| Anyone wrecking one? After front sub-frame. | |
Craftbike Scooter Rider
Number of posts : 28 Location : S'traya Points : 756 Registration date : 2022-05-28
| Subject: Anyone wrecking one? After front sub-frame. Thu May 11, 2023 10:49 pm | |
| Hi, anyone wrecking a wing?
After Honda 50310-MCT-940 - COVER STAY.
Mine's snapped in multiple places!
Regards. |
Number of posts : 1568 Age : 62 Location : South East England Points : 4529 Registration date : 2016-10-01
| Subject: Re: Anyone wrecking one? After front sub-frame. Mon May 15, 2023 12:29 pm | |
| Unless there's somebody down under who's breaking one you'll need to use eBay.
There's a guy on this forum in the UK who breaks SWs but I shudder to think what the shipping costs would be. I guess you may already have considered that? |
Johnbil09 Maxi-Scooter Rider
Number of posts : 129 Age : 59 Location : Jersey City Points : 566 Registration date : 2023-03-23
| Subject: Re: Anyone wrecking one? After front sub-frame. Mon May 15, 2023 2:47 pm | |
| - Craftbike wrote:
- Hi, anyone wrecking a wing?
Regards. Just google that part number and you’ll be a bunch of hits,$160-180 |
| Subject: Re: Anyone wrecking one? After front sub-frame. Mon May 15, 2023 9:45 pm | |
| Thanks. Ended up ordering new from the USA. Yet to ship, so hoping it’s in stock. Interestingly, once the front end was removed, I couldn’t get the bike to turn on; fuel pump doesn’t even prime. Hoping it’s some sensor which stops you starting it without the dash?! |
| Subject: Re: Anyone wrecking one? After front sub-frame. Tue May 16, 2023 2:51 pm | |
| Have you removed the handlebars assembly for some reason? The ignition switch must be earthed to the bike. Just a thought.... |
| Subject: Re: Anyone wrecking one? After front sub-frame. Sat Jun 17, 2023 2:42 am | |
| Front subframe arrived, and I’m trying to put everything back together.
But, I don’t want to go too far as the bike still isn’t starting. Dash lights up, but no fuel pump noise and nothing happens when I press the starter.
Any ideas? |
| Subject: Re: Anyone wrecking one? After front sub-frame. Sat Jun 17, 2023 9:12 pm | |
| So after switching it on and off a bunch of times, the fuel pump kicked on suddenly and it fired right up
An, intermittent, electrical is my least favourite. Any ideas? I feel like a should chase it before putting everything back together |
| Subject: Re: Anyone wrecking one? After front sub-frame. Sun Jun 18, 2023 3:56 pm | |
| Yeah, I hate electrical gremlins. It could be a 'glitch' in the ECM if it hasn't been active for a while? If you have the FSM you could check the wiring diagram to see if anything in the same loom might be the culprit. If you have the time, you could try starting it up every few days to see if it's OK and then, I guess you need to take a punt and put it all back together. |
| Subject: Re: Anyone wrecking one? After front sub-frame. Fri Jul 14, 2023 6:19 am | |
| I thought I had it solved, but it has returned; just when I got everything back together.
Before, it was not starting when this electrical part was not grounded/attached to frame (held on by two screws and a bit bigger than a matchbox).
The only other thing I can think of is that I did tack-weld near there, but had the negative lead close to where I was welding.
Any ideas? No fuel pump noise.....won't try and start. - Attachments
- (215 Kb) Downloaded 5 times
| Subject: Re: Anyone wrecking one? After front sub-frame. Sat Jul 15, 2023 1:56 am | |
| Can anyone identify this part? It's just to the right of my fingers. - Attachments
- (153 Kb) Downloaded 4 times
| Subject: Re: Anyone wrecking one? After front sub-frame. Sat Jul 15, 2023 1:59 am | |
| The first picture isn't very clear to me. Without the FSM I guess its a case of retracing everthing you've disturbed during the surgery.
Problem with the kill switch? Fuel pump relay? Battery connections (earth)? Dislodged fuse holder under seat?
Keep trying. That gremlin can't stay in there forever! |
| Subject: Re: Anyone wrecking one? After front sub-frame. Sat Jul 15, 2023 2:07 am | |
| I can't help with the second picture without my FSM... but, have you got the key hole plate dangling on it's wires at the moment or is it still attached to the handlebar mount. It must be attached (screwed) to the handlebar mount otherwise the bike will appear 'dead'. |
| Subject: Re: Anyone wrecking one? After front sub-frame. Sat Jul 15, 2023 2:22 am | |
| Ok, I think it's the bank angle sensor......
I wonder if I installed upside-down?
Front end removal time..... |
| Subject: Re: Anyone wrecking one? After front sub-frame. Sat Jul 15, 2023 2:28 am | |
| "Good thinking Batman" ! Please keep us posted. |
| Subject: Re: Anyone wrecking one? After front sub-frame. Sat Jul 15, 2023 2:43 am | |
| Ok, I had the bank angle sensor upside down!
So, super excited I put it back together and she started. Was about to do a little jig, then noticed now the speedo doesn't work properly!
HISS, indicators and the high beam light work, but no fuel, temp, speedo etc.
Oddly, before I turned put the bank sensor up the right way, it was working fine!
Any ideas?! So close to rideable!
Edit; if related, horn now not working..... |
| Subject: Re: Anyone wrecking one? After front sub-frame. Sat Jul 15, 2023 3:18 am | |
| Solved! Had blown a fuse while removing speedo etc somehow..... New fuse, all working again. Now to gently reassemble and finish the fairing! |
| Subject: Re: Anyone wrecking one? After front sub-frame. Sat Jul 15, 2023 12:00 pm | |
| Hold on!....you didn't include the horn on your list of fixes. ?? |
| Subject: Re: Anyone wrecking one? After front sub-frame. Sun Jul 16, 2023 3:49 am | |
| Horn and dash lights are on the same fuse!
I didn't know either!
Took bike around the block for the first time in a long time. Forgot a few fairing pieces, but overall success! |
| Subject: Re: Anyone wrecking one? After front sub-frame. Sun Jul 16, 2023 4:27 pm | |
| We all love a happy ending. Ride on..... |
| Subject: Re: Anyone wrecking one? After front sub-frame. | |
