BlackFly Maxi-Scooter Rider
Number of posts : 151 Age : 46 Location : Germany Points : 5292 Registration date : 2010-11-20
| Subject: Hyperpro installtion Thu May 05, 2011 1:51 pm | |
| I just ordered my Hyperpro springs Do i have to replace also the fork seals if i don't have any leaks? I think i can do easyly the replacement of the spring and oil but i don't have the tool to install a new seal. If i want to change the seal i need a garage that will do the job for me (of course i will remove the fork by myself to reduce the costs and have a little bit fun with maintenance )
thomphoto Maxi-Scooter Rider
Number of posts : 188 Age : 87 Location : Owensboro, Kentucky Points : 5877 Registration date : 2009-06-11
| Subject: Re: Hyperpro installtion Thu May 05, 2011 1:58 pm | |
| You won't need to change the seals to install the fork springs. It's a fairly simple job.
Wendell |
joncallihan Silver Wing Guru
Number of posts : 1025 Age : 86 Location : Lafayette, Colorado, USA Points : 6931 Registration date : 2009-02-16
| Subject: Re: Hyperpro installtion Thu May 05, 2011 3:38 pm | |
| The hardest part of spring replacement is compressing the new (stiffer) spring while getting the tube cap started. |
steveR Super Scooter Rider
Number of posts : 218 Location : Shropshire, God's own county! Points : 5246 Registration date : 2011-03-23
| Subject: Re: Hyperpro installtion Fri May 06, 2011 4:51 am | |
| - joncallihan wrote:
- The hardest part of spring replacement is compressing the new (stiffer) spring while getting the tube cap started.
VERY true!!! I like to get the fork leg in a vice and then put the fork cap in a T-bar socket to allow a constant yet steady downward pressure without taking too much skin off my knuckles.... |
| Subject: Re: Hyperpro installtion Fri May 06, 2011 11:16 am | |
| Just look at these tips and free advice. They are all being logged and remembered when/if I get round to modding the 'Wing'. I love this site. |
