "Honda >PP< 64361-MCT-0000 Panel Meter"; why the part number is different I can't explain. My success with welding the Case (Lower) was not repeated with the Cover, Meter. The Case is >PP-T<, while the Cover is just >PP<. One of my concerns is the use of black cable tie as filler; my cable ties are labelled "nylon cable ties", so this might be similar to using the wrong welding rod; what do you think?
Gary
sonuvabug: I just discovered why the part numbers and names are different: it's because they are different! I looked up the wrong part; my bad. The correct part number and the one I'm interested in is "64361-MCT-000 Panel Meter". Sorry for the confusion.
Gary
GaryC Scooter Rider
Gary
GaryC Scooter Rider
For gluing ABS parts on the tupperware I use ABS cement available cheaply at a hardware store. It's a black glue basically made up of ABS and an acetone solvent. Gooey but it makes a solid chemical "weld" to ABS plastic parts. I experimented with a bit of several blobs of different glues and epoxy glues on ABS Goldwing parts and the only one I couldn't pry off the surface of the plastic piece of fairing was the ABS cement. All the others could be pried off with a chisel.
Mix the cement with sanding dust made of ABS and you have a 'weld on' putty to repair or fair in surface repairs. Best of all the makin's are cheap.
Check the forum I've described using that gooey black ABS cement from hardware stores before.
Thanks for the reply, exavid; somehow I missed seeing this until now but recall reading your advice in a different posting on this forum. I've never seen black ABS, only the yellow stuff at building supply stores for ABS plumbing pipes and fixtures. Do you suppose the yellow stuff will work too? As you say, this is the least expensive option. Plastifix, which is apparently very good for these repairs will cost me $35 Cdn plus another $35 for shipping!
Gary
GaryC Scooter Rider
Sonvuabug, thanks for your quick and comprehensive reply, I really appreciate the time and effort you (and the others) have made on my behalf.
Thanks for your several references for me to follow up on; I'll do that as time permits. I'm especially interested in the Plastifix from Aircraft Spruce in Brantford. I've been happy with my previous dealings with them.
As stated in my original post, I have little confidence with gluing plastics so appreciate your candor and caution to use reinforcing methods. Several others, and now you, have suggested drywall reinforcing tape and one auto body repair specialist suggests ordinary paper soaked in Superglue, basically a bridge of paper and hardened glue, so this must be important for an enduring fix. In my case I think the breaks are due to some extraordinary impact like an angry banging of powerful fist (or worse) on the top left of the instrument panel area. When the bike was completely assembled there was no obvious distortion or vibration that I noticed during riding but I must admit that I'm not the world's most observant guy, so that means little. There's got to be a story there but most likely I'll never know what really happened.
Several others claim good results with different glues for the ABS and polypropylene parts. If my cause-of-damage analysis is correct and the glue confirmations bear out, I believe a glue-alone fix will suffice. I tried a feeble effort to "weld" one tab on the large black PP Meter Panel bezel (the panel that surrounds the instruments) using a large propane torch and a black cable tie but was too timid to approach the panel with the torch and only heated the "filler" tie to melting and dribbled some onto the tab but the panel seemed to reject any adhesion... so no luck. I have done successful plumbing and electrical soldering but that skill and steel welding are not my strong areas of accomplishment. I just acquired a Bernozmatic ST2200 butane micro torch, so I may try a more aggressive attempt following your suggestion. However, my concern now is that my "filler" cable ties may not actually be polyproplyene because they are called nylon cable ties. Nothing is easy!
I'll PM you re: the meter panel parts you have available. I believe mine is inherently fixable but fully intact replacements have their appeal too.
Gary
GaryC Scooter Rider
Subject: Re: Tupperware repair Fri Sep 25, 2020 11:07 am
The Bern wrote:
SUPER GLUE ALL PLASTICS, 2G works well PP & PE bud
Datasheet & instructions here ... http://www.farnell.com/datasheets/2330648.pdf?_ga=2.138993268.691865389.1601025128-1281367797.1601025128&_gac=1.15519362.1601025696.EAIaIQobChMIzKmcyPqD7AIVUObtCh1-VQmNEAQYBSABEgIVgPD_BwE
Thanks for your input, The Bern! I've seen this product online but am not sure that it is readily available in Canada... I believe the supplier was in the UK. That doesn't pose any great difficulty other than added cost and time to import. Your confirmation that it works with polypropylene is the really valuable part to me, so thanks for that information! Now I'll try harder to see if I can get some in Canada.
