Life Expectancy of Wheel and Steering Bearings/Seals I_icon_minitimeby sonuvabug Today at 4:19 pm
Life Expectancy of Wheel and Steering Bearings/Seals I_icon_minitimeby sonuvabug Today at 4:17 pm
Life Expectancy of Wheel and Steering Bearings/Seals I_icon_minitimeby sonuvabug Today at 4:06 pm
Life Expectancy of Wheel and Steering Bearings/Seals I_icon_minitimeby JohnyC Yesterday at 10:04 am
Life Expectancy of Wheel and Steering Bearings/Seals I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Life Expectancy of Wheel and Steering Bearings/Seals I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Life Expectancy of Wheel and Steering Bearings/Seals I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Life Expectancy of Wheel and Steering Bearings/Seals I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Life Expectancy of Wheel and Steering Bearings/Seals I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Life Expectancy of Wheel and Steering Bearings/Seals I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
Johnnygone
andyman
NWSSC
Dimond
12 posters
Dimond
Dimond
Number of posts : 540
Life Expectancy of Wheel and Steering Bearings/Seals Empty
PostSubject: Life Expectancy of Wheel and Steering Bearings/Seals   Life Expectancy of Wheel and Steering Bearings/Seals I_icon_minitimeThu Feb 16, 2012 8:51 pm
At 22,000 miles I checked my 2003 SWing front/rear wheel bearings/seals. They look great, turn fine, and seem to have no wiggles/wobbles - so I plan to leave them as is. Checked steering by turning and wiggling (not sure if this is the proper technical term) - although I did not see/touch them, they seem to be fine also.
I have a question on wheel/steering bearing/seal periodic replacement. Do I just wait for a problem - and when might that be? Or should I take some proactive approach and replace them at some (yet to be defined) interval (based on mileage and/or years of service). My SWing has only seen San Francisco Bay Area weather - not overly hot or cold - and rarely has been exposed to riding in the rain.
What do you think? What do you do? Thanks.
Number of posts : 2387
PostSubject: Re: Life Expectancy of Wheel and Steering Bearings/Seals   Life Expectancy of Wheel and Steering Bearings/Seals I_icon_minitimeThu Feb 16, 2012 10:00 pm
x
NWSSC
NWSSC
Number of posts : 418
PostSubject: Re: Life Expectancy of Wheel and Steering Bearings/Seals   Life Expectancy of Wheel and Steering Bearings/Seals I_icon_minitimeFri Feb 17, 2012 12:21 am
One of the most important things you can do is stay away from the wheel bearings with a power washer. I check them out when I replace the tires. Twice now in 34,00 miles. They are roller bearings(no pre-load adjustment).
You can take most of the weight off the front wheel if you raise the scooter on the center stand and then spin the front wheel by hand to listen for any roughness. I always hear some noise from the rear(when on the center stand) but I attribute this to the straight cut gears in the final drive.
Number of posts : 2392
PostSubject: Re: Life Expectancy of Wheel and Steering Bearings/Seals   Life Expectancy of Wheel and Steering Bearings/Seals I_icon_minitimeFri Feb 17, 2012 5:53 am
Dimond, please stop looking for problems.
If a problem arises it WILL manifest itself. You do not have to magic problems just to invent a reason to strip down components.
Get on the bike and ride.
The Silver Wing likes the road and hates the garage.
Number of posts : 3314
PostSubject: Re: Life Expectancy of Wheel and Steering Bearings/Seals   Life Expectancy of Wheel and Steering Bearings/Seals I_icon_minitimeFri Feb 17, 2012 6:34 am
Ride it-----it is 9 years old, just ride it....and wait for stuff to happen....just as it might in a 9 year old Japanese car.
Ride 40,000 a year and of course stuff needs work, but outside of rubber stuff/battery/tires aging, a SilverWing is a pretty good machine. AND stay away from power car washes. Sometimes you may have to fix stuff ham fisted mechs did to it over the years.
PostSubject: Re: Life Expectancy of Wheel and Steering Bearings/Seals   Life Expectancy of Wheel and Steering Bearings/Seals I_icon_minitimeFri Feb 17, 2012 7:09 am
+1 Agree John. Look and you shall find as they say.
