Seat jammed shut I_icon_minitimeby sonuvabug Today at 4:19 pm
Seat jammed shut I_icon_minitimeby sonuvabug Today at 4:17 pm
Seat jammed shut I_icon_minitimeby sonuvabug Today at 4:06 pm
Seat jammed shut I_icon_minitimeby JohnyC Yesterday at 10:04 am
Seat jammed shut I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Seat jammed shut I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Seat jammed shut I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Seat jammed shut I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Seat jammed shut I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Seat jammed shut I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
 Seat jammed shut
goldwinger
joncallihan
craigory
thomphoto
wingnprayer
AAAA
steveR
16 posters
steveR
steveR
Number of posts : 218
Registration date : 2011-03-23
Seat jammed shut Empty
PostSubject: Seat jammed shut   Seat jammed shut I_icon_minitimeSun Jul 17, 2011 7:44 am
This was a real pain as i was on a trip around Scotland late last week and the w/e and the seat jammed so that I could not open it and get at the gear inside the boot! Sad Not good....
The rear catch is opening OK, and I was able to squeeze some stuff out, but only clothes and the like... The seat appears to have either a 2nd catch around the middle of the seat, or has jammed, as the seat wobbles back and forth at the front end when the rear catch has been opened.
I have tried brute force, that didn't work. I have tried putting pressure on the middle area when turning the boot key, no joy either.
Anyone had this or can recommend a way to get at the inside? I did fit a new gas strut before I went away, and did wonder if that was jammed, but when squeezing the seat up, it appears to be free, and with pressure should open anyway.
AAAA
Number of posts : 442
Registration date : 2010-11-14
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeSun Jul 17, 2011 10:51 am
Someone needs to come up with a secret pull cord somewhere up under the side panel for things like this.
Number of posts : 2778
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeSun Jul 17, 2011 11:08 am
Hey Tag,
How about a solid "T" looking bracket that bolts in-place of the stock Honda center seat bracket. The down side would be the center of the seat would not lock up, but on the other side of the coin, a person would never need to worry about having that cable, latch or latch spring failing when on a trip. If a person just removed the Honda bracket, would the center part of the seat move from side to side? (If I still had my bike I would try that out). That's why I'm thinking a solid "T" type bracket.
wingnprayer
wingnprayer
Number of posts : 166
Registration date : 2009-06-27
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeSun Jul 17, 2011 11:18 am
I've had this as well. The way I've managed to open it is to press down hard on the centre of the seat while pulling upwards at the back. I think the cause of this issue is too much stuff in the compartment.
AAAA
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeSun Jul 17, 2011 12:07 pm
DennisB wrote:
Hey Tag,
I just went out and looked at mine, and that would work, the downside being a lot of "getting down into it". From what i see, it serves no purpose other than additional security, and maybe a sure, tight seal on the box. If that's the case, anyone wanting in the box that bad is just going to take the whole bike anyway, it would take a while to cut into the seat enough to steal stuff.
More simply, one could just cut off the u bolt that serves as a latch bar in the front position. Unbolting it would be possible, but it mounts from the top, so you would have to tear into the top of your seat, remove it, then reupholster
it.
steveR
steveR
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeSun Jul 17, 2011 12:09 pm
Tried this with no joy! Where did you put the pressure, can you remember? This a real pain, I have gear I need out, and I want to use the bike again on Tuesday, 48hrs from now... Sad
steveR
steveR
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeSun Jul 17, 2011 12:11 pm
DennisB wrote:
....on the other side of the coin, a person would never need to worry about having that cable, latch or latch spring failing when on a trip. If a person just removed the Honda bracket, would the center part of the seat move from side to side? (If I still had my bike I would try that out). That's why I'm thinking a solid "T" type bracket.
So I guess from this, that it may well be a cable operating a second catch that is the cause of the problem. Bummer!
AAAA
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeSun Jul 17, 2011 12:19 pm
On a side note. The projector beams in the eyebrow of the front lens idea is a bust. It works but there if far to much fabrication to make it viable. So now were working on using pig spotter mirror cases to accomplish the same thing, mounted on the upper, outside w piece between the windscreen, and the turn signal, looks like it might just work out fine!
And the cut back driver seat bolster is coming along slowly but surely!
AAAA
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeSun Jul 17, 2011 12:29 pm
The forward seat latch is directly under my 2 fingers, its more forward than you think it is.
Seat jammed shut DSCN1114
AAAA
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeSun Jul 17, 2011 12:41 pm
DennisB wrote:
Hey Tag,
Dennis.
