DR pulley sliders-bike vibration I_icon_minitimeby zrx212 Yesterday at 4:40 pm
DR pulley sliders-bike vibration I_icon_minitimeby Meldrew Yesterday at 4:37 pm
DR pulley sliders-bike vibration I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
DR pulley sliders-bike vibration I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
DR pulley sliders-bike vibration I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
DR pulley sliders-bike vibration I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
DR pulley sliders-bike vibration I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
DR pulley sliders-bike vibration I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
DR pulley sliders-bike vibration I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
DR pulley sliders-bike vibration I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
3 posters
andyman
Number of posts : 67
Registration date : 2009-10-28
DR pulley sliders-bike vibration Empty
PostSubject: DR pulley sliders-bike vibration   DR pulley sliders-bike vibration I_icon_minitimeWed Apr 27, 2011 7:07 am
A week ago I installed a set of DR pulley sliders. I got 26g weights, the acceleration isn't much different, but I am enjoying the lower RPMS at highway speeds. The bike at lower speeds now vibrates when using the throttle, so much that I can't see clearly in the rear view mirror. Is this normal? The vibration smooths out when the variator is fully extended, around 55 mph.
Over the past 2 months I went from my worn out Jcosta, back to stock, then to the DR pulley sliders. So far, the stock seems to be the best overall, even though I'm sure new Jcosta pins would help that one out. I think there's potential in DR pulley, just the vibration is getting annoying.
buddy19520
buddy19520
Number of posts : 378
PostSubject: Re: DR pulley sliders-bike vibration   DR pulley sliders-bike vibration I_icon_minitimeThu Apr 28, 2011 11:23 am
I've read that the DR Pulleys sliders must be installed in a specific way. Do you think you might have one or more installed backwards/upside down?
Most people seem to like them.
I use a JC variator. Have put about 7000 miles on it and still like it. My recollection of the stock variator is the rumble in the dashboard upon acceleration - I much prefer the smoothness of the J Costa.
Please let us know your outcome. A comparison between the three types of variators/weights would also be interesting.
PostSubject: Re: DR pulley sliders-bike vibration   DR pulley sliders-bike vibration I_icon_minitimeThu Apr 28, 2011 3:30 pm
The 'grooved' side of the Dr Pulley Sliders faces the fixed ramp plate, and the flat surface rests on the center hub of the movable variator sheave.
Did you use Blaster Dry Lube? Ya gotta spray the variator ramps with that stuff. It evaporates quickly and leaves a dry white lubricant.
Hope this makes sense.
andyman
PostSubject: Re: DR pulley sliders-bike vibration   DR pulley sliders-bike vibration I_icon_minitimeThu Apr 28, 2011 8:34 pm
Thanks for the feedback. I am fairly certain that I installed them in the correct manner, but I didn't lube them. I'll take it apart to inspect and lube again. I may order another set of DR Sliders to get a better weight for my desired riding style.
I put 16k miles on my Jcosta and originally I loved it. I got tired of the more frequent belt changes since it only drives on one side of the variator. I got 8k on my belts. The road manners of the Jcosta were great, more power when needed by allowing the scoot to rev higher at low speeds but high throttle, also at high speed the revs were lower which made highways better.
When I pulled my belt apart to check my clutch since there was slipping at low speed high power starts, I found that the belt was so worn that both sides of the variator would come in contact with each other. The belt only had 8k miles on it, so I figured that I'd start experimenting with other stuff. I put the stock variator back in for a while to get use to it before modding again. I was surprised most by the revs on the highway of the stock setup. A brief 90 mph jaunt with high revs gave me the modding bug again. I bought 26g DR pulley sliders and the revs are very similar to stock but the variator doesn't max out as soon, around 60 mph, and when it does, the revs on the highway are lower. This should be constant for any weight DR pulley, but now I think I want lighter weights to get some of the Jcosta acceleration back. The only downside to the sliders is the vibration that I am experiencing. Maybe one slipped on install, but I'll add dry lube when I inspect.
buddy19520, if you want to check out the sliders, I'm a few exits down I-77 on the other side of Huntersville, we should get together and ride sometime.
» Dr. Pulley Sliders, again
» Dr. Pulley sliders - which ones do I have?
» Dr Pulley Slider Installation
» Dr pulley sliders
