Daboo Super Scooter Rider
Number of posts : 271 Age : 72 Location : Seattle, WA Points : 5764 Registration date : 2009-12-08
| Subject: JCosta Broken Weights Fri Jun 01, 2012 4:20 pm | |
DarthJ Maxi-Scooter Rider
Number of posts : 195 Age : 50 Location : Hell Paso Points : 5027 Registration date : 2011-09-27
| Subject: Re: JCosta Broken Weights Fri Jun 01, 2012 4:40 pm | |
| HOLY CRAP! Should have stopped after the first break. All damage after is operator headspace and timing. That's the point I would have said F*** this and Uhaul-d it back home. |
| Subject: Re: JCosta Broken Weights Fri Jun 01, 2012 7:21 pm | |
| The were the real deal.
Chris |
Old Limey Silver Wing Expert
Number of posts : 921 Age : 80 Location : BOLTON LANCASHIRE ENGLAND Points : 6298 Registration date : 2010-06-09
| Subject: Re: JCosta Broken Weights Sat Jun 02, 2012 12:46 pm | |
| I think maybe this makes the case for Dr Pulley sliders as opposed to J Costa(it does for me) |
jerry-d Scooter Rider
Number of posts : 12 Location : tampa Points : 968 Registration date : 2022-04-19
| Subject: Re: JCosta Broken Weights Fri Apr 22, 2022 11:44 am | |
| pics here are not from a majesty, not from a silverwing. its clearly a tmax cvt. the jcosta is now on its 5th or sixth version. they have greatly improved metallurgy and design. the cvt is hard anodized and drilled at well bottom to create vacuum effect on pins. the slide is DLC coated. diamond like coating. nascar developed to prevent fast wear of piston wrist pins. and the bushing is self lubricating graphite. my friend owns a tmax. I installed the jcosta pro about 5000 miles on it. still butter smooth and quiet. will update when it is serviced. |
sonuvabug Silver Wing Expert
Number of posts : 934 Location : Mid-Western Ontario Canada Points : 6202 Registration date : 2010-09-15
| Subject: Re: JCosta Broken Weights Fri Apr 22, 2022 12:10 pm | |
| - jerry-d wrote:
- ... snipped ... will update when it is serviced.
Please do. Thx. |
09TMaxFL Scooter Rider
Number of posts : 3 Location : Tampa, FL Points : 953 Registration date : 2022-04-21
| Subject: Re: JCosta Broken Weights Fri Apr 22, 2022 1:12 pm | |
| I'm the one Jerry-D is referring to. It still performs the same as it did upon install. Still butter smooth and quiet. It will actually be coming out in favor of the new XRP model with fuzzy washer and newer smaller designed belt. I'm sure we will document the change over and take lots of pics. |
