headlight modulator I_icon_minitimeby zrx212 Yesterday at 4:40 pm
headlight modulator I_icon_minitimeby Meldrew Yesterday at 4:37 pm
headlight modulator I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
headlight modulator I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
headlight modulator I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
headlight modulator I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
headlight modulator I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
headlight modulator I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
headlight modulator I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
headlight modulator I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
 headlight modulator
crahar
edwardwr
Eldon
8 posters
Eldon
Eldon
Number of posts : 42
headlight modulator Empty
PostSubject: headlight modulator   headlight modulator I_icon_minitimeTue Jun 15, 2010 11:10 pm
any recent experience with the kisan brand of plug and play modulator are any other simlar kind headlight modulator 186319
Number of posts : 1995
PostSubject: Re: headlight modulator   headlight modulator I_icon_minitimeWed Jun 16, 2010 8:05 am
Eldon,
I've never heard of a bad experience with one of their modulators. Mostly I recall hearing about the ease with which it is installed. I do not know if it is truly plug and play as there is some wiring that needs to be run to accomodate the sensor that disables the modulator in low light conditions.
Eldon
Eldon
PostSubject: Re: headlight modulator   headlight modulator I_icon_minitimeThu Jun 17, 2010 8:22 pm
the state of iowa has a deal where they will pay $150 for the purchase and installation for a headlight modulator done thru a iowa motorcycle dealer association member. the two i went to told me 4to 5 hours labor and 100 for the kisan plug and play modulator. am i wrong are does take any more than 5 minutes to the get to the high beam and zip tie and light sensor.
PostSubject: Re: headlight modulator   headlight modulator I_icon_minitimeFri Jun 18, 2010 5:04 am
Eldon,
Good question, and I can not answer it. Any one who has installed a headlight modulator care to chime in on this?
edwardwr
Number of posts : 5
Registration date : 2009-05-12
PostSubject: Re: headlight modulator   headlight modulator I_icon_minitimeFri Jun 18, 2010 8:53 am
I have a Kisan "plug and play" on my Goldwing and a hardwired unit on the Silverwing. The plug and play is the way to go. For the S'wing you should remove the small panel below windscreen (4 screws) to run the sunlight sensor up along side the windshield so that it "sees" the sky, 10 minutes total, you can access the high beam blub from under the fairing above the front tire. World of difference in being seen, and I think, next to a helmet, the easiest safety device to add.
After 38+ years in Law Enforcement, Fire Service and EMS the common theme I've heard in crashes is always "I didn't see them".
Ed
PostSubject: Another source   headlight modulator I_icon_minitimeSun Jul 04, 2010 3:47 am
Not to put down Kisan or any other brand, but I have installed the HMs from Comagination on four different scooters.
http://www.comagination.com/modBulb.htm is their URL and I have had excellent results each time. The product is fully potted, tiny, and only requires that you pull the socket from the headlight, plug in the HM and then plug the socket from the HM onto the light. It can be done without removing any tupperware, but I am too clumsy.
I have also, each time, installed their brake light flashers. That does require breaking the hot wire and putting it in-line. (I use Posi-lock taps rather than the 3M taps as the Posi-Locks do not nick the wires.)
crahar
crahar
Number of posts : 283
Registration date : 2009-08-31
PostSubject: Re: headlight modulator   headlight modulator I_icon_minitimeSun Jul 04, 2010 2:16 pm
Mine was on the Swing when I got it, took me a while to figure out what that thing sticking up behind the left master cylinder was, still think it was an odd place for the headlight sensor.
ronjr009
ronjr009
Number of posts : 180
PostSubject: Re: headlight modulator   headlight modulator I_icon_minitimeSun Jul 04, 2010 3:27 pm
I have a comagination modulator on my helix. It has worked flawlessly for 4 years. I really need to get one on my Silverwing. I am sure that it has kept someone from pulling out in front of me on at least several occassions.
Eldon
Eldon
PostSubject: 2 or 3 pin plug   headlight modulator I_icon_minitimeTue Jul 06, 2010 5:19 pm
does the silver have a 2 or 3 pin plug for high beam just figuring out which kisan modulator to have ordered
Number of posts : 2778
PostSubject: Re: headlight modulator   headlight modulator I_icon_minitimeTue Jul 06, 2010 5:30 pm
Hi Eldon, I just looked at the wiring diagram and it looks like 2 wires/pins. headlight modulator Icon_smile
Eldon
Eldon
PostSubject: Re: headlight modulator   headlight modulator I_icon_minitimeTue Jul 06, 2010 5:34 pm
thank you 1600 miles in 2 months and counting
PostSubject: Re: headlight modulator   headlight modulator I_icon_minitimeTue Jul 06, 2010 5:37 pm
I guess I need to get out and ride more. headlight modulator Kopfschuettel
Eldon
Eldon
PostSubject: Re: headlight modulator   headlight modulator I_icon_minitimeTue Jul 06, 2010 10:49 pm
which kisan modulator works on the silverwing they list at least 3 I just want the one headlight modulator which they have two types
PostSubject: Re: headlight modulator   headlight modulator I_icon_minitimeWed Jul 07, 2010 2:19 am
I installed a Kisan modulator about four years ago on my Goldwing. It's worked flawlessly and only took about 20 minutes to install. Getting at the head light took most of the time. Mounting the sensor is quick and easy. I need two more now one for the Silverwing and one for the Goldwing 1800 I just picked up.
Number of posts : 2008
PostSubject: Re: headlight modulator   headlight modulator I_icon_minitimeWed Jul 07, 2010 2:50 am
If you are unsure which model to use, call or emal kisan directly.
headlight modulator
» Headlight Modulator
» Kisan headlight modulator
» Modulator Sensor?
» Brake Modulator, Tap A Taillight, AND a QUAD LED License Frame
» Worlds Smallest Headlight Modulator.
