| More butt room | |
craigory Maxi-Scooter Rider
![craigory](https://2img.net/u/3413/63/00/33/avatars/1425-10.jpg)
Number of posts : 120 Age : 67 Location : California Points : 4998 Registration date : 2011-06-25
![More butt room Empty](https://2img.net/i/empty.gif) | Subject: More butt room Fri Sep 02, 2011 12:19 am | |
| Does anybody have a reasonably simple way to get a little more space behind the butt (crude, but what else can I call it?). I have my buttrest (is there an official name?) slid back as far as it will go, and there still isn't enough room. I have a Utopia backrest which mounts directly through the existing buttrest, so that might complicate things. Please let me know what any of you have done to improve this situation. Thanks!
Craig |
dspevack Silver Wing Guru
![dspevack](https://2img.net/u/3413/63/00/33/avatars/39-50.jpg)
Number of posts : 2008 Age : 59 Location : Miami, FL Points : 8136 Registration date : 2008-12-27
![More butt room Empty](https://2img.net/i/empty.gif) | Subject: Re: More butt room Fri Sep 02, 2011 1:31 am | |
| http://www.leroybeal.net/motorcycles/silverwing/articles/backrest/backrest.html
![More butt room Empty](https://2img.net/i/empty.gif) | Subject: Re: More butt room Fri Sep 02, 2011 1:39 am | |
| Thanks Dan. That was a very clever approach. I'm not sure how that would work out with my Utopia backrest, but I'm going to take a hard look to see if they would be compatible. |
Somerled Maxi-Scooter Rider
![Somerled](https://2img.net/h/i139.photobucket.com/albums/q301/Khan_Noonien_Singh/silouette.jpg)
Number of posts : 177 Age : 62 Location : Fort Bliss, TX Points : 5053 Registration date : 2011-06-02
![More butt room Empty](https://2img.net/i/empty.gif) | Subject: Re: More butt room Fri Sep 02, 2011 3:04 am | |
| Craig, I ordered the Jac Vinson seat extender here:
http://www.ebay.ca/itm/Honda-Silverwing-Reflex-Drivers-Backrest-kit-Complete-/270772988952
I saw the bracket Dan mentioned but didn't think it would be reliable enough for my 230 lb body. That, and there was no padding for my lower back which the Vinson provides. It costs more sure, but still fairly inexpensive and I believe worth the extra cost. However, I will admit I think of it as only an interim solution until I get a custom seat and backrest eventually.
I believe honda_silver uses the Utopia without the backrest. You might ask Bill if that is a solution for you too. He found some padding for the bracket it uses as I recall. |
![More butt room Empty](https://2img.net/i/empty.gif) | Subject: Re: More butt room Fri Sep 02, 2011 9:48 am | |
| - Somerled wrote:
- I believe honda_silver uses the Utopia without the backrest. You might ask Bill if that is a solution for you too. He found some padding for the bracket it uses as I recall.
I first installed my Utopia backrest with the buttrest in place, but riding two up ~75% and with gear fully packed ... it sheared both grade 6 and grade 8 bolts. According to Utopia, this has never happened before. I removed the buttrest and reinstalled the Utopia backrest, which is way more comfortable ( without buttrest) and allowed the two Utopia bars to be tightened and with no gap between them ... and the bolt has never sheared. I have a Large AirHawk on my seat covered with an Alaskan sheepskin which covers the plastic groves for the buttrest ... but I will drill out the rivets and completely remove the plastic groves this fall. |
tubeck Scooter Rider
Number of posts : 85 Age : 71 Location : Ft Pierce fl Points : 4890 Registration date : 2011-08-10
![More butt room Empty](https://2img.net/i/empty.gif) | Subject: Re: More butt room Fri Sep 02, 2011 9:55 am | |
| corbin makes a replacement seat for 500.00. I called and found their location here in fl. I am going to go sit on one before buying. I want flatter and further back. I will let you know how it goes |
![More butt room Empty](https://2img.net/i/empty.gif) | Subject: Re: More butt room Fri Sep 02, 2011 12:09 pm | |
| Dan, Tom, and Bill, All of you proved good solutions with pros and cons to each one, and now I need to think about all of these options both separately and perhaps combined in some way. >> Dan, your choice shows very detailed photos on the leroybeal website. They answer any questions I might have. >> Tom, your choice shows photos on eBay. There are 4 bolts attaching the extension bracket to the existing seat brackets. Do those bolts just attach the extension bracket to the existing seat brackets, or do they go all the way through into the seat shell (under the cushion)? >> honda_silver, do you have any photos of your setup? I want to make sure I understand exactly what you've done.