Gary
GaryC Scooter Rider
Subject: Re: Tupperware repair Fri Sep 25, 2020 10:57 am
Terry Smith wrote:
You are quite correct that the meter panel is polypropylene (PP) and I suspect the rear fender and inner fender, luggage box are too, but the painted parts on mine are all ABS, as are the centre cowl (over the engine/floorboards) and upper (around the instruments) and lower (glove box etc) front cowls.
PP is a beast to glue and I haven't had much luck, and also haven't tried too hard, as I only have a locating post broken on the back of the instruments which I "welded" with my soldering iron.
For the ABS I have used Permatex Plastic Weld (2-part epoxy), and also Plastex (powder + solvent) and both have been great. I've had to work on the front fairing and both the side skirts extensively, plus the parts around the glove boxes. The Permatex is incredibly strong and I have used that to refix broken mounting tabs and sockets. The Plastex is really good for bodywork cracks. Watch some "HOw to With Kel" videos for, well, how to...including using Drywall fibreglass tape to reinforce bits.
Terry, thanks for the quick reply from New Zealand! Most of the 2006 Silverwing's lower black body parts are polypropylene... from my own recent goggling, PP seems to be the "standard" abbreviation for that specific plastic. Your confirmation of Permatex Plastic Weld for the upper ABS painted panels is very valuable to me and I believe I can get it easily and economically right here in Ontario, so thanks a bunch for that contribution. I hadn't heard of Plastex before but will look into that product if necessary. Thanks also for the suggestion on "How to with Kel" videos and the drywall fiberglass tape reinforcement tip.
One delightful tip from a very experienced auto body specialist is so practical it hurts: he suggests putting a bead of Superglue on any plastic then applying a strip of paper, yes ordinary paper, on top of the part with tweezers then saturating the paper with more Superglue and letting it dry. Optional but not necessary is to use more layers of paper. He uses this to repair plastic car bumper clips and claims it seldom fails to hold. Check it out: https://youtu.be/pzldxs_Z6DI
Gary
GaryC Scooter Rider
Subject: Re: Tupperware repair Fri Sep 25, 2020 10:09 am
Yes, you folks up in the GWN can’t seem to get your hands on Plast-Aid. But all is not lost. See this link to a previous discussion of body panel repair. Of particular note is Sonuvabug’s post: https://www.silverwing600.com/t11792-bodywork-paint-repair
Edit. Here is a fairing repair video link: https://www.youtube.com/watch?v=JhTtikXYXzo
Thanks for the quick reply, Cosmic_Jumper. Yes, you US folks really have it made regarding the vast and ready supply of great products... I've found I can get most things albeit at much higher cost and longer delivery time if I'm persistent enough. What I don't want to do is pay the premium, then wait, only to discover that the product won't work as hoped for by me, especially if some new skill on my part is needed. Thanks for the link to Sonvuabug's post; I think he also has answered my cry for help! I'll watch your suggested video after I've acknowledged everyone's contributions.
Gary
GaryC Scooter Rider
Subject: Re: Tupperware repair Fri Sep 25, 2020 9:51 am
Search Plast-Aid. I've repaired a few tabs works great strong bond and smell.
Not sure what type panels are made of but this stuff works well.
Thanks for the quick reply, Mech 1 twa. I was aware of this excellent product but it is very expensive and not easily obtained in Canada; I'm pretty sure the supplier doesn't ship to Canada. Before Covid19, my avenue around that problem was to have goods delivered to Sault Ste Marie, Michigan which is only a 4 hour trip away (and an excuse to ride!) but, as you know, now that border is closed to me.
Your testament to it's performance on repairs for ABS tabs is what I really value... so thanks for that!
Gary
sonuvabug Silver Wing Expert
Subject: Re: Tupperware repair Fri Sep 25, 2020 9:35 am
The Bern Silver Wing Expert
Subject: Re: Tupperware repair Fri Sep 25, 2020 5:23 am
Terry Smith Silver Wing Rider
Subject: Re: Tupperware repair Fri Sep 25, 2020 1:14 am
Hi from Northern Ontario, Canada. I`ve got my "new" 2006 Silverwing FSC600A torn down so that installing the wiring for new grip heaters, a seat heater and a 12V power outlet in the factory-provided hole in the left glove box is simplified. Virtually all body panels are off. I'm also stealing the tool storage tray to locate a PDM60 power distribution module for ease of future mods and maintenance work. During the tear down I discovered that a few of the hard plastic body tabs and a couple of black plastic screw standoffs were broken, in particular the ones holding the left side of the meter panel. How that happened and was left unrepaired on a machine with only 14K km is disturbing to me but I intend to fix it if I can.
