| transmission 'oil' | |
+4MikeO BlackFly DennisB Texas Viper 8 posters |
Texas Viper Scooter Rider
Number of posts : 3 Points : 5025 Registration date : 2010-12-10
![transmission 'oil' Empty](https://2img.net/i/empty.gif) | Subject: transmission 'oil' Sat Dec 11, 2010 6:07 pm | |
| I see mixed messages of the suggested lubricant to use in the transmission(not even mentioned in the owner's handbook, by the way). I use 'gear oil' in my Aprilia's and some of the forum guys say use 'regular' engine oil - - - ok, what's the best. Also - - how much? I can always measure the stuff that comes out but I'd rather know what should be in there - - help me out - - thanks,
tj |
![transmission 'oil' Empty](https://2img.net/i/empty.gif) | Subject: Re: transmission 'oil' Sat Dec 11, 2010 6:38 pm | |
| Hey Texas Viper,
Most of use just go with what the shop manual states, and that is the same oil you use in the motor.
BlackFly Maxi-Scooter Rider
![BlackFly](https://2img.net/u/3413/63/00/33/avatars/974-99.jpg)
Number of posts : 151 Age : 45 Location : Germany Points : 5218 Registration date : 2010-11-20
![transmission 'oil' Empty](https://2img.net/i/empty.gif) | Subject: Re: transmission 'oil' Sat Dec 11, 2010 7:01 pm | |
| You need 0,32l if you change the oil. I don't know, do you know liter? ![Wink](https://2img.net/i/fa/i/smiles/icon_wink.gif) 0,32liter are 0,34 US Quarts |
![transmission 'oil' Empty](https://2img.net/i/empty.gif) | Subject: Re: transmission 'oil' Sat Dec 11, 2010 7:06 pm | |
![transmission 'oil' Empty](https://2img.net/i/empty.gif) | Subject: Re: transmission 'oil' Sat Dec 11, 2010 7:16 pm | |
| Good job with the pictorial section! I only have the problem that i'm a german guy and i have no idea how much 10oz are ![Wink](https://2img.net/i/fa/i/smiles/icon_wink.gif) I try my best and give this information from my german garage manual but i have to convert the values because i think you have the same problem with liter like me with oz ![Wink](https://2img.net/i/fa/i/smiles/icon_wink.gif) The used oil in the pictorial 75-90w is it the normal engine oil? Because the engine oil is called 10w40 in germany... |
![transmission 'oil' Empty](https://2img.net/i/empty.gif) | Subject: Re: transmission 'oil' Sat Dec 11, 2010 7:22 pm | |
| Easy...Put in bottom drain plug, after draining old oil, then install bottom plug. Then add oil into the top filler hole until it starts to come out and then screw in the top stopper. Your done. I use 10W40 also. |
![MikeO](https://2img.net/u/3413/63/00/33/avatars/308-62.jpg)
Number of posts : 3819 Age : 75 Location : Seaham, Co Durham, UK Points : 9613 Registration date : 2009-06-29
![transmission 'oil' Empty](https://2img.net/i/empty.gif) | Subject: Re: transmission 'oil' Sun Dec 12, 2010 7:00 am | |
| 1 fl oz us = 30ml Therefore 10fl oz = 300ml 1 fl oz imp = 28ml ![Smile](https://2img.net/i/fa/i/smiles/icon_smile.gif) |
![transmission 'oil' Empty](https://2img.net/i/empty.gif) | Subject: Re: transmission 'oil' Sun Dec 12, 2010 8:44 am | |
| Thanks everybody - - My Aprilias (both the little Mojito and the big Scarabeo) use gear oil so I opted for 'Bey-Ray' hypoid gear oil - SAE 80w-90. Anybody see any reason I shouldn't use this stuff in the Wing too? |
![transmission 'oil' Empty](https://2img.net/i/empty.gif) | Subject: Re: transmission 'oil' Sun Dec 12, 2010 9:03 am | |
| It is not the recommended from Honda but i think there is no technical issue to do not use it, possibly it can be the better oil for this purpose regardless the recommandation from Honda. I think both will work but if you have garantee it can be a problem in case of a defect! |
Slick-Tenn Scooter Rider
Number of posts : 47 Points : 5222 Registration date : 2010-07-19
![transmission 'oil' Empty](https://2img.net/i/empty.gif) | Subject: Re: transmission 'oil' Sun Sep 04, 2011 5:25 pm | |
| - Texas Viper wrote:
- I see mixed messages of the suggested lubricant to use in the transmission(not even mentioned in the owner's handbook, by the way). I use 'gear oil' in my Aprilia's and some of the forum guys say use 'regular' engine oil - - - ok, what's the best. Also - - how much? I can always measure the stuff that comes out but I'd rather know what should be in there - - help me out - - thanks,
tj Sorry! Honda will NOT convince me that 10W30 MOTOR OIL will adequately lube TRANSMISSION GEARS. I use Amsoil 80/90 synthetic gear lube. |
GaryL Super Scooter Rider
![GaryL](https://2img.net/u/3413/63/00/33/avatars/690-51.jpg)
Number of posts : 237 Age : 72 Location : Casa Grande, Arizona Points : 5433 Registration date : 2010-07-09
![transmission 'oil' Empty](https://2img.net/i/empty.gif) | Subject: Re: transmission 'oil' Sun Sep 04, 2011 6:59 pm | |
| I agree with a comment made by BigBird on another post. Don't second guess Honda on this. They are way smarter than most of us. I have had a number of Honda cars with manual transmissions, and guess what they recomment for transmission oil? 10W30... the same thing that goes in the crankcase. I put in Mobile-1, and ran it for 200,000 miles with the smoothest shifting transmission I ever had. No problems of ANY sort. You will NOT convince me that Honda does not know what they are doing.
Last edited by GaryL on Sun Sep 04, 2011 7:04 pm; edited 1 time in total (Reason for editing : Spelling correction.) |
AAAA Silver Wing Rider
Number of posts : 442 Points : 5575 Registration date : 2010-11-14
![transmission 'oil' Empty](https://2img.net/i/empty.gif) | Subject: Re: transmission 'oil' Mon Sep 05, 2011 2:05 am | |
| - GaryL wrote:
- I agree with a comment made by BigBird on another post. Don't second guess Honda on this. They are way smarter than most of us. I have had a number of Honda cars with manual transmissions, and guess what they recomment for transmission oil? 10W30... the same thing that goes in the crankcase. I put in Mobile-1, and ran it for 200,000 miles with the smoothest shifting transmission I ever had. No problems of ANY sort. You will NOT convince me that Honda does not know what they are doing.
+1 on Bigbird. My manual ford ranger uses motor oil as well. I use 10-30 mobil one t4 synth n my Silverwing, front and back. |
bob wells Maxi-Scooter Rider
![bob wells](https://2img.net/u/3413/63/00/33/avatars/1458-72.jpg)
Number of posts : 107 Age : 74 Location : Idaho Points : 4930 Registration date : 2011-07-06
![transmission 'oil' Empty](https://2img.net/i/empty.gif) | Subject: Re: transmission 'oil' Mon Sep 05, 2011 11:04 am | |
| After having worked for and with Honda for 25+ years in motorcycle, Honda car and Acura, I pretty much trust what they have to say.
Bob |