Thanks you guys! Craig |
![More butt room Empty](https://2img.net/i/empty.gif) | Subject: Re: More butt room Fri Sep 02, 2011 12:19 pm | |
| - craigory wrote:
- >> honda_silver, do you have any photos of your setup? I want to make sure I understand exactly what you've done.
http://www.utpr.com/silverwingnew.html Pictures are from the website listed above 1) Utopia backrest with buttrest ![More butt room Swfront](https://2img.net/h/www.utpr.com/images/swfront.jpg) 2) Utopia backrest without buttrest ![More butt room Swbarcover](https://2img.net/h/www.utpr.com/images/swbarcover.jpg) I use two leather wraps ( optional ) from Utopia to wrap both the upper for passenger protect the passenger and lower for appearance. You do you not see the black plastic pieces on mine, because they are covered with a Large AirHawk and Alaskan Sheepskin ( I will have to measure to verify the size ). |
![More butt room Empty](https://2img.net/i/empty.gif) | Subject: Re: More butt room Fri Sep 02, 2011 2:30 pm | |
| - craigory wrote:
>> Tom, your choice shows photos on eBay. There are 4 bolts attaching the extension bracket to the existing seat brackets. Do those bolts just attach the extension bracket to the existing seat brackets, or do they go all the way through into the seat shell (under the cushion)? They go all the way through the cushion and replace the factory plate but use the rest of the factory bracket. |
AAAA Silver Wing Rider
Number of posts : 442 Points : 5575 Registration date : 2010-11-14
![More butt room Empty](https://2img.net/i/empty.gif) | Subject: Re: More butt room Fri Sep 02, 2011 11:55 pm | |
| I just took my bolster off entirely, now i have plenty of room for the boys! |
![More butt room Empty](https://2img.net/i/empty.gif) | Subject: Re: More butt room Sat Sep 03, 2011 12:09 am | |
bkg123 Scooter Rider
Number of posts : 8 Points : 5104 Registration date : 2010-09-26
![More butt room Empty](https://2img.net/i/empty.gif) | Subject: Re: More butt room Mon Sep 05, 2011 10:47 pm | |
| My solution was to completely remove the butt rest, I drilled the rivets out on the plastic guides and the seat allows me to stretch out as much as I like. Right now I have my Airhawk slid back over the place the butt rest used to be, but this winter that's all getting foamed and patched up. The butt rest did nothing for me. |
![More butt room Empty](https://2img.net/i/empty.gif) | Subject: Re: More butt room Mon Sep 05, 2011 11:11 pm | |
| Im in the process of carving my buttrest down, and back, and will re cover it and replace it. Its amazing the difference in the angle between the seat riser and the backrest to begin with. It will be a smaller and much thinner version of what already there. |
![More butt room Empty](https://2img.net/i/empty.gif) | Subject: Re: More butt room Tue Sep 06, 2011 11:01 am | |
| It seems the seat angles up you back up. i took the buut pad off and tried sitting on it. i feel like I am slide forward |
![More butt room Empty](https://2img.net/i/empty.gif) | Subject: Re: More butt room Wed Sep 07, 2011 12:07 am | |
| Hi Tagg, Do you use an Airhawk seatpad? Does it take care of the differing angle problem? Thanks! |
![More butt room Empty](https://2img.net/i/empty.gif) | Subject: Re: More butt room Wed Sep 07, 2011 9:41 am | |
| - craigory wrote:
- Do you use an Airhawk seatpad? Does it take care of the differing angle problem?
I sit all the way back without the buttrest. If you position the AirHawk properly, rear of AirHawk touching the rear ramp or even forward more ... it helps in two ways 1) AirHawk bottom has non-slip rubber and AirHawk top material helps to prevent sliding. 2) If positioned properly the AirHawk should raise your forward height by the height of the AirHawk. |
| More butt room | |
