Honda Grip Heater connector I_icon_minitimeby zrx212 Yesterday at 4:40 pm
Honda Grip Heater connector I_icon_minitimeby Meldrew Yesterday at 4:37 pm
Honda Grip Heater connector I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Honda Grip Heater connector I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Honda Grip Heater connector I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Honda Grip Heater connector I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Honda Grip Heater connector I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Honda Grip Heater connector I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
Honda Grip Heater connector I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
Honda Grip Heater connector I_icon_minitimeby Siataukreg Thu Nov 07, 2024 3:45 am
4 posters
BlackFly
BlackFly
Number of posts : 151
Registration date : 2010-11-20
Honda Grip Heater connector Empty
PostSubject: Honda Grip Heater connector   Honda Grip Heater connector I_icon_minitimeTue Aug 09, 2011 9:12 am
I bought a used handle bar (mine is bended) with original Honda heated Grips.
Can someone tell me where are the connectors for the Heaters?
In best cases with pictures?
PostSubject: Re: Honda Grip Heater connector   Honda Grip Heater connector I_icon_minitimeTue Aug 09, 2011 10:17 am
Could it be that the Grip Heater wires were cut off when the bars were removed from the original scooter? Hopefully not though.
Grip Heaters are an add-on accessory, and will require an additional wiring circuit (with a fuse) to connect the Heaters to the scoot power supply.
bikerboy
Number of posts : 405
PostSubject: Re: Honda Grip Heater connector   Honda Grip Heater connector I_icon_minitimeTue Aug 09, 2011 11:47 am
Honda heated grips have male and female bullet connectors for each grip connected to a harness which includes the heat controller, this in turn is linked to the brake light circuit for +ve and to the park brake cicuit for -ve. At least that's what the instructions said when I fitted mine a few weeks ago.
BlackFly
BlackFly
PostSubject: Re: Honda Grip Heater connector   Honda Grip Heater connector I_icon_minitimeTue Aug 09, 2011 2:47 pm
Sorry, but what exactly do you mean with +ve and -ve? Means ve = voltage?
My handlebar/heat grips are complet without cutted wires!
The Controller and the heat grips are connected with bullet connectors.
For ground connection a have a (in german we call it) cableshoe like this: Honda Grip Heater connector 39d18ad161-41fb803b66902ff6fd840de7db6ecc7f I think i can attach this somewhere to the frame...
For the positive i have "t-piece" with male and female cableshoes like this: Honda Grip Heater connector 9b3eb611b3-17058. One of them is straight and one of them have 90° and rubber. I think this "T-piece" will fit between the cable and the brake light switch. Is this correct?
But for the moment i have another problem. I don't touched the wiring for the moment and only replaced the handlebar and now i have a short circuit somewhere between the limit switch and the engine start switch...
I think i have to remove a lot of tupperware tomorrow...
PS: Where do i install the controller?
Number of posts : 3837
PostSubject: Re: Honda Grip Heater connector   Honda Grip Heater connector I_icon_minitimeTue Aug 09, 2011 3:07 pm
+ve is short for positive.
-ve is short for negative.
The blue connector you show is called a 'spade' connector in the UK ('male' in this case as it slips inside the other half, the 'female').
bikerboy
PostSubject: Re: Honda Grip Heater connector   Honda Grip Heater connector I_icon_minitimeTue Aug 09, 2011 3:48 pm
The official wiring had two small sub-harnesseswhich had small spade connectors to fit onto the appropriate place on the original wiring and to connect to the main grip harness:- no ring connector on mine, it earthed (or gounded ) thro' the parking brake connection.
BlackFly
BlackFly
PostSubject: Re: Honda Grip Heater connector   Honda Grip Heater connector I_icon_minitimeTue Aug 09, 2011 5:12 pm
OK and thanks...
I think my technical english is ok, but i'm a mechanic and not electrician Wink
The spade connector looks like riginal Honda and the ring connector don't looks like Honda. Then i think i will connect the negative/ground somewhere to the frame...
Is there somewhere a special place to connect the +ve with the brake light circuit? Or is it ok if i put the Heatgrips between the spade connectors of the brake light switch?
And how or where do i attach the controller? Have someone pictures of the attachment of the controller?
PostSubject: Re: Honda Grip Heater connector   Honda Grip Heater connector I_icon_minitimeTue Aug 09, 2011 5:48 pm
For the mount see this picture:
https://www.silverwing600.com/gallery/Personal-album-of-MikeO/Heated-Grips-Controller-Mirror-Extenders-pic_426.htm
The box is attached to a metal plate which fixes on the two bolts.
» Grip Heater Kit Question
» Honda Reflex Headlight Power Connector
» Air Conditioning / Heater
» Honda SilverWing Parts Lists (Real Honda Part Numbers)
» Torque Monster Shootout…. Yamaha FZ1, Honda CBF 1000, Honda CB1300S.