I believe that there are at least two different plastics used in the Silverwing body panels but stand to be corrected on that point. I see that many people refer to these collectively as "Tupperware", which is an excellent and amusing analogy but I think Tupperware is primarily polyethylene and not the ABS that many seem to think is the primary body plastic for the Silverwing. If it is indeed ABS, which is highly probable, "Plumbingware" may be a more accurate nickname! I may be wrong on that point too.
So, I just don't know what is used but my machine has both the hard, thick plastic for the showy painted body panels and the softer black, thinner, flexible plastic for the lower parts like the large step floor that surrounds the gas filler cap; this material seems to me more like the PVC that I think is used for vinyl siding. Even that material I'm not sure about. My step floor has the following stamped on it: "64320-MCTA-0000 MCTA STEP FLOOR >PP<"; actually the angle bracket symbols are missing on this particular part but they are prominent on most of the other body panels. Could PP mean PolyPropylene? Fortunately, Honda has provided this information but it is cryptic and needs careful interpretation; for example, on the underside of the right lid pocket is stamped: "LID RH POCKET 64461-MCT-6100 Honda >ABS<. So it's easy for me to jump to the happy conclusion that items surrounded by angle brackets indicate the material of the part, but nowhere have I seen this explicitly stated. I think I've seen something like this on General Motors plastic parts too, so maybe this is an industry standard.
What I do know from mostly unsuccessful experience is that it is imperative to match the glue to the specific plastic to have a reasonable chance for a good repair. I've had excellent results with yellow ABS cement on black ABS plumbing pipe and with the primers and cements sold specifically for PVC & CPVC pipe. Most of the Super or Gorilla glues I've tried on small and difficult jobs have generally failed after a short time for me. Does anyone out there really know what plastics are used on the 2006 Silverwing?
I've taken these pictures to illustrate my points:
This first picture shows the back of the Meter Panel with a cracked bracket and the broken standoff part which is still held in place by a screw. This is an example of the softer black plastic, which may be... PolyPropylene? Stamping on the back of the Meter Panel states: "Honda >PP-T<, so already my theory has an exception. This stamping, which declares: "Honda >PP< 64361-MCT-0000 PANEL METER" is not actually on the back of the Meter Panel but is on the Meter Panel Bezel and is what is what is leading me to think the soft black plastic may be PolyPropylene. I'd like to be sure before attempting any glue-ups. This third picture illustrates a broken-off hard plastic tab; my supposition from stampings on the other painted, hard plastic body panels is that it too is ABS.
I'd appreciate comments from people who know this stuff and that are specific and scientifically based. I've had suggestions from friends and have read posts that feature products that are just not reasonably available in Canada. I'd probably try one of those if I felt it would definitely work. In my opinion, it takes too much time and is too costly to experiment.
Hiyo Scooter Rider
Number of posts : 94 Location : East Central Illinois Points : 1948 Registration date : 2019-10-22
Subject: Re: Tupperware repair Tue Oct 22, 2019 10:17 pm
Permatex makes a plastic bonder with an activator. I think it is cyanoacrylate based. I used it on a cage front air dam. Pretty sure those are ABS. It never did let go.
Hiyo Scooter Rider
Subject: Fairing repair Tue Oct 22, 2019 10:02 pm
I cut the windshield (GIVI) and had a bit of plastic leftovers. Some tabs on the front panel were broken . I made new ones out of the leftover bits and used JB Weld plastic bonder epoxy. So far so good.
Subject: Re: Tupperware repair Mon Oct 21, 2019 11:06 pm
Just to confuse matters here is YouTube link sent by Sonofabug. Windy Urtnowski has a good reputation repairing & painting fairings on race bikes. He favors using cyanoacrylic glue & fiberglass:
https://www.youtube.com/watch?v=RWvpZaKBBfI
My go-to for tupperware repair is still PlastAid.
DLK Scooter Rider
Number of posts : 75 Location : Cincinnati Ohio Points : 2155 Registration date : 2019-04-01
Subject: Re: Tupperware repair Mon Oct 21, 2019 9:01 pm
also there is a 6 oz kit of Plast-aid for just $34.99 if you have more than a few tabs broken, and they claim a 5 year shelf life even after opened....
Subject: Re: Tupperware repair Mon Oct 21, 2019 8:54 pm
ABS Plumbing Cement. It's used for black ABS plumbing pipe.
