LarryB Scooter Rider
Number of posts : 24 Age : 77 Location : Sw Virginia USA Points : 4743 Registration date : 2011-12-26
| Subject: Headlight Question Tue May 22, 2012 9:10 pm | |
| I'm blowing the headlight fuse. Do both headlights light when the hi-beam is on or does the low beam go out?
Thanks |
| Subject: Re: Headlight Question Tue May 22, 2012 10:22 pm | |
| On mine (2007) the low beam stays on when the hi beam comes on. |
OldRacer67 Scooter Rider
Number of posts : 10 Location : N E Indiana Points : 4587 Registration date : 2012-05-13
| Subject: Re: Headlight Question Tue May 22, 2012 10:49 pm | |
| 2010 does too. I like it. |
| Subject: Re: Headlight Question Wed May 23, 2012 5:53 am | |
| Both lights remain on when High Beam selected. |
| Subject: Re: Headlight Question Wed May 23, 2012 9:19 am | |
| OK, thanks for the help. I'll look for the problem. |
| Subject: Headlight problem Sat Jun 02, 2012 9:10 am | |
| I found out that my headlight fuse blows when I turn the handle bars full right. After further examination, I can pull on one of the accelerator cables and blow the fuse. A volt-ohm-meter shows the fused side of the headlight fuse goes grounded when the ignition swith is on and I pull on one of the accelerator cables.
The accelerator cables are very tight when in this position, and must be rubbing agains the wireing harness. I have not tore the bike apart yet to do further examination.
Anyone ever had this problem? |
Number of posts : 387 Age : 71 Location : Lattitude 47 Points : 5752 Registration date : 2010-03-31
| Subject: Re: Headlight Question Sat Jun 02, 2012 12:45 pm | |
| - LarryB wrote:
- I found out that my headlight fuse blows when I turn the handle bars full right. After further examination, I can pull on one of the accelerator cables and blow the fuse. A volt-ohm-meter shows the fused side of the headlight fuse goes grounded when the ignition swith is on and I pull on one of the accelerator cables.
Anyone ever had this problem? I have not heard of this, but thank you for posting your findings. |
