Ideling up and down I_icon_minitimeby zrx212 Yesterday at 9:40 pm
Ideling up and down I_icon_minitimeby Meldrew Yesterday at 9:37 pm
Ideling up and down I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 11:05 pm
Ideling up and down I_icon_minitimeby terryweasely Thu Nov 14, 2024 3:48 am
Ideling up and down I_icon_minitimeby AldusFran Mon Nov 11, 2024 2:21 pm
Ideling up and down I_icon_minitimeby xwelder Sat Nov 09, 2024 8:46 pm
Ideling up and down I_icon_minitimeby landisr Sat Nov 09, 2024 5:46 pm
Ideling up and down I_icon_minitimeby Dale N. Fri Nov 08, 2024 3:07 am
Ideling up and down I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 1:24 pm
Ideling up and down I_icon_minitimeby Siataukreg Thu Nov 07, 2024 8:45 am
 Ideling up and down
lesley & John
lesley & John
lesley & John
Number of posts : 113
Ideling up and down Empty
PostSubject: Ideling up and down   Ideling up and down I_icon_minitimeTue Apr 26, 2011 6:48 pm
Wonder if any other swing owners get these two issues I'm having at the moment when I first start her in the morning she will go up to 2000 revs which I believe is normal but with a bad vibration enough to make the right hand mirror vibrate but once warm the vibration gets alot better?also my idling has just started to vary slightly I like her set at 1400 I know it should be around 1300 but every now and then she will drop 100 revs then go up 100 or so revs a bit like surging I've got a new air filter standard and plugs are standard and 2000 miles on them just wondering if these symtoms are common thanks all
Number of posts : 3837
PostSubject: Re: Ideling up and down   Ideling up and down I_icon_minitimeTue Apr 26, 2011 7:13 pm
Mine always revs higher when I start it but I rarely wait long enough to experience any other variations.
Does the Silverwing have an automatic choke? If so, that's the reason.
Number of posts : 2392
PostSubject: Re: Ideling up and down   Ideling up and down I_icon_minitimeTue Apr 26, 2011 8:21 pm
Higher revs at first start of the day is pretty normal. As for the vibration, I too suffer that phenomenon but after the engine is warm and the revs have dropped so does the vibration. I find on my machine the mirror vibration at most speeds when riding too.
As for the 'surging' as you call it, I call it 'hunting' I have no idea. Probably something to do with the engine mapping - me wild guessing!!!!
Mike, I await to be corrected but I don't think FI engines have a choke, I thought they were for the carburatted engines!!
PostSubject: Re: Ideling up and down   Ideling up and down I_icon_minitimeTue Apr 26, 2011 8:34 pm
Indeed, Doug, but I think injected engines have some sort of device for enriching the mixture on start-up................don't they?
PostSubject: Re: Ideling up and down   Ideling up and down I_icon_minitimeTue Apr 26, 2011 8:35 pm
Your forcing me to open up my manual aren't you!! Laughing
PostSubject: Re: Ideling up and down   Ideling up and down I_icon_minitimeTue Apr 26, 2011 8:43 pm
OK opened the manual!
I looked, I no understandee!!
Just tons of sensors. So my guess would still be the engine mapping!!!
Out of my depth with any more!!
BlackFly
BlackFly
Number of posts : 151
Registration date : 2010-11-20
PostSubject: Re: Ideling up and down   Ideling up and down I_icon_minitimeTue Apr 26, 2011 8:55 pm
Cold start enrichment is done by the ECU via the mapping of the fuel injection times. You don't have (except of the sensors but they are not only used for this) any special hardware for the enrichment like on carburators.
To the idling speeds: 2000 revs should be normal with cold engine, i think i had at winter temperatures some more...
To the surging: Do you hear it or do you only see it on the tacho? I think it can also be a indication problem. Btw, the rev meter is no high precision indicator it estimates the value and 100revs more or less can be misjudging of the indicator. Therefore the question: Do you hear it?
AAAA
Number of posts : 442
Registration date : 2010-11-14
PostSubject: Re: Ideling up and down   Ideling up and down I_icon_minitimeWed Apr 27, 2011 12:34 am
Mine does the same thing, and i hear it.They all idle up till a certain temp is achieved, allowing the o2 sensor to do the job of measuring air. The o2 sensor, in harmony with the maf sensor(if it has one?) is what determines the fuel ratio to be inserted into the cylinders. Does anyone know if the o2 sensor is a 2,3,4 wire? If its a 3 wire or over it has closed loop tuning.
Number of posts : 2387
Registration date : 2010-05-03
PostSubject: Re: Ideling up and down   Ideling up and down I_icon_minitimeWed Apr 27, 2011 3:22 am
4 wire, definitely closed loop.
ehaughn
ehaughn
Number of posts : 131
Registration date : 2010-06-14
PostSubject: Re: Ideling up and down   Ideling up and down I_icon_minitimeWed Apr 27, 2011 3:43 am
I also have the vibration as well and only have 2k miles on her.
I notice the vibration in the handle bars. If I accelerate a little while it warms up, it goes away for a splt second until the idle drops.
Also, once warm, it also goes away.
When riding on the highway, I do get some vibration on the mirrors as well.
I think it has to do with it being a twin cyclinder?
Erick
PostSubject: Re: Ideling up and down   Ideling up and down I_icon_minitimeWed Apr 27, 2011 3:58 am
No vibration on mine and my mirrors are crystal clear at all times. I'm wondering if you are feeling drive belt slap?
ehaughn
ehaughn
PostSubject: Re: Ideling up and down   Ideling up and down I_icon_minitimeWed Apr 27, 2011 4:07 am
Not sure, I do not hear the belt hitting the case.
No idea on how to troubleshoot this.
PostSubject: Re: Ideling up and down   Ideling up and down I_icon_minitimeWed Apr 27, 2011 5:02 am
Maybe a throttle synchronization issue?
This could be more pronounced during fast idle enrichment when open loop operation does not modify the ignition and injector pulse width with feedback from the O2 sensor.
Ideling up and down