Looks like it also serves as a limiting device, allowing the seat plate to travel only so far down, so . . . . . . .
thomphoto
thomphoto
Number of posts : 188
Registration date : 2009-06-11
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeSun Jul 17, 2011 1:04 pm
When I switched to the Corbin seat, I didn't install the center latch, and I've had no problems whatsoever. I don't see what purpose the center one serves.
http://wendellthompsonfineart.com
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeSun Jul 17, 2011 1:43 pm
A person could weld a small piece of the steel into the original Honda seat catch that attaches to the bottom, center of the seat and make it a no-lockable catch. The piece of steel needs to be the same gauge as the Honda round stock used in the catch...It would work.
Does any have the original Honda Part number for the catches (2) that bolt to the bottom of the seat. I have looked on 3 different Honda dealer sights with no results.
confused
Number of posts : 2008
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeSun Jul 17, 2011 1:54 pm
Umm...which latch is it that closes the circuit for the interior light to come on?
If its the front latch then that is a concern by removing or modifying it too.
Dan
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeSun Jul 17, 2011 1:56 pm
Dan, It's the rear latch that does the light
Number of posts : 1288
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeSun Jul 17, 2011 2:13 pm
Steve this has happened to me a bunch of times. Most times I was able to get it open by pressing down in the center of the seat. Once, that did not work and I apologize that I can't remember who suggested this, but it worked.
Have someone (or yourself) sit on the seat while turning the key to open the latch. Worked like magic. Hasn't happened again.
Number of posts : 2387
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeSun Jul 17, 2011 3:02 pm
Tagg, can't quite make out the tat on your arm. What does it say? Is it in Spanish?
craigory
craigory
Number of posts : 120
Registration date : 2011-06-25
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeSun Jul 17, 2011 3:25 pm
After installing the Utopia backrest I discovered that the original gas strut wasn't strong enough, so I installed a stronger one and that fixed the problem. However, after that the middle catch on the seat often refused to release because there was always pressure against it when I unlocked the rear latch. Because the hook was pulling hard against the latch the friction wouldn't let it slide back across the catch to retract. A sharp whack or two of the fist at that position of the seat always lets it release because it momentarily removes it from contact with the hook and it is able to retract. The person above who mentioned unlocking while sitting on the seat is doing the same thing - take the pressure off the center catch so that it can retract. Hope that helps!
joncallihan
Number of posts : 1025
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeSun Jul 17, 2011 4:25 pm
confused
Dennis, Honda Parts Direct lists the center latch as
12 CATCH, SEAT
77230-MCT-000
the rear latch as
10 CATCH, RR. SEAT
77220-MEF-000
The support bar as
19 STAY, SEAT CATCH
77250-MCT-010
I see no reason that the cable to the catch cannot just be disabled (at either end).
Jon
http://www.joncallihan.com
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeSun Jul 17, 2011 5:27 pm
Jon, Good try, but no cigar. The 2 catches that bolt to the bottom of the seat are the same and they are not listed on the web sight. If you open your Silverwing seat and look at the bottom, you will see the 2 catches that are bolted to the bottom of the seat. They are just not listed or shown on the drawing.
steveR
steveR
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeSun Jul 17, 2011 6:16 pm
Thanks for the pic Tagg, I'll have another go in the morning now I have a better idea of where to put pressure..... Smile
steveR
steveR
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeSun Jul 17, 2011 6:19 pm
If all else fails, I will put some serious weight on the seat.... Give me 5 minutes while i get the wife.......
Thanks for the advice.
steveR
steveR
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeSun Jul 17, 2011 6:22 pm
Thanks Gary, I tried pressing down while my daughter operated the seat but had no joy earlier, I'll try sitting on the seat next. Smile
AAAA
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeSun Jul 17, 2011 6:50 pm
Latin.
Where your life may take you
God goes with the holy warrior
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeSun Jul 17, 2011 6:59 pm
Tagg wrote:
Latin.
Interesting.
Mine would say, in hieroglyphics:
"Aliens are responsible for everything"
AAAA
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeSun Jul 17, 2011 7:02 pm
Have someone hold the key turned, then give the latch area a good sharp rap with your hand.
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeSun Jul 17, 2011 7:04 pm
I'm not a big fan of rap.
Will your trick work with some Led Zeppelin rock instead?
AAAA
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeSun Jul 17, 2011 7:10 pm
bigbird wrote:
Tagg wrote:
Latin.
Interesting.
Hmmmm.
Mayan, or Egyptian?
hieroglyphic wise that is.
Both civilizations had the same fascination with the sky. Interesting when you consider the independent development of each society
AAAA
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeSun Jul 17, 2011 7:16 pm
Funny you should say that. I had a dream last week where someone was on the news and said that Mick Jagger had passed away, and that rock and roll as you know it, has died.
