| Hey dudes! | |
Cnking Scooter Rider
Number of posts : 7 Points : 4830 Registration date : 2011-08-18
| Subject: Hey dudes! Thu Aug 18, 2011 6:01 am | |
| Hey everyone I've finally found s cool place were everyone with these look machines collect. So ofcorse I have a silverwing 600
I was driving it other day and all the electrical power went .. So the engine cut out and nothing would work, I found it was the solenoid fuse under the left pannel , got around the corner this morning and it happens again .
What causes this to go ?
I've been reading through these forums also what a help they are! This ones a bit of a puzzle though.
Cheers. |
| Subject: Re: Hey dudes! Thu Aug 18, 2011 6:05 am | |
| A quik edit. It is the starter relay main fuse A that keeps going thanks again |
| Subject: Re: Hey dudes! Thu Aug 18, 2011 10:32 am | |
Number of posts : 2387 Location : Winnipeg Points : 7883 Registration date : 2010-05-02
| Subject: Re: Hey dudes! Thu Aug 18, 2011 10:57 am | |
| Subject: Re: Hey dudes! Thu Aug 18, 2011 11:44 am | |
| Thanks for reply will have a second look.
| Subject: Re: Hey dudes! Thu Aug 18, 2011 12:44 pm | |
| Can't find any wear no shorts, I have the whole headset off can't achieve a short by moving wires ....mhmm |
| Subject: Re: Hey dudes! Thu Aug 18, 2011 3:14 pm | |
| Subject: Re: Hey dudes! Thu Aug 18, 2011 5:19 pm | |
| No it's pointless doing that (I have checked all that anyway) cause it's intermittent it do not blow as soon as you start the engine , so can't find it by measuring must be something being ran by the fuse ?
Thanks again |
| Subject: Re: Hey dudes! Fri Aug 19, 2011 10:20 am | |
| just putting bike back together- can't find any dodgy wiring it's only two wires to check - so it could be one of 4 things. 1,wire (checked). 2,worn out fuse. 3,dodgy ECT sensor. 4,dodgy regulator/rectifier.
Any Other thoughts ? |
| Hey dudes! | |
