| Column spacing | |
DickO Founding Member
| Subject: Column spacing Wed Apr 25, 2012 11:34 pm | |
| Hey Admin,-------------------------------------------------------- Why do the top two series of week days in the calendar (in left column near the bottom) run over into the "Author" column (two of the days at least). Would be all the days except the avatar prevents, or hides, the lower 3 series. As I look again, it is whenever "any" avatar is in the calendar area. The calendar looks to be too wide.
jdeereanton Silver Wing Guru
| Subject: Re: Column spacing Fri Apr 27, 2012 8:29 am | |
| DickO,
I think it has been fixed? |
| Subject: Re: Column spacing Fri Apr 27, 2012 8:33 am | |
| - jdeereanton wrote:
- DickO,
I think it has been fixed? Nah - No and Negative!!!! Calendar still intrudes into the main body. |
| Subject: Re: Column spacing Fri Apr 27, 2012 8:37 am | |
| Could be a display aspect ratio thing. It no longer intrudes on my screen, my display is set to 1280x768, and no problem. |
| Subject: Re: Column spacing Fri Apr 27, 2012 8:43 am | |
- Could be a display aspect ratio thing. It no longer intrudes on my screen, my display is set to 1280x768, and no problem.
Will experiment Dale. My display is currently 1280 - 800! |
| Subject: Re: Column spacing Fri Apr 27, 2012 8:44 am | |
| Nope, if I change the settings the calendar still intrudes!
I reckon I can live with it. |
| Subject: Re: Column spacing Fri Apr 27, 2012 10:41 pm | |
| Dale... are you pickin' on me??? I don't even have a calendar now. But then, I never used it anyway, so I really don't care if it's gone. Really, I can live with it too... was just curious. Thanks none the less. |
| Subject: Re: Column spacing Sat Apr 28, 2012 4:15 am | |
| Yay - it's has gone. Superb. One of those little irritations that once spotted is really quite annoying!! |
| Subject: Re: Column spacing Sat Apr 28, 2012 8:04 am | |
| I do have to say that if a change is made, it is sort of a courtesy to let us know. Especially in this case where a poster actually pointed out a problem.
Is the calendar gone because some sort of positive action was taken? Sometimes moderating is more than just quoting or linking. |
| Subject: Re: Column spacing Sat Apr 28, 2012 9:37 am | |
| Subject: Re: Column spacing Sat Apr 28, 2012 2:11 pm | |
- Is the calendar gone because some sort of positive action was taken?
The Calendar button is (and always has been) on the main menu bar. The Calendar picture was a widget. The size of the calendar widget did not reduce in size, no matter what changes were made ... therefore the duplicate calendar was removed as only resolution. - jdeereanton wrote:
- Sometimes moderating is more than just quoting or linking.
Since I have been unbelievably busy with my normal job ... then secondary moderating work will be effected. Now back to normal job. |
| Subject: Re: Column spacing Sat Apr 28, 2012 7:18 pm | |
| Problem noted and handled... Good Job! |
| Subject: Re: Column spacing Sat Apr 28, 2012 8:37 pm | |
| Damn those short people. Oh, you said widget. My bad. |
| Subject: Re: Column spacing Fri May 04, 2012 9:33 am | |
| - honda_silver wrote:
- ... then secondary moderating work will be
effected. "affected" Part of my normal job. |
| Column spacing | |