All of which has nothing whatsoever to do with a effin stuck seat latch! So there you go!
Long live the the Rolling freaking Stones!
Seat jammed shut 510-80
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeSun Jul 17, 2011 7:25 pm
Thanks for the advice.[/quote] Looks like we may have another member in the hospital and unable to ride. :lol!:
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeSun Jul 17, 2011 7:26 pm
Tagg wrote:
Hmmmm.
Mayan, or Egyptian?
Definitely Egyptian. I am a big believer in ancient alien intervention. It explains a lot of things that the bible and science cannot.
What this has to do with a stuck seat latch is way beyond my scope of comprehension.
I had a dream about old man Soichiro Honda, who started the ball rolling. He came back from the heavens on a scooter powered by a VFR 800 engine, connected to a DN-01 style hydrostatic transmission, applying drive power to the rear wheel via a shaft.
AAAA
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeSun Jul 17, 2011 7:40 pm
bigbird wrote:
Tagg wrote:
Hmmmm.
Mayan, or Egyptian?
Oh! That reminds me of something. Someone correct me if im wrong, but yesterday, i saw a brand new Honda pickup truck (with the funky sloping bed on it) that was a Harley Davidson edition! With all the badges and harley pin-striping and stuff, i couldnt believe it!
goldwinger
goldwinger
Number of posts : 75
Registration date : 2011-06-15
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeMon Jul 18, 2011 3:26 am
I've had this happen too periodically. If pushing down above the first catch doesn't work, try thumping your fist down on the same spot. That worked for me a couple of times. I adjusted the catch after the third or forth time it happened and it's fine now. It was last year but I think the catch was not centralised properly, causing it to stick.
Ian
steveR
steveR
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeMon Jul 18, 2011 7:07 am
Tried all the suggestions here but no luck at all. I have eased the seat up enough to see that it is hooked on the catch, but it won't free at all.
I can see two nuts and wondered what would happen if I could slacken them off?? Hell of a reach though Sad
Failing that, it is bolt croppers or a hacksaw blade and cut the "U" steel part of the catch... Or can I get to the cable and give it a good tug somehow?
Later.....
In the end, I got a hacksaw blade, held it in a length of 1/2" copper pipe that I had flattened to form a long handle, and cut the hook off. 10mins work. On opening the seat, the catch appears to be knackered or the cable is broken, as it is not operating at all when the key is operated.
RESULT! Of a sort.
Number of posts : 3837
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeMon Jul 18, 2011 7:30 am
Clutching at straws - a naff suggestion, too - is it possible to squirt some oil or grease on the catch to encourage it?
*Thinks* - or even washing-up liquid...
Number of posts : 2392
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeMon Jul 18, 2011 3:45 pm
Had the seat latching problem on my Burgman 400. It was p*ss easy to crack open. (When you know how!!)
I have had a few moments with seat latching but mainly due to my loading of the trunk. A few thumps and it released. Hope it's not a sign of things to come. Crying or Very sad
Glad you sorted though Steve, (sort of.) Bad news having to resort to a hacksaw blade!!
wingnprayer
wingnprayer
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeMon Jul 18, 2011 5:18 pm
Is there an easy way to deactivate (sorry not a mechnical bod) this middle latch? Whilst I've never had the sort of failure Steve has had, I could see it happening at an inconvenient moment. I can't see the necessity of this centre latch anyway. If a crook wants in I really don't imagine it will hold out under force.
steveR
steveR
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeMon Jul 18, 2011 5:47 pm
Not a problem really from looking quickly, just remove one side or the other of the catch. Probably the seat side would be the easiest, without recourse to a hacksaw!! Smile
steveR
steveR
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeMon Jul 18, 2011 5:49 pm
I was well hacked off that the "bump" technique was not going to work, especially as the boot was not really loaded at all. I guess everything fails in time... At least it wont jam again.... ever!!! Rolling Eyes
tinman
Number of posts : 1298
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeSun Dec 04, 2011 5:58 pm
Take the side panell with the key off . Remove keylock ,disconect
the cable pull with pliers. after that remove the grease using break parts cleaner
The grease makes it stick .push in the center of the seat while pulling on the cable. YOU welcome
tinman
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeSun Dec 04, 2011 6:05 pm
Read bottom of page 1
Daboo
Daboo
Number of posts : 271
PostSubject: Re: Seat jammed shut   Seat jammed shut I_icon_minitimeMon Dec 05, 2011 5:37 pm
Yup...+1.
Chris
Seat jammed shut
» Seat latch jammed
» Look under the seat?
» low oil shut off?
» Fork tube jammed
» Seat Modification: Car seat substitution
