Rear Rack for Bestem T-Box TBOX-2012-SIL  I_icon_minitimeby JohnyC Today at 5:39 am
Rear Rack for Bestem T-Box TBOX-2012-SIL  I_icon_minitimeby JohnyC Yesterday at 10:04 am
Rear Rack for Bestem T-Box TBOX-2012-SIL  I_icon_minitimeby JohnyC Tue Nov 19, 2024 4:42 am
Rear Rack for Bestem T-Box TBOX-2012-SIL  I_icon_minitimeby john grinsel Mon Nov 18, 2024 7:50 am
Rear Rack for Bestem T-Box TBOX-2012-SIL  I_icon_minitimeby Meldrew Sat Nov 16, 2024 4:37 pm
Rear Rack for Bestem T-Box TBOX-2012-SIL  I_icon_minitimeby POCAHONTAS Thu Nov 14, 2024 6:05 pm
Rear Rack for Bestem T-Box TBOX-2012-SIL  I_icon_minitimeby terryweasely Wed Nov 13, 2024 10:48 pm
Rear Rack for Bestem T-Box TBOX-2012-SIL  I_icon_minitimeby AldusFran Mon Nov 11, 2024 9:21 am
Rear Rack for Bestem T-Box TBOX-2012-SIL  I_icon_minitimeby xwelder Sat Nov 09, 2024 3:46 pm
Rear Rack for Bestem T-Box TBOX-2012-SIL  I_icon_minitimeby landisr Sat Nov 09, 2024 12:46 pm
joncallihan
OkSmitty
8 posters
OkSmitty
Number of posts : 11
Registration date : 2012-08-18
Rear Rack for Bestem T-Box TBOX-2012-SIL  Empty
PostSubject: Rear Rack for Bestem T-Box TBOX-2012-SIL    Rear Rack for Bestem T-Box TBOX-2012-SIL  I_icon_minitimeSun Aug 19, 2012 9:04 am
I recently purchased a
Bestem T-Box TBOX-2012-SIL Silver 20" X 10.5" X 16" Motorcycle/Scooter Top Box
Does anyone have any recommendations on a rear rack for it? Or do i have drill holes in the frame of my 2008 SWto mount it?I have a 2008 silver Wing
Thx,
Smitty
Number of posts : 3314
PostSubject: Re: Rear Rack for Bestem T-Box TBOX-2012-SIL    Rear Rack for Bestem T-Box TBOX-2012-SIL  I_icon_minitimeSun Aug 19, 2012 2:29 pm
I would-----take rear spoiler off, turn over, bosses for holes are already there----drill thru, bolt box directly to spoiler-----racks like GIVI require the same---why waste money on rack? Replace spoiler.
Number of posts : 2778
PostSubject: Re: Rear Rack for Bestem T-Box TBOX-2012-SIL    Rear Rack for Bestem T-Box TBOX-2012-SIL  I_icon_minitimeSun Aug 19, 2012 3:25 pm
Smitty, Your new top box should have come with the mounting system. Did it not?
joncallihan
Number of posts : 1025
PostSubject: Re: Rear Rack for Bestem T-Box TBOX-2012-SIL    Rear Rack for Bestem T-Box TBOX-2012-SIL  I_icon_minitimeSun Aug 19, 2012 4:46 pm
PM DaveR about this, he has one and did a really spiffy mount for it.
:flower:
http://www.joncallihan.com
OkSmitty
PostSubject: Re: Rear Rack for Bestem T-Box TBOX-2012-SIL    Rear Rack for Bestem T-Box TBOX-2012-SIL  I_icon_minitimeMon Aug 20, 2012 7:55 am
Yes Dennis,
It did come with a mounting system. I sent you a pic of that also. Let me know if you would like me to resend it.
Still haven't figured out how to attach pics in the forum as when I try my "attach" button is greed out:o(
Smitty
OkSmitty
PostSubject: Re: Rear Rack for Bestem T-Box TBOX-2012-SIL    Rear Rack for Bestem T-Box TBOX-2012-SIL  I_icon_minitimeMon Aug 20, 2012 8:03 am
Thanks for the suggestion John!
billc.
billc.
