| Low speed maneuvering | |
Jinglebob Super Scooter Rider
Number of posts : 297 Location : Sacramento Points : 6021 Registration date : 2009-07-18
| Subject: Low speed maneuvering Thu Feb 03, 2011 7:33 pm | |
| Went for a nice ride today. Only negative thing was that I nearly dumped the bike on a very sharp low speed turn. I get that with a CVT transmission, the idea is to keep the gas on a little to keep the clutch engaged while also using the rear brake to control the speed. In theory, that should work. In practice, it's a bit more difficult than that. The control is not nearly as precise as the friction zone in an ordinary motorcycle clutch. Looks like I need to do some more practicing somewhere... |
| Subject: Re: Low speed maneuvering Fri Feb 04, 2011 2:50 am | |
| As with any bike/scooter rear brake is/can be balancing aid---great for such as lane splitting, slow speed stuff. Good riders do it all the time. Practice. But PROBLEM: SilverWing 600 has linked brakes! But rear always seems to come on first.....even in low traction situations........but I hate idea of brake input to front at the time you want rear to straighten bike up or keep power to rear wheel in slow turn, etc. Also for experienced motorcyclists left hand brake sometimes hard in slow speed stuff.....foot brake better (see Helix/Vespa...old German scooters.) The linked braking system has proven safe for most riders---GoldWing, Moto Guzzi. Just from my standpoint takes a little of the fine control away.
If you are not experienced, practice in empty parking lot. But have goal for what you wish to accomplish. Ride everyday! SilverWing has a lot of power and can/could get away from you.
John Grinsel
John Grinsel |
Number of posts : 231 Age : 69 Location : Middleburg FL Points : 5350 Registration date : 2010-12-12
| Subject: Re: Low speed maneuvering Fri Feb 04, 2011 6:20 am | |
| Jinglebob,
You have the right idea; balance the brakes against the CVT engagement point. As JG alludes, it can be challenging at very low speeds due to the linked braking system. Be especially careful with the bars at sharp angles -- the natural tendency to grab more brake will engage too much up front and will cause the wheel to want to "fold under." Suggest you try using a little more throttle and left brake than you might think so you can get a better feel for the engagement point until you get used to it. Don't use the right lever at all at slow speeds unless you are completely vertical. |
Sweendog Maxi-Scooter Rider
Number of posts : 154 Location : South New Jersey Points : 5780 Registration date : 2009-07-12
| Subject: Re: Low speed maneuvering Fri Feb 04, 2011 9:27 am | |
| Sounds like you've got the right idea, getting used to the bike just takes practice. The linked brakes will never be a problem at low speed, unless you whale on the rear brake, which you shouldn't need to do at all to achieve decent control. The feel will be different from the friction zone on a manual transmission cycle for sure, but you can get the same results w/some trial and error. Empty parking lots are your friend. |
| Subject: Re: Low speed maneuvering Fri Feb 04, 2011 11:21 am | |
| Yep, great advice, as usual...
Power is not the problem...I get how to use that...the critical point is keeping the clutch engaged. Just a matter of some practice.
Hadn't thought about the linked brakes...forgot about that...suggests very gentle on the rear (left) brake to avoid having the front brake engage...
Hmmm.... |
| Subject: Re: Low speed maneuvering Fri Feb 04, 2011 12:23 pm | |
| You can easily learn when the front brake engages from the linked system, by doing some braking runs from 30-40 down to zero. Apply the rear-only fairly evenly and quickly, and you'll feel when the extra braking engages. On mine it's what I consider about 55-65% of the squeeze range. When riding slowly, you won't need much rear brake to keep the clutch engaged, so the chance of accidentally engaging the front brake is pretty slim.
Practice is the key though! |
| Subject: Re: Low speed maneuvering Fri Feb 04, 2011 1:00 pm | |
| https://www.youtube.com/watch?v=NegpNBY7DIc how about this for controlled riding. |
| Subject: Re: Low speed maneuvering Fri Feb 04, 2011 2:00 pm | |
Winger61 Silver Wing Rider
Number of posts : 452 Age : 75 Location : Louth, Lincolnshire, UK Points : 5634 Registration date : 2010-10-15
| Subject: Re: Low speed maneuvering Fri Feb 04, 2011 3:09 pm | |
| Says it all about the Wing, doesn't it!! |
| Subject: Re: Low speed maneuvering Fri Feb 04, 2011 4:39 pm | |
| Yep...it also says something about the rider...
As in many other activities and sports, an expert makes a thing look easy because of his or her competence. |
| Subject: Re: Low speed maneuvering Fri Feb 04, 2011 7:10 pm | |
| Says something about the rider and the Silverwing's low center of gravity. |
| Subject: Re: Low speed maneuvering Sat Feb 05, 2011 10:11 am | |
| That skill the rider is showing.....should be requirement to get license....and easy to do.
Notice brake light coming on each time he comes to cone----on scooter, matter of gas/brake control/coordination.....and keeping drive line loaded. looking where you are going.
With regular motorcycle gas/clutch/rear brake coordination. These skills are used in everyday riding---swerve,straighten up, brake, etc.
MSF does not cover much of this.
I watched film twice to make sure brake light was coming on. Anybody can do this with some practice. Teaches you also to trust tires. He is probably using feet, too, push right, go right, etc.
Even more fun with man size cones. There is no such thing as too much skill or practice.
John Grinsel
John Grinsel |
