Replacing hoses on your Silver Wing. I_icon_minitimeby JohnyC Today at 10:39 am
Replacing hoses on your Silver Wing. I_icon_minitimeby JohnyC Yesterday at 3:04 pm
Replacing hoses on your Silver Wing. I_icon_minitimeby JohnyC Tue Nov 19, 2024 9:42 am
Replacing hoses on your Silver Wing. I_icon_minitimeby john grinsel Mon Nov 18, 2024 12:50 pm
Replacing hoses on your Silver Wing. I_icon_minitimeby Meldrew Sat Nov 16, 2024 9:37 pm
Replacing hoses on your Silver Wing. I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 11:05 pm
Replacing hoses on your Silver Wing. I_icon_minitimeby terryweasely Thu Nov 14, 2024 3:48 am
Replacing hoses on your Silver Wing. I_icon_minitimeby AldusFran Mon Nov 11, 2024 2:21 pm
Replacing hoses on your Silver Wing. I_icon_minitimeby xwelder Sat Nov 09, 2024 8:46 pm
Replacing hoses on your Silver Wing. I_icon_minitimeby landisr Sat Nov 09, 2024 5:46 pm
Replacing hoses on your Silver Wing. Empty
PostSubject: Replacing hoses on your Silver Wing.   Replacing hoses on your Silver Wing. I_icon_minitimeThu Apr 02, 2009 9:14 pm
The first hose that you should replace on a Silver Wing is the small hose that runs underneath the oil filter. Go buy the OEM hose it costs 6 to 8 bucks. Buy a small long funnel and some 50/50 antifreeze mix. We're well under $20 bucks. The reason you should replace this hose first is because stuff of the road is hitting it at 70 mph and hot oil from the filter is falling onto it.
Put Silver Wing on center stand and remove ticket box. Next remove Radiator cap. Once bike has cooled of unscrew hose clamps and remove hose. Watch antifreeze mix ooze out. Hose will slide off easily. Put new hose and clamps on. There will be a notch on both side that you slide the hose up to. Stick funnel into radiator cap opening NOT THE BULK TANK and fill radiator up with 50/50 MIX. Gently shake bike to remove air in hoses. If you turn bike on without starting it and the fan comes on that means that there is air in the hoses which is rare but it does happen. Pour more 50/50 mix into radiator. Turn bike on if fan does not come on then there is no air in the hoses. Start your Silver Wing and go riding. Congratulation you've just installed a new radiator hose!
Note: If you try to operate your Silver Wing with air in the hoses then in about 2 minutes the emergency overheat light will come on.
PostSubject: Re: Replacing hoses on your Silver Wing.   Replacing hoses on your Silver Wing. I_icon_minitimeMon Apr 06, 2009 6:18 pm
If your Silver Wing is over 2 years old then go ahead and go to your local Honda dealer and order Hose A, Water (the shorter of the two the longer one goes vertically onto the water pump which is not the hose I'm talking about here) and Hose B, Oil Cooler and go ahead and put them under the trunk. This entire purchase is less than $10 at most Honda dealers!
» Silver Wing vs Gold Wing ??
» Gold Wing vs Silver Wing
» silver wing gone ?
» Should I Buy this Silver Wing?
» Looking for a new Silver Wing?