Number of posts : 189
Registration date : 2010-02-19
PostSubject: Re: Rear Rack for Bestem T-Box TBOX-2012-SIL    Rear Rack for Bestem T-Box TBOX-2012-SIL  I_icon_minitimeMon Aug 20, 2012 10:34 am
Smitty, I have the Bestem box on my Swing. I attached the mounting plate that came with the box to the rear aluminum wing. I drilled holes in the wing to "match" the holes in the plate. I also used longer bolts and washers to attach the plate so it would be level.
This allows me to detach the top box from the mounting plate whenever I desire to do so. Works great.
p.s. I also added a 1/2" piece of 8" x 8" inch foam under the top box on top of the mounting plate and never have any rattles!!! billc.
kbcmdba
kbcmdba
Number of posts : 178
Registration date : 2011-05-05
PostSubject: Re: Rear Rack for Bestem T-Box TBOX-2012-SIL    Rear Rack for Bestem T-Box TBOX-2012-SIL  I_icon_minitimeMon Aug 20, 2012 11:03 am
I did something similar for my box though I just used some window insulation foam both in the rim and under my box. Helped a bunch... chickendance
KB
http://kbcmdba.blogspot.com/
PostSubject: Re: Rear Rack for Bestem T-Box TBOX-2012-SIL    Rear Rack for Bestem T-Box TBOX-2012-SIL  I_icon_minitimeMon Aug 20, 2012 9:38 pm
I installed my bestem 2012 easily using the existing swing holes. I had to drill extra holes in the bestem mounting plate to align with the factory swing holes. I cringe when I hear guys drilling unnecessary holes in the rear rack!!! Why not drill the plate and leave the bike "stock"? You will have to remove the rear rack to access the factory hole locations. My holes were already predrilled from a previous owner.One important rule is to make sure (before drilling your plate)to "dry fit" the box on the plate to make sure the seat can open without hitting the backrest pad etc. You will have to do all the plate mounting onto the rear rack before installing back on the bike. My box is level and solid as a rock!! Here are 3 pics of the job.
Here's the installed plate. Just drill holes in the plate carefully to allign with stock holes. Note the brake light wire quick connects that allow the box to be removed easily!
Rear Rack for Bestem T-Box TBOX-2012-SIL  Pic510
I used car door edging (cheap and worked excellent) to prevent the provided C channel from scratching the rack.
Rear Rack for Bestem T-Box TBOX-2012-SIL  Pic210
The only extra hole I had to drill was for the brake light wires. After some head scratching I thought this was the best and only spot to bring the wires up and under the mount plate. Drilling the plastic under the rack was easy.
Rear Rack for Bestem T-Box TBOX-2012-SIL  Pic310
OkSmitty
PostSubject: Re: Rear Rack for Bestem T-Box TBOX-2012-SIL    Rear Rack for Bestem T-Box TBOX-2012-SIL  I_icon_minitimeTue Aug 21, 2012 9:47 am
Thanks guys! Got her done.
johnd
Number of posts : 544
PostSubject: Top Box Rattle   Rear Rack for Bestem T-Box TBOX-2012-SIL  I_icon_minitimeThu Feb 11, 2016 9:09 am
For the longest time I had this nasty rattle coming form my box and was not sure if it was from the plastic locking mechanism or under the box. Tried different things including the screw, large flat washer and wing nut to fasten the box to no avail. Then I bought the foam in a tube that expands and after placing some small wedges on each corner filled every opening I could find, After it dried, I took a hack. saw blade and removed the over flow extra. Got a flat black spray paint, masked everything and that was 1 year ago.
Still no rattles. Love it when I come up with a fix that works. :lol!:
» Looking for best tail luggage
» Rear Luggage Rack
» Bestem T-box 929
» Bestem top box
» Top Box/Rack Question
