tankyuong Silver Wing Rider
Number of posts : 475 Age : 49 Location : Missouri Points : 6297 Registration date : 2009-07-12
| Subject: Harder to start with Power commander Tue Jan 04, 2011 11:01 am | |
| Ever since I installed the power commander I notice more power but the engine would stall the first time and fire up on 2nd try.also the engine would die if I accidentally press the start button while engine is running.anyone else have this problem? |
| Subject: Re: Harder to start with Power commander Tue Jan 04, 2011 11:42 am | |
| Maybe try tech support at:
http://www.powercommander.com/powercommander/Contact/powercommander_technical_support.aspx |
| Subject: Re: Harder to start with Power commander Tue Jan 04, 2011 1:54 pm | |
| - tankyuong wrote:
- Ever since I installed the power commander I notice more power but the engine would stall the first time and fire up on 2nd try
I just give a little more throttle on startup. You could slowly adjust the 0 MPH/ 0 % throttle ( closer to 0 ) to see what would work for you. - tankyuong wrote:
- also the engine would die if I accidentally press the start button while engine is running.
I have only done this once ... and as I recall it did not stall. |
dspevack Silver Wing Guru
| Subject: Re: Harder to start with Power commander Tue Jan 04, 2011 6:48 pm | |
| Programming may be off on the PC. If you have the one with the USB interface, try reloading the map.
Dan |