The brand name for the stuff is Oatey's and it comes in about a 6 oz can.
Just in time for my one of my winter project’s of fixing a crack in the belly pan my brother put there with a big curb…. Tim I see 3 black Oatey abs cements,
#1, United Elchem 4400 Series ABS Medium Black Cement is a formulated for non-pressure applications on all schedules and classes of ABS pipe and fittings up to 6" diameter with interference fit or
#2 Oatey Extra Special Medium Black ABS Cement is specially formulated for use in the hot and arid climates in the western United States on ABS pipe and fittings up to 6" diameter with interference fit. Or last
#3 Hercules ABS Black Medium-Bodied Fast Set PVC Cement is a fast-set black cement for use on all schedules and classes of ABS pipe and fittings up to 8" diameter with interference fit.
By my blind guess I’m thinking the Hercules, but I don’t know….. Which one do you recommend ????
Thank you Dan
johnd Silver Wing Expert
Number of posts : 543 Age : 76 Location : Santa Barbara California Points : 6065 Registration date : 2010-02-01
Subject: Re: Tupperware repair Mon Oct 21, 2019 11:22 am
Thanks again for the Plastix advice. I found a large separation in my right front turn signal along with some other broken tabs. It was amazing stuff, and easier to use than any of the other options used in the past. Now with my new rear tire and no noises, I am a very happy camper again.
Subject: Re: Tupperware repair Sun Aug 04, 2019 8:00 pm
Good stuff works very well on SW plastic body parts. Very strong smell use it in garage or outdoors.
Subject: Re: Tupperware repair Sun Aug 04, 2019 7:50 pm
Not sure about the two different versions of Plastex but the best product I've found for repairing cracked & broken tabs and body panels is Plast-aid. No doubt the same mix of ABS powder & bonding agent as whichever Plastex is the right one for our panels. But this 1.5 oz kit is less expensive that what you mention and free shipping too. https://www.ebay.com/itm/Plast-Aid-Acrylic-and-PVC-Repair-Kit-for-Hot-Tub-Cracks-Leaks-1-5-1-Pack/173817451076?epid=1307490333&hash=item287853d244:g:AUwAAOSwRPBdQbqj
CathyN Silver Wing Expert
Number of posts : 771 Location : USA Points : 6039 Registration date : 2010-11-15
Subject: Re: Tupperware repair Sat May 07, 2016 10:54 pm
Loopless wrote:
Hi CathyN...that stuff looks pretty interesting for tab repair and other purposes. Please post how well (or poorly) it worked out for you.
Thanks
Loopless, this stuff worked great. My front plastic is not rattling nearly as much. Bob couldn't replace every tab because he wasn't sure what some of them looked like but it is a huge improvement. It seems to be holding strong. It works great for any job around the house. He fixed plastic tab on my frig door last week. The cost is 9.99 for the large bottle. Well worth it.
Loopless Scooter Rider
Number of posts : 6 Age : 61 Location : Long Island N.Y. Points : 3130 Registration date : 2016-05-01
Subject: Re: Tupperware repair Sat May 07, 2016 7:03 pm
Thanks
terrier Touring Scooter Rider
Number of posts : 302 Age : 75 Location : Northumberland, UK Points : 3726 Registration date : 2015-08-12
Just watched the video of this on Youtube. Impressive looking stuff. Never heard of it before but it's available here in the UK through Amazon. A bit pricey but if it makes permanant job it'll be worth it.
Den
Subject: Repairing/Replacing plastic tabs on Tupperware. Sun Apr 03, 2016 3:44 pm
Bob this past winter has repaired/replaced quite a few of my plastic tabs with http://www.plast-aid.com/ . This stuff works great. Just make sure you ventilate the rea your working in.
These are pictures of a repaired tab. Front and back
These are pictures of a refabricated tab. Front and back.
We will be putting the Tupperware back on the bike today. Bob installed the Hagon Shocks yesterday. I will report on how both projects. After I take in for a ride.
Cathy
P.S. Administrators I like the ease of posting a picture since I last posted one.
ScooterBJ Maxi-Scooter Rider
Number of posts : 170 Location : Colorado USA Points : 4241 Registration date : 2013-11-14
Subject: Avoid panel cracking and broken tabs Sun Feb 23, 2014 11:57 am
Oops, I forgot to add a tip to avoid cracks, breaking tabs, etc., when removing panels.
