Bought the mini light bar from Admore and the electrical adapter available thru this forum(thanks DennisB!) I brightened up the rear end tremendously. The light is ridiculously bright and flashes 3 times when I hit the brakes, and sweep flashes on turns. Great device.
Did not have to remove any plastic for the install. Took off the big metal guide that wraps around the seat, attached the bracket, and opened the trunk and a little compartment door popped open to give me access to the taillight wiring plug. Ran the wire to the trunk(easy nice space for it already there)popped DennisB's pigtail in, hooked up the wires and attached the light tot he bracket and now am much more visible.
