SilverWing Specs I_icon_minitimeby xwelder Today at 9:06 am
SilverWing Specs I_icon_minitimeby GHM-PM Today at 8:06 am
SilverWing Specs I_icon_minitimeby sonuvabug Yesterday at 4:17 pm
SilverWing Specs I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
SilverWing Specs I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
SilverWing Specs I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
SilverWing Specs I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
SilverWing Specs I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
SilverWing Specs I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
SilverWing Specs I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
 SilverWing Specs
cello33
Number of posts : 150
Registration date : 2018-07-09
SilverWing Specs Empty
PostSubject: SilverWing Specs   SilverWing Specs I_icon_minitimeSat Feb 11, 2023 5:40 pm
2005 Honda Silver Wing ABS/Silver Wing Features
RELEASE
September 8, 2004 — Torrance, Calif.
Nothing else can match the easy operation, luxurious accommodations and outstanding performance of Honda's innovative Silver Wing.
Features & Benefits
New for 2005
ABS version available in Black/Silver or Titanium/ Silver.
Non-ABS version available in Black or Titanium.
Unique features
Compact, fuel-injected 582cc DOHC parallel twin-cylinder engine produces 50 bhp at 7500 rpm and 37 lb./ft. of torque at 6000 rpm for effortless acceleration and freeway cruising.
Sophisticated Honda V-Matic™ belt-drive system delivers seamless shifting and ample power at any speed.
Combined Brake System™ (CBS™) provides excellent braking power for added confidence in a wide range of operating conditions.
Stunning aerodynamic styling is also functional. The fully integrated bodywork envelops the rider in quiet luxury, with protection from the elements that enhances long-distance touring comfort.
Cavernous, 55-liter underseat storage compartment and beautiful, lightweight aluminum rear spoiler.
Engine/Drivetrain
Four-stroke 582cc parallel twin-cylinder engine features DOHC and four valves per cylinder for unequalled engine performance and clean, efficient operation.
Air injection system, exhaust catalyzer and advanced digital mapping simultaneously reduce emissions of hydrocarbons (HC), carbon monoxide (CO), and oxides of nitrogen (NOx).
Engine's 360 degree crankshaft design employs two primary balancer shafts incorporated into the crankcase. Spinning the same speed as the crankshaft, one balancer is positioned above and forward of the crankshaft, the other positioned below and to the rear. Together the balancers cancel out primary vibration in both the vertical and longitudinal axes for comfortable cruising.
A vertically split crankcase eliminates the center journal between the crankshaft outer main bearings and the two connecting rods for a very narrow engine design that contributes to the Silver Wing's slim, attractive profile.
Engine employs lightweight slipper pistons to reduce internal drag for excellent operating efficiency and superb off-throttle engine response.
Direct shim-under-bucket valve actuation assures excellent engine performance, trouble-free operation and 16,000 mile valve maintenance intervals.
Programmed fuel injection (PGM-FI) features compact dual-throat venturis and two laser-drilled, four-hole injectors that produce a highly atomized fuel charge, resulting in quicker, more efficient combustion throughout the powerband.
Auto-enriching system eliminates the need for a manual choke.
Spark plugs are positioned directly in the center of the combustion chambers for fast, efficient ignition and combustion.
Maintenance-free fully transistorized digital ignition assures immediate and reliable power.
Unique ignition timing control is activated by the electronic control unit (ECU) to provide smooth acceleration under abrupt throttle application.
Automatic cam-chain tensioner virtually eliminates maintenance.
Large air-intake ports positioned behind the front wheel route the airflow directly over the radiator to enhance engine cooling.
Compact liquid-cooled oil cooler mounts to the front of the crankcase and provides a convenient mount for the spin-on oil filter.
Fan-cooled radiator assures consistent engine operating temperatures and long engine life. The radiator is located under the seat in front of the frame-mounted engine, maximizing storage bin capacity.
Oil-cooled alternator provides trouble-free operation and ample power for the PGM-FI and all electrical necessities.
Lightweight and quiet stainless steel exhaust system.
Honda V-Matic automatic belt-drive system provides sophisticated three-stage operation, matching the engine's strong low-end and mid-range power to a wide range of operating conditions. Stage One delivers efficient, quiet power for around-town cruising; Stage Two provides increased power for moderate acceleration; and Stage Three provides maximum power for full acceleration and top speed.
Chassis/Suspension
Durable steel frame is lightweight yet strong, providing an optimum combination of rigidity and flexibility for superb handling for one- and two-up riding.
Engine crankshaft and swingarm pivot are coaxially aligned to eliminate the engine as an unsprung suspension member, resulting in better mass centralization for excellent handling, stability and rider comfort.
Stout, 41mm hydraulic front fork with 4.7 inches of suspension travel provides a plush, well-controlled ride.
Dual rear shocks have 4.7 inches of travel and five-position spring preload adjustability for a smooth, comfortable ride. Rearward mounting of the shocks allows a large-capacity underseat storage compartment.
A hydraulic three-piston caliper and 256mm front disc brake, plus a lightweight, twin-piston caliper and 240mm rear disc brake offer excellent stopping power.
The Silver Wing's Combined Brake System features a three-piston front caliper and a twin-piston rear caliper. Rider application of the front brake lever activates the two outer pistons of the front caliper. Application of the rear brake lever, mounted on the left handlebar, activates the dual pistons of the rear caliper and the center piston of the front caliper. When only the rear brake lever is used, an inline delay valve smoothes application of the front caliper piston.
