| Tire Dia. | |
Number of posts : 1298 Age : 76 Location : Matheson, Ontario, Canada Points : 6132 Registration date : 2011-11-29
SCTLVR Maxi-Scooter Rider
Number of posts : 186 Location : Fairfield, CA Points : 4740 Registration date : 2012-06-27
| Subject: Re: Tire Dia. Fri Aug 17, 2012 11:28 am | |
RArch Silver Wing Expert
Number of posts : 613 Age : 57 Location : West London, UK Points : 5416 Registration date : 2011-11-07
| Subject: Re: Tire Dia. Fri Aug 17, 2012 2:28 pm | |
| http://en.wikipedia.org/wiki/Tire_code
-- snip --
Tire geometry
When referring to the purely geometrical data, a shortened form of the full notation is used. To take a common example, 195/55R16 would mean that the nominal width of the tire is approximately 195 mm at the widest point, the height of the side-wall of the tire is 55% of the width (107 mm in this example) and that the tire fits 16-inch-diameter (410 mm) wheels. The code gives a direct calculation of the theoretical diameter of the tire. For a size shown as "T/A_W" use (2×T×A/100) + (W×25.4) for a result in millimeters or (T*A/1270)+ W for a result in inches. Take the common example used above; (2×195×55/100)+(16×25.4) = 621 mm or (195×55/1270)+16 = 24.44 inches.
Using the above info with excel we discover the difference is only 7.4mm for the rear and 1.4mm for the front. Check out the attached image. Not sure you would feel the extra 9mm depth in the profile (96mm vrs 105mm) either.
Your right, they're so near its not worth mentioning.
| Subject: Re: Tire Dia. Fri Aug 17, 2012 2:42 pm | |
| My method was not so complicated,I went to Google tire calculation dia. Suzuki front wheel dia.=21.61" Swing =21.56" Suzuki rear=21.56" Swing=21.27". Very close for rims that are 1+ smaller. |
Number of posts : 378 Location : Cornelius NC Points : 5794 Registration date : 2010-02-28
| Subject: Re: Tire Dia. Tue Aug 28, 2012 4:45 pm | |
| Mostly it helps the B650 riders feel superior to us Swingers!
The only advantage that I think they really have is checking the air pressure - the bigger rim has to make it easier. |
Number of posts : 2392 Age : 72 Location : Portland, UK Points : 8150 Registration date : 2009-07-26
| Subject: Re: Tire Dia. Tue Aug 28, 2012 5:01 pm | |
| - tinman wrote:
- My method was not so complicated,I went to Google tire calculation dia. Suzuki front wheel dia.=21.61" Swing =21.56"
Suzuki rear=21.56" Swing=21.27". Very close for rims that are 1+ smaller. My solution is simpler still!!! I believe you all. By heck there are some clever folk on here! |
Number of posts : 4218 Location : York, North Yorkshire, England UK Points : 9448 Registration date : 2010-11-16
| Subject: Re: Tire Dia. Tue Aug 28, 2012 5:59 pm | |
| What's with the Bergman, it's Burgman, or do they spell it different in Canada eh? |
| Tire Dia. | |
