SILVERWING MIRROR EXTENSIONS I_icon_minitimeby balconio Today at 7:24 pm
SILVERWING MIRROR EXTENSIONS I_icon_minitimeby zrx212 Yesterday at 4:40 pm
SILVERWING MIRROR EXTENSIONS I_icon_minitimeby Meldrew Yesterday at 4:37 pm
SILVERWING MIRROR EXTENSIONS I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
SILVERWING MIRROR EXTENSIONS I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
SILVERWING MIRROR EXTENSIONS I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
SILVERWING MIRROR EXTENSIONS I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
SILVERWING MIRROR EXTENSIONS I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
SILVERWING MIRROR EXTENSIONS I_icon_minitimeby Dale N. Thu Nov 07, 2024 10:07 pm
SILVERWING MIRROR EXTENSIONS I_icon_minitimeby Erdoc48 Thu Nov 07, 2024 8:24 am
4 posters
SILVERWING MIRROR EXTENSIONS Empty
PostSubject: SILVERWING MIRROR EXTENSIONS   SILVERWING MIRROR EXTENSIONS I_icon_minitimeSat May 02, 2009 11:21 am
I'm planning to make up a couple of stainless steel extension arms for the mirrors and wonder if someone knows the exact thread size of the lug that they screw into on the bar fitting.The locknuts take a 15mm spanner so the thread would probably be somwhere between 9mm and 12mm.
I'm lead to believe that there's a slight difference in the thread profile between European and Japanese metric threads for sizes over 12mm sizes so hopefully someone would now what i'm rattling on about.
The new extension would also raise the mirror height as well as bringing them further out as at the moment i'm getting a perfect view of my jacket sleeves at the moment.If anyone else has made these perhaps some dimensions or measurements would be possible.
Number of posts : 2598
PostSubject: Re: SILVERWING MIRROR EXTENSIONS   SILVERWING MIRROR EXTENSIONS I_icon_minitimeSat May 02, 2009 11:51 am
I have read that the threads are 10mm. Is this the measurement you need? I hear the Reflex and the Burgman 400 mirrors work on the SWing and they also have the 10mm thread. Take some pics on how you do this and post them if you have time. I'm sure we would all like to see them.
Cornishman
Cornishman
Number of posts : 181
Registration date : 2009-04-04
PostSubject: Re: SILVERWING MIRROR EXTENSIONS   SILVERWING MIRROR EXTENSIONS I_icon_minitimeSat May 02, 2009 11:58 am
10mm. I put Burgman mirrors on mine they work outstandingly well. Click the picture for larger view.
SILVERWING MIRROR EXTENSIONS Hpim0320.th
Number of posts : 1020
PostSubject: Re: SILVERWING MIRROR EXTENSIONS   SILVERWING MIRROR EXTENSIONS I_icon_minitimeSat May 02, 2009 10:44 pm
Hey All,
I haven't tried it, but does the mirror stem screw in to the mirror head the same as it screws in to the handle bar?? I know there's no lock nut there. Had a funny idea of just getting a piece (whatever required length) of stock threaded material that would screw into both areas and then bend it (carefully) to your most suitable angle. Could then be painted, shrinkwrap applied, etc. Maybe something similar to what Brian is doing. .....just wondered...
DaveR
Number of posts : 440
PostSubject: Re: SILVERWING MIRROR EXTENSIONS   SILVERWING MIRROR EXTENSIONS I_icon_minitimeSun May 03, 2009 11:13 pm
This is "Old Dave" again!
I made two extenders for my 05 SWing. Took a piece of 3/8 in aluminum and cut them out of it with my old saw. I could have use metal as I'm going to paint them black. You do need two 10mm bolts and those are kind of hard to come by here where I live so had to order them. They are the automotive fine thread. You will see when you remove your mirror.
PostSubject: Mirror extenders   SILVERWING MIRROR EXTENSIONS I_icon_minitimeMon May 04, 2009 3:15 pm
Dave Read
I live in Kent and researched mirror extenders for 2009 Silverwing as also fed up looking at my elbows.
I purchased the following Honda parts and they extend mirrors sufficient to give unobstructed view behin - they also do not impeed on Givi windscreen on full lock
Part No 88111mct000 - you need two and these are extender bars - £37.32 the pair
Part No 90314mb6000 - you need two and these are lock nuts - £3.80 the pair
Items ordered and supplied by Kent Motorcycles, Honda dealer
Hope this helps
Bill
FOTGOT TO SAY - Original mirrors just screw into new fittings and job done
Bill
PostSubject: SILVERWING MIRROR EXTENSIONS   SILVERWING MIRROR EXTENSIONS I_icon_minitimeMon May 04, 2009 4:39 pm
Thanks everyone for your responses - all very helpful.I guessed they were probably 10mm threads but my ex-Moto Guzzi 10mm allen socket bolts would start a couple of turns then pinch up.The thread profile is different even they are both 10mm.
I like the Burgman mirrors as they look to have much larger heads although I'm really looking at the least expensive option and think I'll have ago at making a pair of extension arms
Just had my best ride out yesterday since getting the bike in March.Geograhically speaking it probably won't mean much to our friends across the pond when I say I started out at 7.45am from Bromley, Kent and went to Leighton Buzzard (Narrow gauge Railway),across to the Glos.& Warwick Railway and home for supper at 7.30.Super A & B roads,mostly empty,dry weather,excellent machine and 58mpg over 270miles.That might not seem to be a big mileage for a day if you're USA based but in the UK its a different scenario.To give you an idea - Googlemap the route I took starting with the A41 from London - Leighton Buzzard-Winslow-Bicester-Moreton-Stow-Toddington-Cheltenham-Swindon-Bracknell-Guildford,West Wickham.
Cheers and happy riding!
» Mirror extensions
» Mirror extensions
» Mirror Extensions
» Honda Leg Extensions too expensive
» Mirror mirror
