Questions on HyperPro springs install I_icon_minitimeby sonuvabug Today at 4:19 pm
Questions on HyperPro springs install I_icon_minitimeby sonuvabug Today at 4:17 pm
Questions on HyperPro springs install I_icon_minitimeby sonuvabug Today at 4:06 pm
Questions on HyperPro springs install I_icon_minitimeby JohnyC Yesterday at 10:04 am
Questions on HyperPro springs install I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Questions on HyperPro springs install I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Questions on HyperPro springs install I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Questions on HyperPro springs install I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Questions on HyperPro springs install I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Questions on HyperPro springs install I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
MikeH
Number of posts : 2387
Questions on HyperPro springs install Empty
PostSubject: Questions on HyperPro springs install   Questions on HyperPro springs install I_icon_minitimeThu Jul 29, 2010 1:14 am
x
MikeH
MikeH
Number of posts : 74
Registration date : 2009-05-02
PostSubject: Re: Questions on HyperPro springs install   Questions on HyperPro springs install I_icon_minitimeThu Jul 29, 2010 2:28 am
1) Use an impact wrench. I wouldn't attempt this job without one.
2) IIRC they did 'fly off' but they didn't fly far. You can keep pressure on the
cap with the impact wrench, but as soon as the last thread of off, you will
probably be holding the wrench at a slight angle and the parts will fly in the
opposite direction. Wear safety glasses!
3) It is a little difficult, but not really too bad. This is the advantage of the
impact wrench - you can put your weight on the parts to compress the spring and
let the impact wrench do the tightening. The impact wrench really makes it
easier.
4) After I got the caps back on with the impact wrench I tightened them with the
torque wrench. Again - have a helper there to hold the forks while you work on
them.
5) I re-used the old bolts.
Take your time, use an impact wrench, have a helper, wear safety glasses. Have
a clean surface where you can lay the parts out in the order they are
disassembled. That will help you reassemble in the proper order.
It's not that difficult. If you can change oil, you can change the fork springs.
Hope this helps. Good luck!
Mike H.
walmac
walmac
Number of posts : 36
PostSubject: Re: Questions on HyperPro springs install   Questions on HyperPro springs install I_icon_minitimeThu Jul 29, 2010 4:37 am
Hi Terry
I removed the Fork cap this way-
With the fork legs removed I wrapped the end of the leg with masking tape then fitted two Jubilee clips (hose clips) onto the leg.The fork leg was then
put in a vice using the heads of the clips to hold it,the caps came off easily then,also used this method to refit and torque the caps.
When removing the pinch bolts holding the fork legs I used a short reach 14mm socket which gave a bit more room to undo bolts and same when torqueing them up.
Hope this helps
Wal.
PostSubject: Re: Questions on HyperPro springs install   Questions on HyperPro springs install I_icon_minitimeThu Jul 29, 2010 9:35 am
Thank you Mike and Wal. That's exactly the information I was looking for.
Terry
Hammy
Hammy
Number of posts : 362
PostSubject: Re: Questions on HyperPro springs install   Questions on HyperPro springs install I_icon_minitimeThu Jul 29, 2010 10:00 am
Um... silly question cos I tend to be ignorant of a lot of the mechanics of bikes... what do the Hyperpro springs do?
Number of posts : 2008
PostSubject: Re: Questions on HyperPro springs install   Questions on HyperPro springs install I_icon_minitimeThu Jul 29, 2010 10:10 am
Primarily they reduce front end dip on stopping, reduce how much of a pothole you feel, and generally give you a significant improvement in both feel and handling.
Its one of the first upgrades we recommend to new silverwingers, right up there with adding lighting, changing the windscreen, and changing the interior light switch.
Dan
MaxB
MaxB
Number of posts : 302
PostSubject: Re: Questions on HyperPro springs install   Questions on HyperPro springs install I_icon_minitimeThu Jul 29, 2010 10:21 am
I agree with dave.
Just be careful when putting the fork cap back on so you dont crossthread the cap.
i did not use an impact wrench for the above reason. It can be done.
maxB
» HyperPro Springs
» Hyperpro Springs in UK
» Hyperpro Progressive Springs
» HyperPro Progressive Springs
» Fitting hyperpro front springs
