| Here is the correct key blank for Givi topcase | |
+7RickV WingMan02 dspevack MikeO BlackFly toro8 craigory 11 posters |
craigory Maxi-Scooter Rider
Number of posts : 120 Age : 67 Location : California Points : 5073 Registration date : 2011-06-25
| Subject: Here is the correct key blank for Givi topcase Fri Jul 22, 2011 8:49 pm | |
| Hi everyone, I have a Givi V46 Monokey topcase which I needed a spare key for. I did some research on the web and found a couple of suggestions for the correct key blank. I just got back from the lock shop and I can vouch for one of them because it works for my case. It is an ILCO B59 X162. This is in the US, so I hope they use the same key blanks in the UK.
Keep the rubber side down!
toro8 Scooter Rider
Number of posts : 22 Location : Kansas City, MO Points : 5086 Registration date : 2011-01-18
| Subject: Re: Here is the correct key blank for Givi topcase Sat Jul 23, 2011 1:14 am | |
| Thanks I need an extra key myself. I tried my locksmith but he couldn't get one to work. Maybe with some info he can. |
BlackFly Maxi-Scooter Rider
Number of posts : 151 Age : 46 Location : Germany Points : 5293 Registration date : 2010-11-20
| Subject: Re: Here is the correct key blank for Givi topcase Sat Jul 23, 2011 3:45 am | |
| Take a look for a complete cylinder...
The cylinders are cheap, i think it is more expensive to buy a blank key and copy the original one to the blank one... |
| Subject: Re: Here is the correct key blank for Givi topcase Sat Jul 23, 2011 5:11 am | |
| I'm fairly certain that if the key-cutter has state-of-the-art computerised key-cutting equipment, dialling in a US number will throw up the equivilant number for other countries; a friend of mine in London has such equipment. |
dspevack Silver Wing Guru
| Subject: Re: Here is the correct key blank for Givi topcase Sat Jul 23, 2011 8:19 am | |
| When I needed a replacement lock from GIVI they charged me $7+shipping for the entire lock with two keys.
Dan |
| Subject: Re: Here is the correct key blank for Givi topcase Sat Jul 23, 2011 12:00 pm | |
| - dspevack wrote:
- When I needed a replacement lock from GIVI they charged me $7+shipping
Dan Thats what i mean I don't know your local prices, but i paid ~10€ for a replacement lock (incl shipping) and i think i have to pay minimum 5€ for the key-cutting without the blank key... And if the new lock will cost a little bit more than the blank key & cutting it is anyway the better way in my opinion because you have a new lock without the risk of soon damage... |
WingMan02 Super Scooter Rider
Number of posts : 287 Location : Honolulu Points : 5025 Registration date : 2012-01-19
| Subject: Re: Here is the correct key blank for Givi topcase Thu Apr 04, 2013 4:50 am | |
| Has anyone ordered a spare key keyed for your lock directly from GIVI for the top case? |
RickV Maxi-Scooter Rider
Number of posts : 100 Age : 79 Location : MN Points : 5222 Registration date : 2010-11-28
| Subject: Re: Here is the correct key blank for Givi topcase Thu Apr 04, 2013 11:10 am | |
| I received one key for my Givi E45 monokey case on the purchase of my 2002 SW a few years back. I ordered 2 extra key blanks from Givi for $15 plus postage and then took them to a local locksmith to be cut. The locksmith took one look at the blank, picked up one of his Fiat blanks from his wall and went out to my scoot - it turns out that for $1 I could have had another key without the red plastic cover - live and learn!!
Rick V
| Subject: Re: Here is the correct key blank for Givi topcase Thu Apr 04, 2013 12:19 pm | |
| My Honda dealer wanted $15. for my Swing,I said I can get 2 for $9. I payed $10. with tax. |
| Subject: Re: Here is the correct key blank for Givi topcase Thu Apr 04, 2013 12:56 pm | |
| I got 2 spare keys cut for my Givi E52 locally for a fiver, and if I wanted a replacement Givi lock and 2 keys there's plenty for sale on eBay. |
| Subject: Re: Here is the correct key blank for Givi topcase Fri Sep 27, 2013 6:58 am | |
| Nip to your nearest key cutter & ask him to use automotive blank ... BT2 ... worked for me |
Dimond Silver Wing Expert
Number of posts : 540 Age : 79 Location : San Francisco Bay Area Points : 5533 Registration date : 2011-08-07
| Subject: Re: Here is the correct key blank for Givi topcase Fri Sep 27, 2013 1:51 pm | |
| - The Bern wrote:
- Nip to your nearest key cutter & ask him to use automotive blank ... BT2 ... worked for me
Nip to your nearest key cutter and ask him if he has a blank to match your key as not ever Givi Top Box seems to use the exact same blank - IMHO. Or, buy a key set on ebay - if you can't get what you want from your key cutter. |
DerrillW Scooter Rider
Number of posts : 90 Age : 79 Location : Arkansas Points : 4174 Registration date : 2013-09-28
| Subject: Re: Here is the correct key blank for Givi topcase Sun Nov 24, 2013 9:22 pm | |
| The suggested ILCO B59 X162 will work if cut with due care. I ordered a pair of blanks from ILCO (minimum buy) and the first one made was a fail. The locksmith told me it was the wrong blank. I took the other blank to another locksmith and showed him what had been done wrong. This time the key worked perfectly. Glad I had two blanks! Derrillw |
