Added VistaCruise and Powerlet I_icon_minitimeby balconio Today at 7:24 pm
Added VistaCruise and Powerlet I_icon_minitimeby zrx212 Yesterday at 4:40 pm
Added VistaCruise and Powerlet I_icon_minitimeby Meldrew Yesterday at 4:37 pm
Added VistaCruise and Powerlet I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Added VistaCruise and Powerlet I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Added VistaCruise and Powerlet I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Added VistaCruise and Powerlet I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Added VistaCruise and Powerlet I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Added VistaCruise and Powerlet I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Added VistaCruise and Powerlet I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Buickguy
Buickguy
Number of posts : 86
Registration date : 2011-04-10
Added VistaCruise and Powerlet Empty
PostSubject: Added VistaCruise and Powerlet   Added VistaCruise and Powerlet I_icon_minitimeWed Apr 13, 2011 9:46 pm
I just finished up two minor mods on the S-Wing.
First, I added a VistaCruise throttle lock. I'm sure you are familiar with those.
Also added was a Powerlet/BMW style accessory plug.
I had BMW tourers in the 80s and really liked the positive engagement of the BMW type socket and plug over a cigarette lighter outlet. Since that time a company called Powerlet started making them for the aftermarket. Since I still have a bunch of BMW heated gear and other accessories, I've added at least one to every bike I've had, now including the S-Wing.
(115 Kb) Downloaded 77 times
(119 Kb) Downloaded 74 times
Number of posts : 771
PostSubject: Re: Added VistaCruise and Powerlet   Added VistaCruise and Powerlet I_icon_minitimeWed Apr 13, 2011 10:36 pm
Buickguy,
Bob put a Powerlet plug in the same spot on my Swing. Works well. We also have a Vista Cruise we need to put on still.
Cathy
Buickguy
PostSubject: Re: Added VistaCruise and Powerlet   Added VistaCruise and Powerlet I_icon_minitimeWed Apr 13, 2011 10:44 pm
They work well. That spot makes wiring easy and the PSO-007 low profile really fits well right there.
http://www.powerlet.com/shop-by-product/plugs-sockets-wire-more/PWRDIST
Number of posts : 3837
PostSubject: Re: Added VistaCruise and Powerlet   Added VistaCruise and Powerlet I_icon_minitimeThu Apr 14, 2011 1:24 pm
+1 for the 'positive engagement' - much better than ordinary cigar plugs and sockets.
Did you have to take off much tupperware to mount it?
Buickguy
PostSubject: Re: Added VistaCruise and Powerlet   Added VistaCruise and Powerlet I_icon_minitimeThu Apr 14, 2011 1:57 pm
All I had to pull was the left body panel and I took off the left passenger peg mount. With the low profile PSO-007 there is a spot near the end of the tunnel cover that has just enough clearance. I did measure about four times to make sure the pretty tupperware would not have an issue.
A 3/4 spade bit cut right through. I took positive off of where the battery cable attaches to the starter solenoid, a 15 amp fuse in the positive line for protection and ground comes from a chassis bolt. The entire wire run including fuse is about 8 inches for each wire. I used 14 gauge primary for current capacity. The good part of using the tunnel cover position is the cover from the outlet is the same matte black so the install is not obtrusive or aesthetically displeasing.
PostSubject: Re: Added VistaCruise and Powerlet   Added VistaCruise and Powerlet I_icon_minitimeThu Apr 14, 2011 2:07 pm
Thank you very much - with those instructions I think even I can do that. cheers
smorkle
smorkle
Number of posts : 201
Registration date : 2010-08-21
PostSubject: Re: Added VistaCruise and Powerlet   Added VistaCruise and Powerlet I_icon_minitimeThu Apr 14, 2011 5:29 pm
I cant see from the picture you posted, how did you mount the vista cruise little bar that goes across? Did you install the clamp that came with it or did you put it on the brake clamp?
PostSubject: Re: Added VistaCruise and Powerlet   Added VistaCruise and Powerlet I_icon_minitimeThu Apr 14, 2011 5:43 pm
Not all VistaCruise throttle locks are the same.The one I have doesn't have a little bar on it.
Buickguy
PostSubject: Re: Added VistaCruise and Powerlet   Added VistaCruise and Powerlet I_icon_minitimeThu Apr 14, 2011 6:47 pm
I got the VistaCruise model for Honda with two throttle cables. Unlike the universal, it doesn't have the bar across. There is a small tab that goes between the two throttle cables that holds it in place.
The worst part of the installation was the VistaCruise is just a touch tight on the throttle sleeve. even in the released positin it still held the sleeve. Using a bit of sandpaper on the VistaCruise would solve that. I used a Dremel sanding wheel which made short work of it. I did not need to remove much from inside diameter of the Vista Cruise.
The throttle grip had to be pulled away from the switch housing about 1/4 inch and a washer on the bar end weight moved that out enough for everything to clear.
PostSubject: Re: Added VistaCruise and Powerlet   Added VistaCruise and Powerlet I_icon_minitimeThu Apr 14, 2011 10:39 pm
Buickguy,
Yes that's the same one I have.I don't use it a lot but I would not be with out it.Christmas two years ago the local dealer had them for five dollars so I gave it a try and I like it.
smorkle
smorkle
PostSubject: Re: Added VistaCruise and Powerlet   Added VistaCruise and Powerlet I_icon_minitimeSun Apr 17, 2011 6:19 pm
I just installed my Vista Cruise universal. It said it fits most Hondas and others. It definitely does fit, but I'm worried about the operation of the thing. It doesn't have any sort of release mechanism tied to the brake so it will have to be manually released if it is set when you decide to brake. My biggest concern is that if you were in an emergency slow down situation you don't need one more thing to do to get the engine to return to idle. I haven't tested it out yet, but I plan to soon and I'll report back on how I think the thing operates.
AAAA
Number of posts : 442
Registration date : 2010-11-14
PostSubject: Re: Added VistaCruise and Powerlet   Added VistaCruise and Powerlet I_icon_minitimeSun Apr 17, 2011 9:20 pm
Im going to go with the Brakeaway control for mine. But not before a givi screen!
http://www.brakeawayproducts.com/productinfo.html
A bit pricey, but the quality, and operation is top shelf
» Added performance, wear and tear, added cost, or another bike?
» Added a new instrument cluster
» Added another State!
» Hi, I added a few more emoticons
» Added a new "Premium Package"
