» Rear wheel valve stem
Normal Temps? I_icon_minitimeby Meldrew Today at 12:28 am
Normal Temps? I_icon_minitimeby Hop Yesterday at 7:04 pm
Normal Temps? I_icon_minitimeby COMick Fri Nov 22, 2024 6:13 pm
Normal Temps? I_icon_minitimeby xwelder Fri Nov 22, 2024 12:31 pm
Normal Temps? I_icon_minitimeby sonuvabug Thu Nov 21, 2024 4:17 pm
Normal Temps? I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Normal Temps? I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Normal Temps? I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Normal Temps? I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Normal Temps? I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
 Normal Temps?
AAAA
8 posters
AAAA
Number of posts : 442
Registration date : 2010-11-14
Normal Temps? Empty
PostSubject: Normal Temps?   Normal Temps? I_icon_minitimeTue May 31, 2011 10:47 pm
im sure im just overly paranoid here but should the fan come on during a leisurely evening ride? 80 degrees out. The gauge says ok, but when i shut it off, the fan will be on if i turn the ignition on. Also, the right side swingarm pivot it hotter than hell. so is the exhaust can, but i assumed it contains a cat. It just seems that the bike gets really hot. Everything checks, fluids fine, no warning lamps, temp gauge at 1/2 way mark.
Number of posts : 1288
Normal Temps? Empty
PostSubject: Re: Normal Temps?   Normal Temps? I_icon_minitimeWed Jun 01, 2011 7:32 am
Tagg, I believe that is normal. Even though the engine is not "over heated" the temp does rise when the engine is shut off and air from scoot movement stops moving over the engine. The sensor will turn the fan on as a normal function. The only time I hear that is when I am stopped with the engine running and even as I am ready to get off but before turning the key off. If all other indicators you mention are reporting normal, don't worry.
Right now, everything is going to seem "Hot as Hell".
Hope to meet you at the STO rally. Bring your camera. You really should find a smaller one though. Razz
Number of posts : 2392
Normal Temps? Empty
PostSubject: Re: Normal Temps?   Normal Temps? I_icon_minitimeWed Jun 01, 2011 7:35 am
Sounds normal to me also. sunny
AAAA
Normal Temps? Empty
PostSubject: Re: Normal Temps?   Normal Temps? I_icon_minitimeWed Jun 01, 2011 7:55 am
Thought as much, just never experienced a blistering swing arm before.
Gotta love the Ozarks summer! 90 degrees, and 97% humidity!
Cameras? Its what i do for a living!
Normal Temps? Empty
PostSubject: Re: Normal Temps?   Normal Temps? I_icon_minitimeWed Jun 01, 2011 8:00 am
"Cameras? Its what i do for a living!"
I kinda figured that out... hard to imagine you riding the Swing carrying that big guy on your shoulder.
Number of posts : 2387
Normal Temps? Empty
PostSubject: Re: Normal Temps?   Normal Temps? I_icon_minitimeWed Jun 01, 2011 8:26 am
x
eddy
Number of posts : 187
Normal Temps? Empty
PostSubject: Re: Normal Temps?   Normal Temps? I_icon_minitimeWed Jun 01, 2011 10:59 am
Same here.
If you realy want a second check...
After a ride when engine has a good working temperature....
Put a temperature meter in the oil fill hole.
Mine is about 207 gr F. ( 97 Celsius)
Eddy
http://edho@operamail.com
Normal Temps? Empty
PostSubject: Re: Normal Temps?   Normal Temps? I_icon_minitimeWed Jun 01, 2011 12:25 pm
This is normal for both my Swing and my other scooter.
GaryL
GaryL
Number of posts : 237
Normal Temps? Empty
PostSubject: Re: Normal Temps?   Normal Temps? I_icon_minitimeWed Jun 01, 2011 2:18 pm
I have ridden mine in 110 degree weather here in Arizona, and it has never shown any sign of running hot or overheating. Temp guage always shows halfway once warmed up. The fan runs at stoplights, but as you point out, that happens even on 80 degree days. It does seem to get slightly better gas mileage in the hot weather.
Normal Temps? Empty
PostSubject: Re: Normal Temps?   Normal Temps? I_icon_minitimeWed Jun 01, 2011 6:04 pm
I see the same.
robert
robert
Number of posts : 267
Normal Temps? Empty
PostSubject: Re: Normal Temps?   Normal Temps? I_icon_minitimeThu Jun 02, 2011 11:36 am
Hey Tagg,
When are you going to move back to the Valley of the Sun, where it's hot and dry, instead of the hot and humid? Ride Safe...
Robert
Sun City, Az.
Normal Temps?
» Is this normal, or a problem?
» is this normal??
» Is this normal?
» Normal maintenance on a SW
» I guess it's normal
