Kuryakyn LED Battery Gauges I_icon_minitimeby sonuvabug Yesterday at 4:19 pm
Kuryakyn LED Battery Gauges I_icon_minitimeby sonuvabug Yesterday at 4:17 pm
Kuryakyn LED Battery Gauges I_icon_minitimeby sonuvabug Yesterday at 4:06 pm
Kuryakyn LED Battery Gauges I_icon_minitimeby JohnyC Wed Nov 20, 2024 10:04 am
Kuryakyn LED Battery Gauges I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Kuryakyn LED Battery Gauges I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Kuryakyn LED Battery Gauges I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Kuryakyn LED Battery Gauges I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Kuryakyn LED Battery Gauges I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Kuryakyn LED Battery Gauges I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
masscoot
john123
bikerboy
johnd
11 posters
johnd
Number of posts : 544
Kuryakyn LED Battery Gauges Empty
PostSubject: Kuryakyn LED Battery Gauges   Kuryakyn LED Battery Gauges I_icon_minitimeTue Nov 29, 2011 1:51 pm
Where are people installing the Kuryakyn LED Battery Gauges on the scooters?
Number of posts : 1995
PostSubject: Re: Kuryakyn LED Battery Gauges   Kuryakyn LED Battery Gauges I_icon_minitimeTue Nov 29, 2011 1:55 pm
Has anyone installed such a gauge?
http://www.bing.com/search?q=Kuryakyn+LED+Battery+Gauges&src=IE-SearchBox&FORM=IE8SRC
PostSubject: Re: Kuryakyn LED Battery Gauges   Kuryakyn LED Battery Gauges I_icon_minitimeTue Nov 29, 2011 2:41 pm
I would not recommend the Kuryakyn LED. Mine stopped working after getting wet which I found happened to others.
I mounted above the speedometer dead center because the LEDs are bright and I could use the overhanging shelf to block the light if needed.
bikerboy
Number of posts : 405
PostSubject: Re: Kuryakyn LED Battery Gauges   Kuryakyn LED Battery Gauges I_icon_minitimeTue Nov 29, 2011 2:55 pm
Ive been through two of those things on various machines, not very reliable IMHO. I then went to an LED device intended for micro-lights which seemed to fare better but I don't think that it was totally happy with my VRR system so I have nothing fitted to the SWing.
Number of posts : 2008
PostSubject: Re: Kuryakyn LED Battery Gauges   Kuryakyn LED Battery Gauges I_icon_minitimeTue Nov 29, 2011 11:37 pm
The Kisan meter is expensive but it has a few nice extra features too.
Kisan charging and monitoring system
In particular it tells you digitally both volts and amps, and integrates with their battery tender system.
Dan
john123
john123
Number of posts : 133
Registration date : 2010-02-21
PostSubject: Re: Kuryakyn LED Battery Gauges   Kuryakyn LED Battery Gauges I_icon_minitimeThu Dec 01, 2011 11:46 pm
Thanks Dan but these are two expensive for my taste.
Last year i bought there there Vectra Light for $ 80.00 and it lasted about 8 months. I am getting another one for Christmas but only because some one else is paying for it. I really like the way it lights up my reflective jacket when the turn light is on or the break light.I know people really see me coming or going
masscoot
masscoot
Number of posts : 438
PostSubject: Re: Kuryakyn LED Battery Gauges   Kuryakyn LED Battery Gauges I_icon_minitimeFri Dec 02, 2011 8:22 am
I bought and installed one of these many moons ago. For $25 it has been well worth the money. It is only weather resistant but has never failed even in the many downpours I have ridden through. Works well and wired off of switched power. I have a good amount of extras wired in and this makes voltage monitoring very easy. I wanted to monitor not only voltage but air temperature. It also has a built in alarm that sounds when air temp dips below freezing. I do not use the clock or timer side.
Left side is clock/timer ----- Middle: voltage ----- Right: temperature
Kuryakyn LED Battery Gauges IMG_1199
RON SCOLES
RON SCOLES
Number of posts : 1
Registration date : 2012-12-08
PostSubject: HI, WE I NEED HELP ME FOR GAUGES IN QUICKLY FLASH IN MY SCOOTER MOTORCYCLES ?   Kuryakyn LED Battery Gauges I_icon_minitimeSat Dec 08, 2012 5:00 pm
HI ALL, WE I NEED HELP ME I LOOK FOR GAUGES IN VERY QUICKLY FLASH IN MY SCOOTER MOTORCYCLES ? Neutral
THANK RON SCOLES.
bikerboy
PostSubject: Re: Kuryakyn LED Battery Gauges   Kuryakyn LED Battery Gauges I_icon_minitimeSat Dec 08, 2012 5:29 pm
I got through two of the Kuryakin gauges on previous bikes, as other folk have said they are not very reliable. I also had a microlight voltage indicator for a while ( a small LED device which changed from green thro' orange to red according to voltage) but I suspect that it was never totally happy with the Honda charging system. At the moment I have nothing at all and the Scoot seems to run OK without !
Number of posts : 771
PostSubject: Re: Kuryakyn LED Battery Gauges   Kuryakyn LED Battery Gauges I_icon_minitimeSat Dec 08, 2012 11:32 pm
I have had my Kuryakyn gauge for 2 yrs without a problem. Bob has had his even longer.
PostSubject: Re: Kuryakyn LED Battery Gauges   Kuryakyn LED Battery Gauges I_icon_minitimeSun Dec 09, 2012 6:55 am
Since my Kuryakyn failed, I took it apart. It had very little ( almost none ) sealant... what ever sealent was left crumbled. The mother board was covered with a crystalline substance ... I am guessing from the water.
I switched to the ADVMonster digital volt meter which is water proof.
rodenbach
rodenbach
Number of posts : 321
Registration date : 2012-08-30
PostSubject: Re: Kuryakyn LED Battery Gauges   Kuryakyn LED Battery Gauges I_icon_minitimeSun Dec 09, 2012 7:44 am
ADVmonster offer a waterproof voltmeter for $25.00
http://stores.intuitwebsites.com/hstrial-QualiRegResou/-strse-23/Waterproof-Digital-Voltmeter/Detail.bok
Kuryakyn LED Battery Gauges A6473ab1364eb0deb43610_m
wingmann
wingmann
Number of posts : 58
Registration date : 2010-08-22
PostSubject: Re: Kuryakyn LED Battery Gauges   Kuryakyn LED Battery Gauges I_icon_minitimeSun Dec 09, 2012 12:07 pm
I to have 2 Kuryakyn LED volt gauges on my Helix and one did go bad . When I opened it up to see in side I found that water had got in side of it. When I got my silverwing I installed a volt and air temp gauge just like masscoot . You can see a picture of this gauge on his post in this thread . I have insalled two of them and each of them have gone bad do to water getting in side of the gauges . Over this winter I will try some other brand of gauges to replace the air temp and volt gauges that I hope are water proof .
PostSubject: Re: Kuryakyn LED Battery Gauges   Kuryakyn LED Battery Gauges I_icon_minitimeSun Dec 09, 2012 12:59 pm
Wow, I guess Bob and I have been pretty lucky with our Kuryakyn meters.
We have been in some pretty torrential rain. The company should look into there quality control if they haven't already.
I probably just jinx us. Rolling Eyes
» Dead battery ???
» I've lost all my gauges
» Kuryakyn ISO Grips?
» Tire pumps, pressures & gauges
» Kuryakyn iso grip for sportbikes
