» Fun times ahead
Seat Latch Issue I_icon_minitimeby Loosemarbles Today at 3:49 pm
» Dashboard Square
Seat Latch Issue I_icon_minitimeby MikeO Today at 4:11 am
» Hello From MD
Seat Latch Issue I_icon_minitimeby GHM-PM Yesterday at 7:15 am
» LED Headlights
Seat Latch Issue I_icon_minitimeby landisr Mon Oct 28, 2024 11:35 pm
Seat Latch Issue I_icon_minitimeby DescendingRaven Mon Oct 28, 2024 5:15 pm
» Ignition Switch
Seat Latch Issue I_icon_minitimeby POCAHONTAS Sun Oct 27, 2024 9:07 pm
» Lift Without A Lift
Seat Latch Issue I_icon_minitimeby landisr Sat Oct 26, 2024 5:25 pm
Seat Latch Issue I_icon_minitimeby xwelder Sat Oct 26, 2024 3:18 pm
Seat Latch Issue I_icon_minitimeby xwelder Fri Oct 25, 2024 5:00 am
» Handlebar Holder Recall
Seat Latch Issue I_icon_minitimeby xwelder Thu Oct 24, 2024 9:12 am
 Seat Latch Issue
3 posters
aidanpryde18
Number of posts : 28
Registration date : 2011-04-29
Seat Latch Issue Empty
PostSubject: Seat Latch Issue   Seat Latch Issue I_icon_minitimeFri May 20, 2011 1:42 pm
I am loving my Swing SOOOO Much!
The only issue I am having right now is a lot of the time, when I try to open my seat storage, when I turn the key it won't unlatch.
Usually if it happens, on the second turn it will pop open. I make sure that every time I close it, I hear the seat click closed.
Also, if I hold the key over when it doesn't click, I can manually lift the seat and it will sometimes open.
I am not sure if it is the spring release, the seat cable, or maybe the hydraulic seat lifter. I have the service manual but there is nothing in the manual that describes maintenance or repair of this area.
What do you guys think? I don't want to go pulling apart tupperware if it's unnecessary.
Thanks so much,
Billy
alejom
alejom
Number of posts : 64
Registration date : 2011-02-18
PostSubject: Re: Seat Latch Issue   Seat Latch Issue I_icon_minitimeFri May 20, 2011 1:49 pm
I had the same issues at the beginning, closing the seat takes some learning.
When you close the seat, place the palm of your hand on the passenger's back rest and your fingers on the aluminium rack "lip"; then clamp (closing your hand) and push down. This is mainly useful during the winter, but you can spray some silicone lubricant in the latch and that will help too.
Sometimes, I have had a problem when the trunk is so full, that when I turn the key, the foremost seat latch does not unlock, only the rear one. A bit of an annoyance until I get it to unlock after two or three lock-unlock tries.
GaryL
GaryL
Number of posts : 237
PostSubject: Re: Seat Latch Issue   Seat Latch Issue I_icon_minitimeFri May 20, 2011 6:40 pm
Billy,
There are two latches on the SW seat. One at the very back, and another in the middle, under the rider portion of the seat. Next time that happens, leave the key turned to unlock, and push down hard on the middle of the rider seat, just forward of the backrest. You will likely hear the latch release, and then the seat will open.
Seat Latch Issue
» Is the seat supposed to stay up on its own ,when you unlock it and open it?
» seat latch worn
» Seat latch jammed
» Forward seat latch dilemma
» Seat latch stuck this morning
