Latest topics | » Passenger Back rest by landisr Yesterday at 7:02 pm
» OE Quality Drive Belt by landisr Wed Oct 16, 2024 1:11 pm
» Mini-Mate Camper by MikeO Wed Oct 16, 2024 7:17 am
| | Shakey silverwing | |
lesley & John Maxi-Scooter Rider
Number of posts : 113 Age : 53 Location : bristol uk Points : 5324 Registration date : 2010-09-19
| Subject: Shakey silverwing Wed Jan 12, 2011 1:07 pm | |
| Hi all had the forks done now a strange one the scoot wobbles like mad if I take both hands of below 30mph I only done this because I used to take my hands of on motorbikes to see how they were balanced the scoot handles fine just wondering if any one else has ever done this and had the same effect |
| | | BlackFly Maxi-Scooter Rider
Number of posts : 151 Age : 45 Location : Germany Points : 5258 Registration date : 2010-11-20
| Subject: Re: Shakey silverwing Wed Jan 12, 2011 1:34 pm | |
| I think the shimmy is "normal" you can hear nearly everywhere about this. But you can try to change the tire (brands), play a little bit with the tire press, take higher weight on the steering bar ends and possibly is the headset bearing worn... I have less shimmy if i raise the tire press to 2,2bar on the front and 2,5bar in the rear (sorry, i forgott 32psi / 36psi) and i will change the tires from hoop to Feelfree Wintec at the end of summer and hope this will fix the shimmy |
| Subject: Re: Shakey silverwing Wed Jan 12, 2011 1:49 pm | |
| Cheers for that didn't know they all did that to some extent my back tyre has only half mm to wear limit so might renew as a pair at end of month this site is so useful cheers all |
| Subject: Re: Shakey silverwing Wed Jan 12, 2011 1:56 pm | |
| Do all this? I don't know but i hear/read very often this... And normaly there is no 100% solution for this. It could be (and seems to be in this case) a little problem in the construction, it can be a problem of tire, tire press, imbalance of the tire, the bearing, weights of steering bar, it can be caused by aerodynamic (including topcase!) and many others. All that you can do: Testing/Trying or ignore it But if your tires are worn it also properly can be that it will be fixed after replacement |
| | | J.R. Scooter Rider
Number of posts : 32 Age : 69 Location : Watertown, Minnesota Points : 5567 Registration date : 2009-08-25
| Subject: Re: Shakey silverwing Wed Jan 12, 2011 6:03 pm | |
| I had the same thing on my 02...I found out that the rear tire was worn when I went to a dealer to get it checked out. Put a new tire on and handlebar shake went away. Hope that helps, J.R. |
| | | Guest Guest
| Subject: Re: Shakey silverwing Wed Jan 12, 2011 7:14 pm | |
| iv'e had this wobble thing on a few bikes / scooters after fitting hard luggage.simple solution is don't take both hands off the handlebars.then it's never a problem. |
| | | Waspie Silver Wing Guru
Number of posts : 2392 Age : 72 Location : Portland, UK Points : 8113 Registration date : 2009-07-26
| Subject: Re: Shakey silverwing Wed Jan 12, 2011 7:41 pm | |
| I have never experienced the wobble you describe. When I first started out with the 'Wing' I did suffer a very fine vibration through the handle bars. Either it was me settling into a different ride ar the bike settling into me!!! Another theory I have regards my own circumstance is that I also use a tyre sealant which I reckon may have assisted in the dampening out of the vibration. I am wondering if that may aid curing your 'wobble'!!!! |
| | | Skippy Super Scooter Rider
Number of posts : 299 Age : 57 Location : Exeter. Devon. Points : 5532 Registration date : 2010-08-18
| Subject: Re: Shakey silverwing Thu Jan 13, 2011 6:21 am | |
| Lesley, To an extent I've got to agree with 'Phantom', don't let go and the issue wont arise But if the 'vibration' is/has become more intrusive, to the extent that it is an issue when riding then its most important to find the cause - vibration = damage! 'Black Fly' is right, look at all those areas, but having said that don't expect to 'cure' the problem. Some machines are sensitive to certain things i.e. my 650 hates BT45 tyres, the profile is all wrong and makes the bike feel like its falling into corners all the time and it also 'squirms' over white lines and overbanding. Yet if I use 'Cougar' tyres with a harder compound then its great; just the way things are! |
