| Drive faces | |
DavidinDunnellon Scooter Rider
Number of posts : 26 Age : 75 Location : Dunnellon, FL Points : 915 Registration date : 2022-04-19
| Subject: Drive faces Mon Sep 02, 2024 3:52 pm | |
| Doing some maintenance in preparation for a trip to Georgia mountains. Pulled the drive face off found grooves about .020 of an inch deep on the top and bottom. Should I clean them up or just leave them alone? A new belt is going on. |
JohnyC Touring Scooter Rider
Number of posts : 348 Age : 71 Location : Bristol, UK Points : 989 Registration date : 2022-12-23
| Subject: Re: Drive faces Mon Sep 02, 2024 6:59 pm | |
| Hi David.
Any chance of a couple of photo's please. With 20k under it's belt it will show wear marks, although there's no tolerance limits in the manual covering it. Mine has 20k+ miles on it, and showing wear marks but runs just fine despite my tinkering and tweaking, hence the request for photo's.
Hope this helps.
Be safe, be seen! |
steve_h80 Silver Wing Guru
Number of posts : 1022 Location : Teesdale, UK Points : 4149 Registration date : 2016-05-15
| Subject: Re: Drive faces Tue Sep 03, 2024 1:19 am | |
| That's only about 0.5mm, I wouldn't worry about. CVT's are pretty much self adjusting. |
zrx212 Silver Wing Expert
Number of posts : 554 Age : 65 Location : Ocala, FL Points : 1931 Registration date : 2020-12-26
| Subject: Re: Drive faces Tue Sep 03, 2024 9:58 am | |
| The pulley faces should always be sanded down slightly to smooth down any ridges or wear pattern left by old belt, it's kind of like smoothing out "The Bumps in the Road" for the new belt, also helps new belt "Break-In" quicker and establish its own wear pattern. I use a flat sanding block with new 150 grit sandpaper, just sand in a random/even pattern, at a minimum rough up with some red Scotch Brite pad. Obviously clean all belt contact areas.
BTW, less than 1 hour away if you need a hand, LMK. |
| Subject: Re: Drive faces Wed Sep 04, 2024 12:08 pm | |
| Hi David.
OOOH..... Thanks for the pictures, is it 2 pictures of the same drive face, or 1 of each drive face? Either way it looks to me as if someone's been rather aggressive with the throttle using a well stretched belt for some time. The grooving being caused by the reinforcement added to the middle of the drive belt, hence the 2 distinct marks and the darker area (belt burn/slipping) under the outer circle. A quick google found an OEM in Japan (only the driven side) hence the ? about the photos, are both faces as bad? Your not going to clean those marks out in a hurry. Just my personal opinion and not an invite for a bun fight! Maybe go for second hand units. There were 2 swings being dismantled state side the other week (listed on here).
Hope this helps. Be safe, be seen! |
| Subject: Re: Drive faces Wed Sep 04, 2024 10:36 pm | |
| FYI, in the USA at online retailers like Ron Ayers, etc., The 2 front pulley faces are approx. $100 usd, rear 2 are approx. $200, NEW !, I know this because I've purchased/have them in my squirrel stash. |
| Subject: Re: Drive faces Thu Sep 05, 2024 2:29 pm | |
| Separate drive faces. I thought they were a little too deep. I have the ability to machine them smooth again. It appears that there is enough meat to do it. Any thoughts? If the same angle is maintained it should all find it's way... I think The belt that is on it is still within service limits and passes visual inspection. So I assume this was done prior to to the install of this belt. I've put about 2000 mi. on it since I bought it and I'm all about steady and smooth! |
| Subject: Re: Drive faces Thu Sep 05, 2024 3:05 pm | |
| Firstly, thanks for the insight zrx212, wish it was that easy in the UK.
Hi David, the back pair should be ok, it's only the front that will suffer from Blunt Force Impact due to the nature of how the front Variator works. Seems you have alternatives, either machine it out a little, buy second hand, or buy new (Ref zrx212). Let us know how you get on.
Be safe, be seen! |
| Subject: Re: Drive faces Thu Sep 05, 2024 5:18 pm | |
| If you have a way to bring scooter to my home in the "Silver Springs Shores" area (Southeast Ocala, about 1hr. away). I'll be more than happy to get your cvt squared away. Really need to look at all pulley faces, etc., but unless the damage is very critical, most are reusable with some sanding, etc. Just cover any consumables, cleaners, sandpaper, etc. BTW, I have plenty parts JIC ... |
| Subject: Re: Drive faces Thu Sep 05, 2024 5:21 pm | |
| BTW, any machining work on pulleys probably cost more than parts, local machine shops are a rarity nowadays. |
| Subject: Re: Drive faces Fri Sep 06, 2024 10:22 am | |
| Thank you for the great input. It's always good to bounce things off of those with greater experience. zrx212 I'll PM you. |
| Subject: Re: Drive faces Sat Sep 07, 2024 12:12 pm | |
| Here is the finished product after machining and sanding. Worked out well. Only took about .018 off of each face. I'll let you know how it works out Figured I saved about $250 -#300.
OK I don't see the pics.. - Attachments
- (191 Kb) Downloaded 5 times
| Subject: Re: Drive faces Sat Sep 07, 2024 12:14 pm | |
Number of posts : 1600 Age : 62 Location : South East England Points : 4685 Registration date : 2016-10-01
| Subject: Re: Drive faces Sat Sep 07, 2024 2:38 pm | |
| I'd be interested to see how it works out. Mine are showing signs of similar wear. Keep us posted. |
| Subject: Re: Drive faces Sat Sep 07, 2024 9:57 pm | |
| " Here is the finished product after machining and sanding. Worked out well. Only took about .018 off of each face. I'll let you know how it works out Figured I saved about $250 -#300. " Theoretically cutting the faces will allow belt to sit lower in the front pulley, possibly giving you overall lower gearing, better acceleration ?, lower top speed ?, the best way to check how the cut/sand affects operation is to drive it, you can also make a "Sharpie" stripe on pulley face to see the actual belt travel range. BTW, both front pulleys retail for $64.08 + $37.32 = $101.40 + tax + shipping at Ron Ayers today (USA). Few important details when reassembling the cvt. 1. Make sure you hold the inner variator pulley assy. fully collapsed as you slide into engine shaft, don't let rollers move out of place. 2. Never allow the belt to bind in the front pulleys while tightening/torquing bolt, otherwise you may get a false tight !! if you bind on belt, collapse belt into rear pulley as needed to loosen, should be able to spin rear pulley and belt move freely on front pulley, this video may help. 3. The variator bolt + washer should be lightly oiled if you are "properly torquing" 4. A very, very light coat of high temp grease is all you need on variator bushing. https://www.youtube.com/watch?v=xYd9AmiHMRc |
| Drive faces | |
