12 volt cigarette lighter adapter I_icon_minitimeby zrx212 Yesterday at 4:40 pm
12 volt cigarette lighter adapter I_icon_minitimeby Meldrew Yesterday at 4:37 pm
12 volt cigarette lighter adapter I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
12 volt cigarette lighter adapter I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
12 volt cigarette lighter adapter I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
12 volt cigarette lighter adapter I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
12 volt cigarette lighter adapter I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
12 volt cigarette lighter adapter I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
12 volt cigarette lighter adapter I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
12 volt cigarette lighter adapter I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
Hammy
ehaughn
ehaughn
ehaughn
Number of posts : 131
Registration date : 2010-06-13
12 volt cigarette lighter adapter Empty
PostSubject: 12 volt cigarette lighter adapter   12 volt cigarette lighter adapter I_icon_minitimeFri Aug 06, 2010 12:25 pm
Here are some pictures of how I installed the cigarette ligter adapter in the glove box.
(106 Kb) Downloaded 176 times
(63 Kb) Downloaded 141 times
ehaughn
ehaughn
PostSubject: Re: 12 volt cigarette lighter adapter   12 volt cigarette lighter adapter I_icon_minitimeFri Aug 06, 2010 12:27 pm
Here are a few more pics
(92 Kb) Downloaded 122 times
(104 Kb) Downloaded 106 times
Hammy
Hammy
Number of posts : 362
PostSubject: Re: 12 volt cigarette lighter adapter   12 volt cigarette lighter adapter I_icon_minitimeSat Aug 07, 2010 9:36 am
That's how mine is set up too. What I don't like is having to sandwich the cables coming out of the glovebox as I run a line to my GPS, one to my helmet, and another to my phone on my belt. Wish there was a way to have them all come out without being pressed on when I close the lid to lock it...
Number of posts : 3837
PostSubject: Re: 12 volt cigarette lighter adapter   12 volt cigarette lighter adapter I_icon_minitimeSat Aug 07, 2010 10:13 am
Hammy
Hammy
PostSubject: Re: 12 volt cigarette lighter adapter   12 volt cigarette lighter adapter I_icon_minitimeSat Aug 07, 2010 10:57 am
Nice... but I have about 3 different things with a whole bunch of different cable lengths plugged in, so I usually prefer to keep everything hidden inside the cubby... Rain never gets in there and I've been in some pretty crazy downpours and storms! I'm just worried about the cables being pinched -- I'm also worried that if I notch the cubby lid, that I'll lose the waterproofing... UNLESS I can figure out a way to make a rubber gasket of sorts...
crahar
crahar
Number of posts : 283
Registration date : 2009-08-31
PostSubject: Re: 12 volt cigarette lighter adapter   12 volt cigarette lighter adapter I_icon_minitimeSat Aug 07, 2010 9:22 pm
Have you considered a hole through the side of the pocket and running the wires through a grommet then up alongside the wiring harness up to the handle bars. I have ran a wire from the battery up to the center of the handlebars for my 2meter transceiver as well as the coax for the antenna.Make sure and use fuses however you you run your wires, depending on what your running you might want to use relays as well. Also used tubeing for protecting wires.
Craig
Hammy
Hammy
PostSubject: Re: 12 volt cigarette lighter adapter   12 volt cigarette lighter adapter I_icon_minitimeSun Aug 08, 2010 12:29 am
How did you run that wire from your battery? sounds like a ton of tupperware to take off?
PostSubject: Re: 12 volt cigarette lighter adapter   12 volt cigarette lighter adapter I_icon_minitimeSun Aug 08, 2010 7:02 am
ehaughn
ehaughn
PostSubject: Re: 12 volt cigarette lighter adapter   12 volt cigarette lighter adapter I_icon_minitimeSat Aug 14, 2010 8:13 am
My thought was to run the wiring through the backside of the glove box, then up through the steering/handlebar area. Have not done this yet.
BTW, running the wire from the battery to the glove box was simple, I did not have to remove any body panels. I used small wooded dolls rods to fish the wiring through the body work.
Erick
Number of posts : 2778
PostSubject: Re: 12 volt cigarette lighter adapter   12 volt cigarette lighter adapter I_icon_minitimeSat Aug 14, 2010 8:21 am
HI, What I've been doing is running the wiring through the left foot rest (floor board)support tube and no tupperware removal is needed. Easy to do!
crahar
crahar
PostSubject: Re: 12 volt cigarette lighter adapter   12 volt cigarette lighter adapter I_icon_minitimeSat Aug 14, 2010 2:41 pm
I went the hard way just to learn how, I pulled the Tupperware off and ran four extra wires all labeled so I could know what I was working with in the future with enough coiled up at each end to run them where ever I might need or want. I also ran a ground wire with terminal block at front for future connections.Added a relay switched with the key and additional fuses same two bladed as original(picked up holder at Tractor Supply) I think I have enough extra wires for any future add-ons. If not it won't be that hard to use one of the ones I added to pull some extra ones.
Craig
MaxB
MaxB
Number of posts : 302
PostSubject: Re: 12 volt cigarette lighter adapter   12 volt cigarette lighter adapter I_icon_minitimeSat Aug 14, 2010 5:31 pm
Crahar, that's how I am doing mine. I will have 2 hot all the time and 2 switched on relays. I will have only 1 spare. All my fuses are in the same location as OEMS.
Max B.
» cigar lighter socket
» Adapter for car disc, for Honda Silver Ving Scooter.
» Brake light adapter by Dennis B
» Plug and play power adapter
» 12 volt Port