The tabs, catches, and panel retainer pins (pops into a rubber grommet) are pretty east to break. Especially as the Silver Wing gets older and the areas get dirty. Once panels are off, clean up the area and use a 'Door Ease' stick liberally over the tabs, pins, grommets, etc.
Door Ease is a wax/grease stick meant to use for sticking door edges or drawers that do not slide well. Works the same on plastic panels as it stays on the area, provides lubrication and makes the parts easier to pull apart next time. Sometimes it can also lessen, or stop, panel squeaking due to vibration. I've been using this method for years on everything from dual-sports to scooters with good results.
The stick I have has been in use for 5 years or more -- it lasts a long time. Most hardware or home stores carry Door Ease (or similar) for about $4US. Here is an example. DOOR EASE LINK
The Delboy Garage (above) heat welding procedure video works well for the soft plastic panels like the hump plastic over the fuel tank. The Plastex kit (I have) does not work on this type of plastic, only hard plastics like ABS (and even cracked windscreens). Plastex does offer a kit for soft plastics, which they claim even works on fuel tanks, but I have not used it. I have used a solder gun to hot weld soft plastic though.
Subject: Re: Tupperware repair Sun Feb 23, 2014 11:37 am
lalee wrote:
Good information here. Thanks to all who posted. I need to fix a small crack on my bike and now I can see how to do it.
Glad you found it helpful. For small cracks I handle the repair a bit differently so I don not have to refinish the paint. 1) Clean the inside of the crack with an old toothbrush and alcohol. Allow to dry fully. 2) Rejoin the crack with a small amount of super glue (toothpick works well for applying). Be sure to wipe any excess off the paint surface before it sets up. Use pressure to force the crack together. Sometimes I use bungees or duct tape. Allow the glue to fully dry. 3) On the backside, grind a V shape into the crack about 2/3 way through. Clean it up. 4) Use the Plastex kit to fill and weld the crack back into one piece. If there is room, build up the weld a bit to strengthen the crack area. If all goes well the crack will be almost invisible, sealed shut and strong.
Granny Rides Scooter Rider
Number of posts : 13 Age : 73 Location : Lake City, Florida Points : 3937 Registration date : 2014-02-21
Subject: Scooter BJ Fri Feb 21, 2014 2:17 pm
Awesome....Thanks so much! I'm pretty handy and I'll give it a shot. Thanks for the direction. Saw something similar on "You Tube" where they used a heat gun to melt the top layer of fine lines, then another using "wet" sand papering method. When I learn how to upload here I'll send before and after pics.
I have been using a Plastex kit for years and it does a great job. It is chemical welding (solvent, similar to the ABS plumbers cement) and has the solvent liquid and powered ABS to make the welds, fill areas and strengthen. It is pretty easy to use once you get the hang of it, but make sure you have good ventilation.
There is an article I did in Scooter Rider Magazine, which is available on the BigAss Scooter website. Posted articles are free to download for personal use. Go to http://www.bigassscooter.com, click on Articles in the menu and then on the Scooter Rider Magazine Articles link. It is listed there and the articles are in PDF format.
I have been using this stuff a lot recently as my '04 is stripped of it's body panels for doing upgrades, fixes, etc. It had been in a fall over accident and the left side panels were damaged. Many of the prior repairs were done with a JB weld type epoxy, which does not stick to ABS well. Since Plastex is a welding method (not gluing) I have used it to make/replace and reattach fixing points, fill holes, weld cracks, and strengthen weak points. I use pieces of old electronics cases when I need to make a part or make a strengthening point. In the past I have also repaired a laptop case, cellphone housing, etc.
Here are some before - during - after pics of remaking an alignment tab on the left rear side panel. For this I used the clear powder, hence the plastic weld is see-through. It is important to get to the actual ABS (as stated prior) and not try to weld through the paint. The cleaned/beveled edges of the old tab mouting point, and the new tab, can be seen through the weld. The masking tape provides a way to hold the part together and a 'dam' to hold in the powder/solvent mix while it dries. After 24 hours I remove the tape and do the same to the back of the tab. The tab is now stronger then stock. Hope this helps.
Last edited by ScooterBJ on Fri Feb 21, 2014 12:47 pm; edited 1 time in total (Reason for editing : additions)
Daboo Super Scooter Rider
Number of posts : 271 Age : 72 Location : Seattle, WA Points : 5757 Registration date : 2009-12-08
Subject: Re: Tupperware repair Fri Jun 08, 2012 4:01 pm
Another repair method is "plastic welding". Here's a YouTube video explaining how it is done. Several BUSA members have tried it and now swear by it.
