Silverwingdays Scooter Rider
Number of posts : 98 Location : UK Points : 2836 Registration date : 2017-06-05
| Subject: Silverwing Brakes Fri May 10, 2024 6:20 am | |
| Hi a chap breaking a 600 has offered me a Silvering 600 2011 front caliper ABS etc.
Looks the same in the pic as my 2007 ABS but he thinks they are different.
Just one to bung on the shelf but thought I should ask here, I was sure 2007 on they were all the same unit and pads
Many Thanks
JohnyC Touring Scooter Rider
Number of posts : 366 Age : 71 Location : Bristol, UK Points : 1053 Registration date : 2022-12-23
| Subject: Re: Silverwing Brakes Tue May 14, 2024 6:15 pm | |
| Hi Silverwingdays.
Having studied several Honda Agents Parts listings, it seems the caliper is the same but it's carrier is different between none ABS and ABS. The ABS being longer to include the speed sensor mounting hole. Also different Mounting lugs on the ABS forks Hope this helps.
Be safe, be seen! |
Terry Smith Silver Wing Rider
Number of posts : 403 Age : 60 Location : Auckland, New Zealand Points : 2121 Registration date : 2020-03-11
| Subject: Re: Silverwing Brakes Tue May 14, 2024 11:57 pm | |
| I use the Partzilla website to check this stuff. If you find a part number for the part for your current bike, it shows all the other bikes that also take the same part. In the case of a front caliper for an ABS Silverwing, 2003-2013 use ths ame front brake calliper assembly.
https://www.partzilla.com/product/honda/45150-MCT-911?ref=cd629c4449a7d28bac4d629b61cbe1144495540d |
