Belt Change - simplified facts... I_icon_minitimeby sonuvabug Today at 4:19 pm
Belt Change - simplified facts... I_icon_minitimeby sonuvabug Today at 4:17 pm
Belt Change - simplified facts... I_icon_minitimeby sonuvabug Today at 4:06 pm
Belt Change - simplified facts... I_icon_minitimeby JohnyC Yesterday at 10:04 am
Belt Change - simplified facts... I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Belt Change - simplified facts... I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Belt Change - simplified facts... I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Belt Change - simplified facts... I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Belt Change - simplified facts... I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Belt Change - simplified facts... I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
AAAA
Moonman
Moonman
Moonman
Number of posts : 6
Registration date : 2011-04-23
Belt Change - simplified facts... Empty
PostSubject: Belt Change - simplified facts...   Belt Change - simplified facts... I_icon_minitimeSat Jul 23, 2011 9:15 pm
I have gleaned all info from this most helpful site, however, with all the variables I need someone to verify my findings. (Thanks to y'all for all the info). Smile
I plan to carry a spare belt, steel variator spanner, dry lube, etc as a roadside belt change for me is easier (and quicker) than calling up roadside assist, getting transported home etc.
My 600D has not been "got at" so I assume it has a standard Honda variator (not J. Costa or Malossi).
I believe that I need to buy a Honda belt (which is probably made by Mitsuboshi) and I was going to buy some Dr Pulley sliders (to replace at the same time). I also understand that "pins" are only used on the Costa pulley, so I don't need them.
I plan to change belt and sliders at the 16,000 time but will carry the spares just in case. bom
This should be a breeze job compared to my B650 CVT dramas (now on-sold)...
Another question, is there any reason why dry lube should not be placed on the splined shaft, prior to replacing the variator outer half?
Thanks in anticipation. rabbit
AAAA
Number of posts : 442
Registration date : 2010-11-14
PostSubject: Re: Belt Change - simplified facts...   Belt Change - simplified facts... I_icon_minitimeSat Jul 23, 2011 11:28 pm
Generally, centrifugical force, lubes, and belts don't play well together. Ive never had an issue with removing a driven face before, so its your call.
On another note.
If that's you in the avatar, that's a serious "stache" man! That's badass!
PostSubject: Re: Belt Change - simplified facts...   Belt Change - simplified facts... I_icon_minitimeSun Jul 24, 2011 2:36 pm
To loosen the variator nut you may need either
1) 12v DC or portable impact wrench
2) The Honda tool is small an portable, but the pins are shallow which seem to require a third hand. Honda has a different part number that I found in the Service Manual and ordered. It basically a metal plate with long bolts and a hole drilled out of the middle to access to variator nut ... the metal plate is screwed into the screw holes from the aluminum housing that was removed to access the variator nut.
You may need some leverage to brake the variator nut loose and to apply enough torque for tightening.
Some people keep their old belt as a spare.
With only 16,000 miles on your original OEM rollers ... they should be find to maintain as spares. But if you really like the Dr Pulley sliders you could order another set .... I have both Razz
masscoot
masscoot
Number of posts : 438
PostSubject: Re: Belt Change - simplified facts...   Belt Change - simplified facts... I_icon_minitimeSun Jul 24, 2011 8:04 pm
I think we need a bit more info. What year is your 600D and how many miles on the clock? From your other posts you indicated this is a commuter bike for you. Like bigbird I would just change the belt and sliders and call it a day especially if you are at the 16k service point. A 16k belt makes a good spare as do rollers.
If you did want to carry a spare and the tools to install it, my 2ยข would be using a click torque wrench in place of the breakerbar they are about the same size and weight. Bill makes a good point about being able to torque back to spec. This one tool would do all three jobs. The holder is essential. Lube is just too big to carry on board, I wish they made smaller cans.
Moonman
Moonman
Number of posts : 6
PostSubject: Re: Belt Change - simplified facts...   Belt Change - simplified facts... I_icon_minitimeMon Jul 25, 2011 12:08 am
Thanks guys.
So I need to buy a new belt and the good doctor's sliders, and don't lubricate the shaft.
Now, wheres's the best place in the US of A to purchase?
I will obviously not be purchasing them here in Melbourne...
Thanks for yr input.
Moonman
PostSubject: Re: Belt Change - simplified facts...   Belt Change - simplified facts... I_icon_minitimeMon Jul 25, 2011 1:37 am
Dr Pulley sliders are available from Australia-----Scooter Doctor Pty Ltd.,www.performancecvt.com.au
Is there a reason why you want to buy in the USA??
tubeck
Number of posts : 85
Registration date : 2011-08-10
PostSubject: Re: Belt Change - simplified facts...   Belt Change - simplified facts... I_icon_minitimeWed Aug 17, 2011 1:37 pm
Other than reaching 16,000 mi, is there any ride indication of possible need to change the belt and rollers earlier? (other than drifting to the side of the road).
PostSubject: Re: Belt Change - simplified facts...   Belt Change - simplified facts... I_icon_minitimeWed Aug 17, 2011 1:55 pm
Nothing. I have 37,000 miles on my belt, which I will change when the weather is cooler.
I have only heard of one belt snapping less then 16,000 miles ... as I recall it was with a J Costa Variator.
john123
john123
Number of posts : 133
Registration date : 2010-02-21
PostSubject: the homebrew variator holder or the Honda variator holder.    Belt Change - simplified facts... I_icon_minitimeSun Aug 28, 2011 12:12 pm
homebrew variator holder or the Honda variator holder. How do I make the variator holder. Pleeease
» how not to change a drive belt,
» v belt change
» Belt and Rollers change.
» At what mileage did you change your belt?
» Belt Drive Change