On the other hand. Pour petrol in the tank and enjoy life. At my end of life it's for living not grovelling with spanners trying fix that which aint broke.
Number of posts : 1995
PostSubject: Re: Life Expectancy of Wheel and Steering Bearings/Seals   Life Expectancy of Wheel and Steering Bearings/Seals I_icon_minitimeFri Feb 17, 2012 7:50 am
bigbird wrote:
1) yes
2) ask a clairvoyant
This is what I think.
PostSubject: Re: Life Expectancy of Wheel and Steering Bearings/Seals   Life Expectancy of Wheel and Steering Bearings/Seals I_icon_minitimeFri Feb 17, 2012 7:52 am
Waspie wrote:
Dimmond, please stop looking for problems.
This is also what I think.
This is what I do.
You asked.
PostSubject: Re: Life Expectancy of Wheel and Steering Bearings/Seals   Life Expectancy of Wheel and Steering Bearings/Seals I_icon_minitimeFri Feb 17, 2012 8:54 am
I have 84700 mi on my '04 and while I am a "worry wort" according to some tests I took in college, I haven't given as much concern about my scoot as you have. If you are afraid of the bike, sell it and do something else with your life. With my mileage I have had to replace two bulbs, two plugs and two belts plus troubleshoot some corrosion on some wiring following (by a year) a heavy rainstorm in Missouri. Change the oil, assure that you have coolant and brake fluid. The big test is if it will start. If it does, you are good to go.
So GO!
andyman
Number of posts : 67
Registration date : 2009-10-28
PostSubject: Re: Life Expectancy of Wheel and Steering Bearings/Seals   Life Expectancy of Wheel and Steering Bearings/Seals I_icon_minitimeSat Feb 18, 2012 9:53 am
I had a front wheel bearing go bad on me around 28k. I didn't notice it when I was riding, but found it when I was putting a new tire on. The bearing still spun but it was very rough feeling. Figured it was a wear item and replaced it myself, I had to use my 'pilot bearing puller' to get it out, but otherwise was a very straightforward job. Keep an ear out for different sounds and just keep riding.
Johnnygone
Johnnygone
Number of posts : 26
Registration date : 2012-06-21
PostSubject: Re: Life Expectancy of Wheel and Steering Bearings/Seals   Life Expectancy of Wheel and Steering Bearings/Seals I_icon_minitimeSun Jul 22, 2012 6:12 pm
andyman, I think keeping an ear out is great advice. Carry a cell phone and invite someone with a good trailer over for BBQ every now and then.
SCTLVR
Number of posts : 186
Registration date : 2012-06-27
PostSubject: Re: Life Expectancy of Wheel and Steering Bearings/Seals   Life Expectancy of Wheel and Steering Bearings/Seals I_icon_minitimeMon Jul 23, 2012 6:39 pm
Dimond.
I like your curiosity for how things work...
MarkB
MarkB
Number of posts : 90
Registration date : 2011-09-19
I have to say that I think Dimond's questions are really just 'conversation starters' - and I think he's been largely successfully in getting some good threads going. (I don't often add a lot to them, but I get a lot out of them.)
Number of posts : 2622
PostSubject: Re: Life Expectancy of Wheel and Steering Bearings/Seals   Life Expectancy of Wheel and Steering Bearings/Seals I_icon_minitimeTue Jul 24, 2012 5:44 pm
I replaced the steering head bearings on both my 1974 CT90's. Both were showing symptoms of drag etc. OMG they were actually ball-in-race units too! Replaced them with All-Balls roller bearings. Can you believe they only gave 36 years of service??? Junk. :lol!:
gobi
Number of posts : 2
Registration date : 2012-07-20
PostSubject: Re: Life Expectancy of Wheel and Steering Bearings/Seals   Life Expectancy of Wheel and Steering Bearings/Seals I_icon_minitimeWed Jul 25, 2012 10:56 am
Hi,
I have a Silver Wing 400 is there anyway I can download a workshop manual and user manual. Appreciate your help.
Thank you.
Gobi
» Front End Strip for Head Bearings and Fork Seals
» Allballs steering bearings
» Ordered my Metzler tires and wheel bearings !!!
» Front wheel bearings.
» Front Wheel Bearings
