| Disc brake drag? | |
| Subject: Disc brake drag? Fri Sep 10, 2010 6:50 pm | |
| Subject: Re: Disc brake drag? Fri Sep 10, 2010 7:50 pm | |
| To get it as free as possible....after you are sure rams are retracting(there will always be some drag) leave fork legs a little loose in clamps(not much) insert axle and see if it as drawn tight draws the whole works in alignment---might work
Another trick to get get things for sure pointing the way they should--- put bike on ground, axle a little loose, fork legs just a little backed off----hold bike with front brake stuff might self align as you bounce it up and down.
John Grinsel |
edbancro Maxi-Scooter Rider
Number of posts : 160 Location : Western Pennsylvania Points : 5684 Registration date : 2009-10-30
| Subject: Re: Disc brake drag? Fri Sep 10, 2010 10:49 pm | |
| BigBird,
I think some sound is normal, but I agree that it probably should rotate more freely than that. Did you check it again after the ride? Maybe they just needed to self-adjust a little.
Also, did you follow that tightening sequence on the front axle and its pinch bolts (involves some bouncing like John mentioned)? If that were a little off I could maybe see it causing a little extra drag (although you'd probably get other symptoms, too). I forgot that when I did mine, and had to go back and loosen/re-tightened it later; I felt like it made a little difference in the overall feel, but that might have just been in my head... |
| Subject: Re: Disc brake drag? Fri Sep 10, 2010 11:32 pm | |
| Subject: Re: Disc brake drag? Fri Sep 10, 2010 11:50 pm | |
| Well, maybe they're okay (I'd check mine to compare if my jack weren't buried in the shed and somewhat inaccessible). A few miles on the highway should tell you one way or the other - if you have to drag your shoes to stop, then you'll know they were grabbing |
| Subject: Re: Disc brake drag? Sat Sep 11, 2010 12:57 am | |
MaxB Touring Scooter Rider
Number of posts : 302 Age : 73 Location : Indiana Points : 5885 Registration date : 2009-10-06
| Subject: Re: Disc brake drag? Sat Sep 11, 2010 6:16 am | |
| just ride , it's normal to have some drag. As you ride the shoes will heat up and move the pistons back further. The shoes always touch the disk. Thus some drag.
MaxB |
| Subject: Re: Disc brake drag? Sat Sep 11, 2010 10:39 am | |
| 1) Double check wheel position (as suggested already)
2) Change the brake fluid. Changing the brake fluid stopped a lot of rubbing for me.
3) I remember reading a FEW rare situations where the disk brake warped from overheating and needed to be replaced ... but I would exhaust all possibilities before replacing the disk brake. |
| Subject: Re: Disc brake drag? Sat Sep 11, 2010 10:44 am | |
