| Heated grip wiring | |
steveR Super Scooter Rider
Number of posts : 218 Location : Shropshire, God's own county! Points : 5243 Registration date : 2011-03-23
| Subject: Heated grip wiring Fri Apr 01, 2011 3:43 pm | |
| I like having Oxford heated wrap arounds on my bikes and will be fitting the wiring next week on the Swing, time permitting. The accessory socket fitted by Honda is a piddling 1amp thing, fit only for a phone charger or a GPS so I need "MORE POWER"
I assumed that I would need to bring a decent supply in from the battery, then I read on another forum that the Swing already has a connection in the loom for grips!! Yee hah!
But where is it?? I have scoured the web looking for a pointer, but with no joy so far. Can anyone help me please? |
Number of posts : 2778 Age : 74 Location : NE Oklahoma Points : 9094 Registration date : 2008-12-28
| Subject: Re: Heated grip wiring Fri Apr 01, 2011 4:00 pm | |
| Hi Steve, How many amps does the grips (combined) draw? |
| Subject: Re: Heated grip wiring Fri Apr 01, 2011 4:30 pm | |
| - DennisB wrote:
- Hi Steve, How many amps does the grips (combined) draw?
As I recall, about 2.5amps, obviously a bit more load if I have a GPS attached too The socket on the Swing is 1amp, a bit pathetic really... |
| Subject: Re: Heated grip wiring Fri Apr 01, 2011 4:58 pm | |
| Subject: Re: Heated grip wiring Fri Apr 01, 2011 6:19 pm | |
| - DennisB wrote:
- Hi Steve,
OK...I'm going to plug my own plug. Have you read this:
https://www.silverwing600.com/t2858-head-light-connector-pigtail-plug-play
Just might get the job done for ya. I had seen your post Dennis, but I thought that your comment about low power suggested it was going to be only a 1-2 amp take off, similiar to that in the glove box.. When I saw mention of a tap into the loom for grips, I assumed that would have a 4-5amp load potential. I may well be wrong though, what power do the honda grips want I wonder? |
| Subject: Re: Heated grip wiring Fri Apr 01, 2011 7:02 pm | |
| Hi Steve, Will you have your grip warmers on high all the time or do they have a variable temp setting? Higher the temp setting the more the voltage draw. Just a thought. |
| Subject: Re: Heated grip wiring Sat Apr 02, 2011 8:15 am | |
| Well it looks like running a wire from your battery is what will give you piece of mined. Don't forget to install a fuse for this new wire and a relay. |
| Subject: Re: Heated grip wiring Sat Apr 02, 2011 3:09 pm | |
| - DennisB wrote:
- Well it looks like running a wire from your battery is what will give you piece of mined. Don't forget to install a fuse for this new wire and a relay.
True, but IF there is actually a plug in the wiring loom for fitting grips, it would seem daft for me to do this I have put a fused 12v power socket in the underseat area for powering compressors and the like, but I would like a higher power outlet up front too and if I don't have to run a twin cable from the battery, I am always keen on an easy life Dennis! |
| Subject: Re: Heated grip wiring Mon Apr 04, 2011 5:35 pm | |
| Well, I had a close look at a wiring diagram today, but I am blowed if I can see a point in the loom, but that may well just be me. I guess in the absence of a definitive confirmation of a power point being available, I will run a twin core lead to the front of the bike instead Thanks for the help Dennis" |