Optionally equipped Anti-Lock Brake System (ABS with Combined Brake System) model features an electric-motor-driven modulator which provides rapid and precise braking-pressure adjustments, resulting in smooth ABS operation. The system incorporates an integrated electronic control unit (ECU) into a simple one-piece design, self-diagnostics with an interactive ECU test function, and automatic protection against system failure.
Stylish three-spoke cast aluminum wheels are lightweight and strong.
Large, 14-inch 120/80 front tire and 13-inch 150/70 rear tire provide excellent traction.
Additional Features
Wind-tunnel-developed full-coverage body-work and windshield are both beautiful and functional, protecting the rider from the elements while reducing wind noise.
Maintenance-free electronic rear-wheel speed sensor eliminates the conventional front-wheel speedometer cable, contributing to the beautiful appearance of the Silver Wing.
Integrated floorboards angle upward in the front for optimum rider foot placement when riding. The floorboards narrow below the seat, which allows the rider to place both feet on the ground easily.
A large, lockable 55-liter underseat storage compartment can accommodate a briefcase or two full-face helmets. A convenience lamp illuminates the compartment in low-light conditions. A lockable, 6-liter left-front storage compartment is joined by an additional 1.5-liter right-side storage compartment.
Multi-reflector headlight incorporates a wide-dimension low beam located directly above the high beam in a compact V-shape for optimal lighting.
n Air ducts located above and on either side of the headlight provide smooth airflow for both operator and passenger.
Wide and low padded seat has an adjustable five-position rider backrest that adjusts over a 2-inch range. The long, wide passenger seat is very comfortable for all-day, two-up riding. The locking seat opens to the front and is held open by a hydraulic damper, allowing easy loading of the storage compartment.
Cast aluminum footrests fold down, offering the passenger a wide range of foot positions.
Instrumentation includes an analog speedometer and tachometer, with LCD digital displays for odometer, twin tripmeters, fuel, clock and coolant temperature. Indicator lights display parking brake, FI (fuel injection), V-Belt, high beam, oil pressure and coolant temperature.
A V-Matic belt wear-indicator senses excessive belt slippage and illuminates an indicator light on the instrument panel.
Push-button electric starter provides quick, effortless starting.
Two handlebar-mounted rear view mirrors with stylish housings.
Large, 4.2-gallon fuel tank offers extended cruising range. The fuel door is located behind a locking cover built into the floor tunnel for easy access.
An easy-to-use cable-operated rear-disc parking brake is engaged by pulling a large handle on the upper-right panel. Pulling the handle again releases the brake.
Powerful 12-volt electrical system and maintenance-free battery offer superb reliability.
Ignition switch/steering lock helps keep the Silver Wing secure when parked.
Sidestand switch allows starting only if the sidestand has been retracted and the rear brake lever is applied.
Handlebar switches and controls use internationally approved ISO graphic symbols.
Transferable one-year, unlimited-mileage limited warranty; extended coverage available with a Honda Protection Plan.
Ownership includes one-year complimentary membership in the Honda Rider's Club of America™ (HRCA®). Benefits include: discounts, travel benefits, roadside assistance, one year complimentary subscription to Honda Red Rider™ magazine, access to HRCA Clubhouse Web site (www.hrca.honda.com), access online to Honda Common Service Manual. For HRCA details, call 1-800-847-HRCA.
Number of posts : 2624
PostSubject: Re: SilverWing Specs   SilverWing Specs I_icon_minitimeMon Feb 13, 2023 7:09 am
Excellent information! My only complaint on my 2012 is that unlike the above I did not get the Honda Rider's Club of America membership for a year... Must have discontinued that in later years.
Thanks for sharing!
Number of posts : 1607
PostSubject: Re: SilverWing Specs   SilverWing Specs I_icon_minitimeMon Feb 13, 2023 7:31 am
I enjoyed reading that, apart from the bit where it says that tappets should be checked at 16000 miles. I obviously missed that part in the service manual, yikes!...another job to consider...I'm already at 37000 miles!
Thanks for sharing.
cello33
PostSubject: Re: SilverWing Specs   SilverWing Specs I_icon_minitimeMon Feb 13, 2023 7:49 am
Cheers , I liked that bit about light weight exhaust......REALLY!!!!
Oh yeah, maybe they have fitted a 4.3 gallon tank for the US market but mine is 12 liters max
johnd
Number of posts : 544
PostSubject: Re: SilverWing Specs   SilverWing Specs I_icon_minitimeMon Feb 27, 2023 1:15 pm
HAHA. Outstanding report. The only thing I would change are the small tires.
Number of posts : 4218
PostSubject: Re: SilverWing Specs   SilverWing Specs I_icon_minitimeMon Feb 27, 2023 5:24 pm
I don't think so. Go look at any spec sheet and the FJS, FSC, and SW-T versions of Silver Wing 600 all share the same size fuel tank. If you convert 4.3 US gallons, it's 3.58 of our proper UK gallons, or 16.22 litres.
SilverWing Specs
» Do you have Time specs on the swing?
» Fork specs, please help before 9/4/2024
» OEM SW Front Fork Springs specs
» Fork springs
» Need torque specs for front brake caliper
